110BCD 32t small chain ring?
Quoted: 75 Post(s)
When looking through specifications I've noticed some bikes(Specialized Diverge, Sequoia) that have 110BCD cranksets with a 32t small ring. I haven't seen them and am wondering how they're managing to squeeze a chain ring that small on there.
Quoted: 75 Post(s)
Guess I haven't been keeping up with the current stuff. FSA lists a 110BCD crankset with even a 30t small ring.
FSA Omega MegaExo - Full Speed Ahead
Quoted: 9 Post(s)
Praxis is offering a 48/32 Micro Compact as well. I was wondering the same thing. If a 34 or certain 33 tooth chain rings are the minimum, how is a 32 or 30 fitting? Is the BCD similar to the Sugino Compact plus with 110/74 BCD with the rings mounted on the inside?
Quoted: 9 Post(s)
Thanks, that makes more sense. The Praxis website doesn't show the Alba or Zayante with a four bolt as of now. I'll probably still get a Sugino as it offers more options with the extra 74mm BCD for the inner ring.
Quoted: 18376 Post(s)
Liked 4,511 Times
Pulling the teeth closer to 4 bolts by relying on a tooth count being a multiple of 4 doesn't work for 30T.
Gotta love the 'simplicity' of double cranks and now the proliferation of new BCDs and crank styles to overcome the inherent limitations of only having two chainrings, while still not addressing the lack of range. Triples FTW, as always
Liked 4,511 Times
So, not really 110 BCD?
Quoted: 9 Post(s)
I'll probably get one of the 46/30 options when they are available for my Volagi Liscio. A bucket list item I really want to do is the Mauna Kea climb from beach to summit. I did Haleakala back in 2012 with a triple and low of 30x27. Mauna Kea is 3000 more feet though and has the horribly steep dirt section as well.
Bikes: Niner RLT 9 4 Star, Kona Splice, Nashbar Carbon road bike
Quoted: 49 Post(s)
Wick works makes a 41/33 chainring set available for most common crank options including 110 Bcd.
https://wickwerks.com/products/cyclo...41-33-110-bcd/
Quoted: 9 Post(s)
Depending on your location and how much climbing you do, a 48/32 or 46/30 can be more efficient than a 50/34 with regards to terrain and how many rollers there are and staying in the big ring. If you are fast and strong than it's all a moot point, but I'm sure most of the people taking the time to read this thread are more interested in the advantages of lower gearing.
The Infractionator
Bikes: Classic road bikes: 1986 Cannondale, 1978 Trek
Quoted: 875 Post(s)
Originally Posted by redlude97
Its 4 hole, you can move the teeth a hair closer to the bolts compared to 5 bolt configurations
As for your other question, 39/53 most of the time.
Likes For PepeM:
Liked 4,511 Times
I wonder if some 110 cranks also need a slight modification to get the 33T rings to work. And if 32's are available, they would also likely need the spider to be carved up a bit.
Oh, it looks like Sheldon Brown also sells the 33T rings as singles.
110 mm BCD Mountain and Compact Road Bicycle Chainrings (Chainwheels) from Harris Cyclery
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
33T was always possible for 110 BCD cranks, it's just not common.
For the smallest chainring sizes, it sounds like FSA has been developing rings where the bolts go *through* some of the teeth: TPE16: FSA gets Modular with new cranks for MTB, Gravel, and Road, plus steel Comet 1x chainrings - Bikerumor
I'm skeptical of 30T on a 110 BCD, though. I wonder if they use a smaller BCD for the 46/30 combo, and neglected to mention that on their page.
Check the link I posted to their adventure crankset. If offers a 30T inner ring and uses a 90mm BCD. Either FSA neglected to mention the smaller BCD or they don't really offer those rings on that crank. It is geometrically impossible to do a 110mm BCD 30T ring. Even aligning the bolt holes with the teeth (using 5 bolts) doesn't create enough space to make it work, unless they are using tiny bolts.
Occam's Rotor
Quoted: 2366 Post(s)
Liked 2,331 Times
In the case of a 46/30T, you only lose one gear at the top vs. a 50/34T. (50/12 = 46/11 ± 0.01).
cf: https://www.bikeforums.net/fifty-plus...road-bike.html
Quoted: 509 Post(s)
Liked 9 Times
There's always this option: https://www.compasscycle.com/shop/co...-double-crank/
Get as small as you need.
Quoted: 550 Post(s)
Liked 325 Times
This ignores the fact that pros are too big to compete at 7% body fat, while 74% of American adult men are over-weight and 36% obese.
A 5'9" guy like Alberto Contador who races at 137 pounds is considered overweight at 169, and obese at 203.
Riding a 15 pound bike at the UCI minimum weight with 4 pounds of water/shoes/gear makes combined weights of 156 pounds when racing-fit, 188 over-weight, and 222 pounds obese; calling for 21% and 42% increases in gearing to maintain the same cadence.
Climbing a moderate 8% mountain like l'Alpe d'Huez where pros use 39x23, at half the power 5'9" guys who look like POW survivors should be riding gears like 30x36, the barely over-weight 26x36, and obese 22x36.
Those of us with 10% grades should use 20% smaller granny rings when going all-out.
Obviously things like all day endurance rides in the mountains and loaded touring call for even lower gears.
Quoted: 550 Post(s)
Liked 325 Times
But but but... you can't buy a road bike with those gears so that can't be right
