Cycling shorts.
Quoted: 87 Post(s)
Liked 28 Times
Cycling shorts.
I have a pair of canari gel shorts and 2 pair of sponeed shorts. The canaries are pretty decent. What do you folks like? Something good that wont break the bank.
climber has-been
Quoted: 3432 Post(s)
Liked 3,567 Times
I've been using Voler bibs for many years now. Very comfortable fit, good chamois pads, made in USA.
Voler men's bottoms
Voler men's bottoms
Old fart
Quoted: 3588 Post(s)
Liked 3,400 Times
I'm not a fan of gel shorts. I prefer a thin chamois, just enough to wick away sweat and prevent chaffing.
Quoted: 4806 Post(s)
Liked 3,929 Times
Another fan of very little padding. But far more important, the shorts, as a whole, have to work for you. No one here can do more than suggest names you could try on. What works for them might be far, far from what works for you.
Edit: a snug fit counts for a lot. Hence bibs being so popular. Another way to get the comfort (and keep the convenience of shorts) is to buy shorts and use clip-on suspenders. Yes you will be the only only one an a ride of any size. But your crotch will be just as happy and using the port-a-potty is far easier.
Ben
Ben
Quoted: 87 Post(s)
Liked 28 Times
I've obviously never worn bibs. Maybe I should try some. Might change the whole feel of the ride. The volers look nice. I have noticed sometimes scooting back on the seat sometimes the front of the seat will catch and pull the shorts. That's frustrating.
Liked 3,929 Times
Both suspenders and bibs should stop that. Not if the straps are not tight enough - another reason I like suspenders. They are so simple to adjust. (Also deal with our varying torso lengths to waist sizes.)
Bikes: 1987 Pinarello Montello, 1996 Litespeed Classic, 1996 Colnago Master Light, 1997 Litespeed Ultimate, 2006 Opera Leonardo FP, 2006 Pinarello Paris FP, 1984 Pinarello Record, 89-ish Cornelo Profilo
Quoted: 148 Post(s)
Liked 119 Times
I use Pearl Izumi Quest shorts. I prefer them to the more expensive Pearl 8 panel ones.
On Your Left
Quoted: 3004 Post(s)
Liked 2,433 Times
Not cheap but I really like them.
Sugoi RS Pro bibs
https://us-store.sugoi.com/products/...-pro-bib-short
Sugoi RS Pro bibs
Quoted: 1591 Post(s)
Liked 1,018 Times
I have a few different brands, but I realize that I usually wear the aero-techs.
https://www.aerotechdesigns.com/mens...ike-short.html
Quoted: 4560 Post(s)
Liked 2,802 Times
Przewalski shorts and bibs on Amazon. Best buy you'll find anywhere, at $15-$25. Be sure to get the type with their 3D padding. Most comfortable pads I've tried, including Pearl Izumi, Black Bibs, Aero Tech and others. Wicks sweat without feeling soggy. Dense, resilient, doesn't lose loft, and washes easily.
I used to prefer minimal padding but after losing weight I need a little more around the sit bones.
Quoted: 87 Post(s)
Liked 28 Times
Thanks for the help guys. I guess I'll try my luck and see what works. Being new to cycling it's hard to know where to find good brands clothing. I'm thinking about a pair of bibs, seems interesting.
Quoted: 942 Post(s)
Liked 527 Times
The Rapha Core Bib shorts are the best value in my opinion. $115
You get the compression in all the right areas, it's cut to fit perfectly in a riding position (one thing I can't stand is loose or overly elastic suspenders) and the stitching and chammy are superb.
Quoted: 365 Post(s)
Liked 419 Times
The word is "chafing" (abrade by rubbing). ONE 'f'. Pronounced with a long "a" sound, like "aid".
Chaffing (teasing, mocking) is a completely different word. Pronounced with a short "a" sound, like "apple".
While I'm at it (not JDT, just a pet peeve): "faze" (disturb) NOT, repeat, NOT, "phase" (states or cycles of a system; or, aspect of moon or planet).
Being "phased" is something that happens when Captain Kirk shoots at you (though, being phased could certainly faze you, for a brief instant).
Likes For noimagination:
Bikes: 1979 Raleigh Team 753
Quoted: 3375 Post(s)
Liked 371 Times
Something I didn't see mentioned is the fit does vary a bit by size (duh). Some brands cut and sew in different countries. They actually may use different stitch types, fabric and panel based on location. Typically location is determined by size, but it is not always the same.
Pearl may be gone soon. Of course, they might get a new owner.
Might mean good deals, but might make repeat buys difficult.
Old fart
Liked 3,400 Times
Quoted: 822 Post(s)
Liked 1,960 Times
Chafffing is when you are rubbbed raw. Thats whenn I use my Shammmy Buttter.
Likes For CAT7RDR:
try Merlin cycles from the UK . I like there altura shorts there med range pairs run about 50 bucks have a few pairs for about 4 years now and still holding up really good. Better than some of my pearl Izumi shorts that cost over a hundred bucks shipping takes about a week tho .
Quoted: 229 Post(s)
Liked 327 Times
My first cycling shorts were Canir shorts, not bibs. Did their job in eliminating chafing, though my rides weren't long enough to need any padding.
I got a second pair (this time Garneau) from Dick's sporting goods. The problem with the shorts is that the waistband folds over while I'm cycling.
So then I got some of the basic bib shorts and shirts from GCN as I like the channel and the design/colors of the apparel. I quite like them. So far after two months of use they are comfortable, they fit well, the sizing was accurate, and the straps means they stay on.
I have one pair of Assos bib shorts/jersey. The material quality is better but I'm not sure if the difference is meaningful. Maybe they will last longer and that would offset the fact they cost 80% more.
Quoted: 12 Post(s)
I find bib shorts are one of the most important factors in riding and that's why I'm not shy to spend money there. I've really had good experiences with Assos (not surprising) and Eliel.
Quoted: 550 Post(s)
Liked 325 Times
Assos and Rapha also use EIT pads.
Quoted: 1069 Post(s)
Liked 787 Times
I'm sorry but I disagree, I own these and have actually thrown them away due to discomfort. Frankly, shell out some cash for one or two decent $$$ pairs of bib shorts and you will be extremely happy. Far too many people neglect actually buying quality kit and it really does make an extreme difference.
Quoted: 2952 Post(s)
Liked 3,106 Times
Everybody's different and different shorts work for different folks' butts. However, I have never regretted spending to get quality shorts. In my case, Castelli.
Likes For caloso:
