Wolftooth Roadlink experiences?
Old 03-05-16, 04:24 PM
KonaRider125
Bikes: Niner RLT 9 4 Star, Kona Splice, Nashbar Carbon road bike
Quoted: 47 Post(s)
Does anyone here have a Wolftooth Roadlink on their gravel bike? How is the shifting and does it create any extra chain noise?
RoadLink ? wolftoothcomponents.com
Thanks, interested in putting this on a gravel bike so I can run a 46/34 crank and Shimano 11-40.
KonaRider125 is offline
Old 03-17-16, 07:12 PM
natemeister
Got it earlier this week and finally found time to put it on, along with a 11-40 rear derailleur. Had to readjust my rear derailleur a little bit but it shifted smoothly afterwards. I'm dying to get out on the trails now. I have 50-34 in the front, so 46-34 should work just fine.
File Type: jpg
natemeister is offline
Old 03-17-16, 11:04 PM
KonaRider125
Quoted: 47 Post(s)
Awesome, thanks for sharing your experience. Please let us know how it works out on the first ride.
Old 03-18-16, 06:22 AM
dr_lha
Bikes: 2016 Black Mountain Cycles Monster Cross v5, 2015 Ritchey Road Logic, 1998 Specialized Rockhopper, 2017 Raleigh Grand Prix
Quoted: 360 Post(s)
I'm curious to see how this works for you, because you're way over capacity with that set up aren't you? I'm assuming from your picture you've got a RD-6800-GS, which has a 37T capacity, and (50-34) + (40-11) = 45T. Shimano capacities are conservative, but still.
dr_lha is offline
Old 03-18-16, 08:45 AM
natemeister
Me too. So far, I took it out to a parking lot to clear up the shifting and was able to smoothly access 34 (front) and the entire range in the rear (40-11). With large in the front (50), I could only access 11-35, it wouldn't go up to 40 unless I was in the small ring. So unless I am severely cross-chaining (50-40), it shifted just fine. I biked 10 miles in today to work with this new set up and no hiccups
Old 03-18-16, 09:05 AM
dr_lha
Quoted: 360 Post(s)
Yep, that's about what I'd expect. How did you determine the size of your chain? Usually it'd be based on the two largest gears, but that would give you a lot of slop when in a small/small configuration.
dr_lha is offline
Old 03-18-16, 09:12 AM
Shimagnolo
Shimagnolo's Avatar
Quoted: 1742 Post(s)
Liked 239 Times in 167 Posts
Interesting device.
I might try it some time.
BTW on the chain wrap issue: The chain does *not* need to be tight on the small/small combo. In fact, I've seen issues where a chain would try to crawl off the side of the lower pulley in the big/big combo because the pulley was pulled so far forward that it was no longer in the plane of the chain. Think about it; when the lower arm of the RD swings forward in a cross-chaining situation, it is staying in the plane of the currently-engaged cog, which moves it away from the plane of the chain as it swings forward.
The solution is to just make the chain long enough that there is slack in the small/small combo. There is absolutely no problem with this; All the gears will work just fine. I have 2 bikes set up they way.
Shimagnolo is offline
Old 03-18-16, 09:16 AM
natemeister
I physically aligned it using the larger rings of both. I purchased a 118L chain and took one off. There is only slight rubbing at 34 (front) - 40 (rear). I have an extra chain now, so maybe try 116L and see if it fits.
Old 04-10-16, 07:32 PM
GodinSession
Quoted: 21 Post(s)
I just ordered a roadlink also. I have a 105 11speed setup with a 50/34 compact crank. I ordered a sram pg1170 11-36 cassette to give me a better grany gear. I expect it to work great! I will report back later this week once i get it installed and have a ride on it.
GodinSession is offline
Old 04-10-16, 10:21 PM
natemeister
Should work fine. Been riding 50/34 with 11/32 and 11/40 in the rear, no problems at all. Love the flexibility and for trail riding and commuting.
Old 04-15-16, 03:29 PM
Chris Pringle
Chris Pringle's Avatar
Bikes: '12 Rodriguez UTB Custom, '83 Miyata 610, '83 Nishiki Century Mixte (Work of Art), '06 Specialized Epic Marathon MTB
Quoted: 20 Post(s)
Question to those with more technical experience with this product, do you think it will work with the new Sram eTap derailleur. That derailleur is advertised to be used with a 28t max cassette. Should I buy the groupset, I would like to use a larger cassette (e.g., 36t) for gravel-riding and light touring.
Chris Pringle is offline
Old 06-06-17, 08:14 AM
Hisamatsu
Quoted: 107 Post(s)
How long is your chain? I sized my new KMC-X11SL chain and only had to remove 2 links on a 46/36 + 11-40. It was pretty tight on big-big. If I did 50/34 not sure I'd have enough chain length.
Hisamatsu is offline
Old 06-06-17, 09:04 AM
Jarrett2
Jarrett2's Avatar
Bikes: Steel 1x's
Quoted: 631 Post(s)
A friend of mine had one installed (unknown to her) by a LBS to accommodate a larger cassette on her 1x setup. It started dropping chains immediately.
I replaced her DR and that thing with a SRAM Apex1 DR and all good since.
Jarrett2 is offline
Old 06-06-17, 09:08 AM
shoota
shoota's Avatar
Quoted: 1164 Post(s)
Liked 96 Times in 74 Posts
Clutch type derailleur ftw
2015 Cannondale SuperX Hi-Mod
shoota is offline
Old 06-06-17, 03:11 PM
motorthings
Quoted: 49 Post(s)
i thought the wifli version of the etap rear der was out soon or already...which should get you to 32
motorthings is offline
Old 06-06-17, 05:38 PM
TimothyH
- Soli Deo Gloria -
Quoted: 6823 Post(s)
Liked 655 Times in 412 Posts
My guess is that the Wolf Tooth wasn't the problem.
