Strava personal records
Anyone know how Strava personal records are calculated? Did a new route today with a bunch of segment I never road before. Technically they should be personal records since it is my first time?
Dave
Dave
It technically is a new PR, but Strava doesn't give PR medals because you're not really beating a previous time.
Strava does give cups and crowns on segments that you've never done before.
Bikes: 50/34, 11-40, 11 Speed
Quoted: 142 Post(s)
Liked 73 Times
Why can't you simply log into Strava and see for yourself as well perhaps answer other questions you may have?
Likes For bonsai171:
- Soli Deo Gloria -
Quoted: 6844 Post(s)
Liked 736 Times
Dave, @HTupolev is 100% correct.
Ride them a second time and segments will then be PR's if you are faster.
I got a PR on Hulseytown by the way
-Tim-
-Tim-
-Tim-
-Tim-
Quoted: 1020 Post(s)
Liked 463 Times
BTW, I had the same question and was not able to find the answer in Strava.
So go figure.
Likes For eja_ bottecchia:
Bikes: Trek Domane 4.3
Quoted: 193 Post(s)
Liked 50 Times
It spawned a thread on the Strava support board where one of the more interesting suggestions was a "first time" badge/achievement for a new (to you) segment so that you would see an indicator for at least that.
https://support.strava.com/hc/en-us/...-first-attempt
https://support.strava.com/hc/en-us/...ting-a-segment
Bikes: yes
Quoted: 1281 Post(s)
Liked 643 Times
I think a few years ago Strava changed this so that your first time on a segment became a PR. Complaints were many, because users thought it a bit silly to have every segment be a PR when one was biking in a new area/route. Strava rolled back to the previous and current approach - achievements only for the second and after ride.
I think there was a lot of kvetching about that, too. They haven't done it since.
Quoted: 193 Post(s)
Liked 50 Times
(Although personally I think the year's best should be the last 365 days on a rolling basis.)
Likes For TimothyH:
Quoted: 142 Post(s)
Liked 73 Times
If one is unable to find the answer in the Strava Q&A database or one doesn't want to search then just ask Strava support.
https://support.strava.com/hc/en-us/...trava-Support-
Bikes: bikes
Quoted: 2622 Post(s)
Liked 1,429 Times
So glad they did away with that awful idea. As winter progressed to spring and people started riding harder every single ride would be peppered with the dumb things. Absolutely no point to it.
Quoted: 142 Post(s)
Liked 73 Times
Here is a specific direct answer from Strava regarding the issue and question raised by OP.
Bonsai171, good luck, and success on getting lots of PRs in the future while enjoying fun and safe rides.
That is just down right silly. for me the only meaningful PRs are those for long climbs, or long out and back routes. I like the ones for segments created for TTs also.
don't try this at home.
Quoted: 973 Post(s)
Liked 511 Times
After a ride, I saw I had a new PR! Yeah!
Oh, it was the local pedestrian bridge, it's usually busy, so cyclists go slow. PR -- 8 mph!! Woah! thanks, Strava!
I like riding new routes, and do it quite often. I don't want to see a PR for all those new segments.
Quoted: 941 Post(s)
Liked 319 Times
On a decent return ride segment from Dexter to Ann Arbor I was looking at Strava and found I was number, Er, not sure, but in the hundreds. After filtering for my weight, got down to under 100. Then filtered for my age.. Bingo, #1 .
