difference between truing stands
I'd like to try my hand at wheelbuilding. I figure a truing stand would be a good investment even if I don't get too obsessed with wheels.
On ebay, I note the bike-shop quality stands cost circa $180 shipped. There are some folding ones and no name stands as well for much less. I checked on Sheldon Brown/ Harris and I would like something a step above the flimsy stands. I want a stand that works well so I don't get discouraged early on.
Any recommendations? PM me if you have an old one that you'd like to sell or have recently upgraded.
Bikes: Giant TCR Comps, Cdale R5000, Klein Q-Pro, Litespeed Siena, Piasano 105, Redline Conquest Pro, Voodoo Bizango, Fuji Aloha
I've got a cheapie minura/spin doctor that works great. Sure, maybe not for everyday shop use, but builds a perfectly acceptable wheel.
Quoted: 1572 Post(s)
Liked 643 Times
The big selling feature for the more expensive stands is the self centering feature that lets you check the dish while you're doing side-to-side trueing. I've found that feature to be unreliable on every stand that I've ever used.
wow, not the heaping praise I expected for the high-end stuff. I need to go find myself a big workbench, a vice, and a fork.
Over the hill
Quoted: 998 Post(s)
Liked 1,206 Times
Liked 7 Times
Liked 7 Times
Originally Posted by urbanknight
I used to get my wheels so in true you would hear a ping every time the seem went by!
Mad bike riding scientist
Quoted: 6219 Post(s)
Liked 4,218 Times
I've owned something like the Spin Doctor and it gets the job done. It's not fancy and it is cheap. If you are building a few wheels over several years, it's lack of bells and wistles won't do any harm.
If you like tools, however, and like them to be rugged and well made, go for the TS2. I've used mine for several years. It's easier to clamp the wheel in the stand than other truing stands, it adjust for front hubs and the widest rear hub. Like any precision tool, it does need care and occasional alignment. The centering mechanism works just fine if you take the time to align the stand (yet another tool ). I still check all of my wheels with a dishing gauge but they are close enough that I don't have to really worry about them.
And, unlike the cheaper ones, if you happen to drop it from a wall bracket...twice...7 feet to the concrete garage floor, you can pick it up and just go right on making wheels like nothing ever happened
Stuart Black
Stuart Black
I'm assuming the TS-2 does the dishing without having you flip the wheel. The TS-8 looks similar and costs about half what the TS-2 does. Anyone have a TS-8? Does it auto-dish, so to speak?
If I get a nice stand, I could skip out on the extra clutter of having a dish tool.
Non Tribuo Anus Rodentum and off to the next adventure (RIP)
Originally Posted by cyccommute
The fork will work just fine as long as you only want to build front wheels. I'd hate to have to try and muscle a 135mm hub into a 100mm fork Sounds like a 2, or even 3, person job to me.
Not at all, just spread those fork legs open and drop the hub right in.
Liked 4,218 Times
No, the TS8 doesn't autocenter like the TS-2. As with most stands, you can get close to the proper dish by flipping the wheel in the stand (without moving the gauges). You just go back and forth until you are satisfied.
Stuart Black
Stuart Black
Quoted: 2026 Post(s)
Liked 1,096 Times
A relatively inexpensive truing stand like the Park lower-line, Minoura or Performance's house brand will work fine for almost any home wheel builder. You will need a dishing tool and, a tension tool is a good investment unless you are sure you can tell "by ear" when the spokes are at the correct tension.
I've built several wheels with the crude truing stand that came with my Ultimate work stand along with a Park dishing tool and they have come out true and round and properly dished. I wouldn't use it for routine wheel building but it's adequate for the few uses it gets.
Over the hill
Quoted: 998 Post(s)
Liked 1,206 Times
What does this mean?