Many, many people ride them every day without issues including some very hardcore gravel racers.
-Tim-
TimothyH is offline
Old 06-06-17, 07:28 PM
Jarrett2
Jarrett2's Avatar
Bikes: Steel 1x's
Quoted: 631 Post(s)
-Tim-
It was part of the problem for sure. The real issue was the guy choosing the combination of components.
Jarrett2 is offline
Old 06-06-17, 08:50 PM
TimothyH
- Soli Deo Gloria -
I'm interested to hear more about how the Wolf Tooth caused the chain to drop.
Not trying to challenge but sincerely asking because I almost went with one but didn't need it in the end. A Wolf Tooth is not out of the question for me in the future.
Can you elaborate?
-Tim-
TimothyH is offline
Old 06-06-17, 09:03 PM
mstateglfr
Sunshine
mstateglfr's Avatar
Bikes: '18 class built steel roadbike, '19 Fairlight Secan, '87 Schwinn Prelude, Black Mountain Cycles Monstercross V4, '89 Novara Trionfo, '18 Diamondback Syncr
Quoted: 3593 Post(s)
Liked 528 Times in 367 Posts
It just lowers the derailleur by a couple cm...was the hanger bent on the frame or something? It basically makes thw setup a long cage for a larget tooth difference...not sure how that makes a chain jump?
mstateglfr is offline
Old 06-07-17, 06:52 AM
Jarrett2
Jarrett2's Avatar
Bikes: Steel 1x's
Quoted: 631 Post(s)
Can you elaborate?
The guy at her (previous) LBS threw together a bunch of shop bin parts and tried to pass it off as a true 1x setup. First he had her on a Shimano 9 speed MTB DR, then tried to put her on an old SRAM Apex DR with this extender. None of them were meant to work together in a 1x configuration and they didn't. Both configs dropped chains for her repeatedly, to the point that she was ready to stop riding altogether. The sad part is he talked her into moving from a fully functional 2x groupset to this mess.
If you've had any experience with 1x stuff, you probably know that a reliable 1x setup is typically built around purpose specific components. I only got involved because he stopped helping her. Once I dumped that stuff and got her a true 1x DR, her problems ended and she's happily riding again. After wasting hundreds of dollars with his shop bin BS, the fix was a $65 1x specific DR.
Maybe this extender works great in 2x setups, but trying to make a short cage road DR work reliably in a 1x config with it did not for her. She has all the parts that didn't work on her bike in a box somewhere, I'm sure she would sell you hers if you want it
Jarrett2 is offline
Old 06-07-17, 07:47 AM
TimothyH
- Soli Deo Gloria -
Thanks for the explanation.
Based on what you wrote however, I still don't see how the Wolf Tooth was the root or exclusive cause of the dropped chain.
-Tim-
TimothyH is offline
Old 06-07-17, 08:00 AM
redlude97
Quoted: 1897 Post(s)
Liked 156 Times in 111 Posts
all that could have been fixed with a $20 chain guide or $5 FD
redlude97 is offline
Old 06-07-17, 08:05 AM
Jarrett2
Jarrett2's Avatar
Bikes: Steel 1x's
Quoted: 631 Post(s)
She wanted it done right.
Jarrett2 is offline
Old 06-07-17, 08:09 AM
mstateglfr
Sunshine
mstateglfr's Avatar
Ok, so this may sound like arguing, it really isnt. I am just curious how the piece of machined aluminum caused all this when the company advertises it for 1x setups and I have seen a few 1x setups using the Roadlink(they werent in use, but itd be dumb to have it if it didnt work).
- So the woman's bike had a 9sp Shimano RD which means Shimano shifting too. That didnt work.
- SRAM Apex 10sp was then installed, so presumably a SRAM shifter too since they need to be mated together. That didnt work.
- So then a SRAM Apex1 11sp was installed. This required yet another new shifter. And now it works.
Am I understanding all this?
1- Why arent shifters swaps included in all this hassle and cost talk?...or have the shifters not changed somehow as brand and speeds changed?
2- Was the crankset a 1x specific with a 1x ring?
3- Was a $25 chainguide ever used? Wouldnt that have solved everything?
4- After all this, I havent seen anything specific to the Wolftooth. Again- they make this product in part so people can run 1x with road derailleurs.
Your friend's issues had to have been frustrating. Why someone went to 1x when their 2x worked perfectly is...odd, but hey- variety is the spice of life, i guess.
Why a derailleur extender on a cobbled together 1x setup without a simple chainguide or 1x crankset is being blamed for chain dropping is...odd.
Yeah, all that got argumentative. It really isnt, its just sarcastic and unbelieving. I know, i know, you were there and I(we) werent. And now that the Roadlink is gone, it all works properly. That doesnt mean the Roadlink was the issue.
I wouldnt do a gravel 1x setup as its too limiting for how and where I ride, but if I were to build one, it would be with proper components to ensure the chain doesnt drop. A 1x chainring and a chainguide. I wouldnt have to then change my derailleur and shifter twice.
Old 06-07-17, 08:17 AM
redlude97
How is a chain guide not a correct solution? Plenty of pros use them. Shimano still doesn;t have a proper clutch RD yet plenty run them without chain drops. There are alot of solutions that don't involved a new RD
