Very disappointed with Campy Centaur
Fortunatissimo
That's putting it kindly. I like the smooth shifting and great looks of the Centaur gruppo. However, after only about 7,000 miles, the bottom bracket is sounding its death rattle. I'll change it when the noise becomes unbearable. Back in early October, I had to overhaul the right ergolever and change the "g-springs" (a mere $9 each). This stuff is too delicate for what it costs.
Stop it.
Bikes: 2003 Specialized Hardrock Pro w/ slicks, flipped stem and HB, 2003 Colnago Dream with full Dura-Ace 7700 double, 2001 Bianchi XL Boron/Daytona, Mavic Open Pro/Campy Centaur/DT Champion built wheels.
Eh?
Cat None
Bikes: LOOK KG 461, LeMond Zurich, Giant Talon 29er 0
Originally Posted by 56/12 and 22/28
Shoulda bought Record...
Eh?
Eh?
Prefers Aluminum
Bikes: Wife: Trek 5200, C'dale Rush Feminine, Vitus 979 Me: Felt S25, Cervelo Soloist, C'dale Killer V500, Miyata Pro (fixie)
Shoulda bought Shimano...
Eh?
Eh?
Stop it.
Originally Posted by SDRider
Record costs twice what Centaur costs though. That's a lot of bottom brackets and shifter rebuilds.
Remember, I'm OCP.
Eh?
Stop it.
Eh?
Eh?
Eh? (That's the spirit!)
Faith-Vigilance-Service
Bikes: Trinity, Paradisus, Centurion, Mongoose, Trek
Only 7000 miles?
Oh man. Bummer.
Oh man. Bummer.
President, OCP
--"Will you have some tea... at the theatre with me?"--
President, OCP
CAT6 UTP 568B
Bikes: 2005 Allez Elite
7000 miles on one square taper bottom bracket? That's more than double the average lifespan of a Shimano square taper BB... ask any LBS mechanic.
Bikes: Colnago Altain, Klein Pulse II, Stumpjumper FSR, GT Zaskar LE, Pedalforce RS2
No one should be disappointed with 7000 mile service life. Regardless of manufacturer or component level group.
For theoretical arguement, assume you do 20mph at 90rpms cadence, that's close 350 hours or 21000 minutes to accomplish 7000 miles. If my calculations are right, that's close to 2 million revolutions on that bottom bracket before replacement.
Go buy a replacement and consider yourself fortunate to be able to ride that much.
CAT6 UTP 568B
Originally Posted by sydney
The Centaur and lower campy BB aren't noted for long life, but they are cheap.
Quoted: 1572 Post(s)
Liked 642 Times
Unique Vintage Steel
Just bought 2 shimano BB's
UN73 - $14
UN53 - $12
Figure at 1500-2000 miles a season across both bikes, if I get 5000 miles out of them they'll last me till I've long forgotten how much I spent on either one.
UN73 - $14
UN53 - $12
Красный Октябрь
Bikes: Kona Major Jake - CX/Gravel Kona Jake The Snake - Commuter, Pinarello Galileo - RoadieAF, Niner Air 9 - HT MTB.
Loser
All posts are crafted by an adult, for adults. Not responsible for hurt feelings. Get in touch with your true self.
My experiences with Campagnolo brackets (both my own and working of friends bikes) are negative. They are crap. I've owned or worked on perhaps 5 or six different ones, inc Record. The only positive thing I could say about them is that they look nice. Campagnolo make some nice equipment but you can't include their BB's in that category. I also have two mates who own bike shops - ones a big Campagnolo fan and the other isn't, but both of them despise Campagnolo BB's.
Apparently Centaur was upgraded this year - hopefully better than the old model.
My experiences with Shimano square taper BBs are mostly positive.
Quoted: 128 Post(s)
Liked 12 Times
My experiences: Shimano UN-53 bottom bracket, I've put 7500 miles on it with 180mm cranks in a stiff aluminum frame, so the spindle is bearing lots of load, and it turns perfectly smoothly when I overhauled the thing this summer.
My brother rode his Campy Mirage drivetrain into the ground - around 10,000 miles without changing the chain. You've never seen such worn cogs and chainrings! (Really, it's incredible). However, his bottom bracket - a square-taper Mirage, at that - was perfectly smooth after 15,000 miles when I removed it from his bike and replaced with a Shimano (b/c I replaced his whole crank, which was lots cheaper than buying three new Campy chainrings).
Just two data points, but it's something.
That's nonsense too.... The Centaur and lower campy BB aren't noted for long life, but they are cheap.
Bang for buck, Campy mid grade is impossible to beat.
7K miles on a hard ridden and inexpensive BB is OK...I might get less on my Veloce BB...still perfect at 4K...but if I get 7K...good enough..new Veloce BB is 20 bones on e-bay.
George
Bikes: Eddy Merckx Corsa Extra, Basso Loto, Pinarello Stelvio, Redline Cyclocross
Quoted: 336 Post(s)
Eh?
Eh?
Bottom Brackets don't fail for no reason. The new sealed BB's are very difficult to misuse and if his is making noise I'd firstly suspect that it was loose from insufficient installation torque. I remember that Cannondale used to have a lot of problems with noisey BB's because they would loosen up in the aluminum shell.
Either the poster had really bad luck or he's pretty hard on equipment.
Bikes: 2001 Look KG 241, 1989 Specialized Stump Jumper Comp, 1986 Gatane Performanc
I just replaced the 'G' springs in my right hand Veloce ERGO lever this morning. Took about an hour including getting the lever off the bike. $13 in parts. Shifts like new!
I usa a Record crank (180mm) with Chorus BB with over 2 years (14-16,000 miles) of service. It is as smoth as the day I put it in. Now I do snap one chain ring bolt (the reversed one that screws into the spider) every year or so.
7000 miles on that BB aint to shabby.
Bikes: Colnago Master XL, Bianchi Via Nirone 7, Marinoni Fango
My Veloce BB started making noise after 800 KM. took it out cleaned it, torqued it and it's been fine ever since. Things wear out allot quicker when there not maintained and especially when you ignore noises.
