Low tech gravel bike
Quoted: 1872 Post(s)
Liked 692 Times
As long as it's an uphill finish, no problem. It's the descent that would suck.
2019 Salsa Warbird
2019 Salsa Warbird
Likes For shoota:
The uphills sucked too. While derailleurs were permitted in road racing by 1939, "racing" derailleurs of the day had very little chain wrap, usually less than 10 teeth. So in order to also have remotely-plausible gears on the flats, you were looking at doing mountainous ascents in a 55" gear or higher.
Liked 692 Times
2019 Salsa Warbird
2019 Salsa Warbird
While the gearing does suck whether it's paved or not, gearing bottom-out is more of a problem on gravel than pavement due to limited rear wheel traction. You can't stand and chop at the pedals to produce extra torque on gravel like you can on pavement.
Liked 692 Times
Gearing wasn't mentioned in the OP's text, but it's relevant to their example image.
2019 Salsa Warbird
2019 Salsa Warbird
Bikes: too many of all kinds
Quoted: 1147 Post(s)
Liked 415 Times
back when there were real gravel bikes.
Yeah, fixed gear or single speed back in the day. TdF fixed gear - now that would be a sufferfest.
Bikes: yes
Quoted: 1281 Post(s)
Liked 643 Times
It looked miserable.
The documentary itself was ok. Not great. Very little interest to anyone who isn't a cyclist. It's really mostly just footage of these two guys suffering on bikes and pretty light on the historical info. But it wasn't a bad way to kill 1.5 hours on the trainer.
- Soli Deo Gloria -
Quoted: 6844 Post(s)
Liked 736 Times
Has anyone read "Road to Valor" about Gino Bartali?
https://www.goodreads.com/book/show/...-road-to-valor
It was a fascinating book, as much about history as it is about cycling and Bartali himself.
To the point of this thread, I'll bet Gino would have preferred disk brakes and 45 mm tubeless.
-Tim-
-Tim-
Quoted: 2952 Post(s)
Liked 3,106 Times
No suspension, no discs, no gears. Who needs ‘em?