Over the hill
Quoted: 998 Post(s)
Liked 1,206 Times
To the OP, the TS-2 is indeed very nice to have, but had I not been given it for free I might have gone with something less expensive. It depends on how many wheels you want to build. I ended up building and truing tons of wheels for family and teammates, so it was nice to have. I also became Team Redlands' best friend after the poor pavement in stage 3 of the Tour of the Future
Liked 7 Times
[QUOTE=MistaMuShu]I'm assuming the TS-2 does the dishing without having you flip the wheel. QUOTE]
Not really. If you center the caliper arm for a 130mm rear wheel it will do a pretty good job of centering other 130mm spaced wheel. Where it has issues is when you adjust the span to fit a front wheel. It will probably not be centered. I keep my TS2 centered for rear wheels. For front wheels I set all spokes at the same tension and then confirm dish by flipping the wheel on the stand.
Al
Al
In my experience, the TS2 did not have the self-centering feature adequately aligned as received. After alignment with a home made tool, it seems to stay aligned. Haven't got a decade of use out of it, but so far, it works fine. You would think that Park would assemble it and align it but naaahhhh
fanatik
Quoted: 12 Post(s)
One that hasn't been mentioned in this thread is Ultimate's one-armed bandit, which I favor because of its simplicity, portability and inconspicuousness.
I owned the Minoura (Performance Spin Doctor) for a number of years. Despite its flex, I turned out a number of solid wheels on it, proving that it's all about the builder, not the stand.
I "upgraded" for a very short time to the Park TS-2. I was disappointed that the self centering was, in fact, not. Despite its incredible heavy duty build, I felt my dollar would be better spent elsewhere.
I then picked up the Ultimate. I find the one-armed design very freeing, providing open access to one entire side of the wheel. Yes, I have to use the flip flop method (or a dishing guage), and the QR skewer must be tensioned each time the wheel is repositioned.
But for that minor inconvenience, I get a stand that accepts my big 29" wheels with the tires still mounted, I get a portable design that comes with a weighted base, and it's pretty compact to store unobtrusively on a shelf since I don't have a dedicated workshop in which to keep it.
Aluminium Crusader :-)
i have a cheap, foldable stand, and while it definitely does the job, it's bit annoying that it flexes, and lets the wheel flex, just when I don't want it to. I can't barely touch the wheel without the whole thing flexing just enough to be a nuisance.
I actually had the opposite experience. Someone gave me a Park professional truing stand 10 years ago and it has been a dream to work with. You don't have to flip thye wheel to do the other side like the really cheap models, and every wheel came out dished properly, save for one which I found wasn't in the truing stand's fork all the way when I was truing it. I used to get my wheels so in true you would hear a ping every time the seem went by! That doesn't happen so much now with machined braking surfaces, but it was a source of pride back then.
Over the hill
Quoted: 998 Post(s)
Liked 1,206 Times
Originally Posted by Mothra
And don't drop the truing-stand, it weighs a hefty amount. You end up dropping it onto one of the adjustment knobs and bending it, leading to non-linear movements.
To infinity and beyond
Bikes: Cannondale M600, Crescent 92318, Bianchi Lo Spillone (tandem)
+1 for the TS-2, but you could do with a much cheaper stand if you're not planning on building many wheels or if you're not a tool fetichist You will need a dishing tool though.
Jonnys ilegitimate Father
Bikes: too many too list
I build about 200 wheels a year using an older Park TS-6 truing stand. I personally don't like any of the "self-centering" stands. They are o.k. for front wheels...again as long as the centering adjustment is spot on...but for rears it can be benificial to be able to separate dishing and lateral adjustment. When building a rear wheel I always start with a slightly tensioned, perfectly true lateral and radial rim. Once you have everything straight and round you can add tension. I have for years (and Gerd recommends it in his book) done all the drive side tension first and then used non-drive tension to bring the wheel into dish. With the self centering stands this is not really possible as the truing probe will always be far closer on one side. I will take my 12 year old adjustable Park stand over any of the self centering ones. My next stand will be the nuclear bomb proof Hozan model.
