Long Distance Competition/Ultracycling, Randonneuring and Endurance Cycling Do you enjoy centuries, double centuries, brevets, randonnees, and 24-hour time trials? Share ride reports, and exchange training, equipment, and nutrition information specific to long distance cycling. This isn't for tours, this is for endurance events cycling
Everesting on a single speed?
Old 05-11-20, 10:50 AM
cormacf
Bikes: 2017 Lynskey Sportive Disc, 2021 Lynskey Pro29, 1977 Schwinn Super LeTour 12.2
Quoted: 118 Post(s)
Liked 70 Times in 29 Posts
I had a probably very dumb thought--if you could find a really, really consistent hill for an Everest (e.g., let's just go with a steady 4% with no more than 1% variance in either direction), shouldn't a SS bike be a pretty good candidate?
Potential advantages:
  • Shave a couple of pounds of weight
  • Being able to sound like a badass when you tell people the story some day
  • OK, well, that was really it.
Potential disadvantages:
  • You get tired and can't finish without a cog swap.
  • Settling on a lowest common denominator gear means you have to spin like a maniac and it still takes forever
  • "Everests are hard enough, so stop being an idiot."
I WANT to believe I could find a gear that would give me the desired average speed at about 90 rpm, allowing me to dial it up or down and still get there, but I'm probably wrong, and it would really only be for the story.
Thoughts?
cormacf is offline
Old 05-11-20, 11:32 AM
rhm
multimodal commuter
rhm's Avatar
Quoted: 1908 Post(s)
Liked 574 Times in 339 Posts
As long as it doesn't get so steep that you have to get off and walk, I would not worry about a little variance in slope. That variance will give you a chance to change your cadence now and then, which I find helpful on long rides. Obviously you don't want to spin like a maniac for long stretches, but spinning like a maniac every now and then is not such a bad thing. I did a very flat 200k on fixed gear last year, and the constant cadence got to be a real pain in the ass. Now and then I needed to get out of the saddle for a while, and the only way I could do that was by going slow, holding the brakes. That was my only complaint, though, and I don't think you'd have that problem.
So the plan would be to spin up the hill averaging 90 rpm or so, coast back down, and repeat repeat repeat? I would have a hard time working up the enthusiasm for that, regardless of the bike, but if you don't have that problem, I think you'd be good to go.
www.rhmsaddles.com.
rhm is offline
Old 05-11-20, 11:52 AM
clasher
clasher's Avatar
Quoted: 229 Post(s)
Liked 148 Times in 103 Posts
A 4% slope would make for a long ride to get to everest elevation... like 400km I'd guess... There's an everesting calculator out there you can plug strava segments into and it'll tell you how long the ride will take and all that jazz, fun to play around with.
I think my carbon roadie is lighter than any of the single speed bikes I have. Probably better to just make a 1x hill-climb bike with a really light corncob cassette on the back and a smaller chainring. Could just run one brake up front and use downtube shifters if one were building a specific bike for everesting I'd go with something like that in theory. Run a superlight tubular wheelset too and all that other weight weenie kind of stuff.
clasher is offline
Likes For clasher:
Old 05-11-20, 12:52 PM
cormacf
Quoted: 118 Post(s)
Yeah. My coworker did his on a 4% average, but that was a double everest, so I'm sure he chose it because he knew he'd have to pull almost 60k in elevation and wanted to have something left.
cormacf is offline
Old 05-11-20, 01:44 PM
79pmooney
79pmooney's Avatar
Quoted: 4806 Post(s)
Liked 3,928 Times in 2,553 Posts
I ran a 28 X 13-21 when I climbed Mt Washington. Except for the flat 1/2 mile to the base from the start at the tollgate, perfect. I've done a bunch of lesser but still long climbs on fix gears. Up Mt Ashland and up Dead Indian Memorial Highway on a 42-23. Mt Diablo many years ago on a 42-17 back when I never changed gears. Now, except for Mt Washington, none of these were races or recorded but several were parts of epic days.
A lot of this is mindset. Being comfortable out of the saddle counts for a lot. Now, 90 RPM sounds like a lot to me. I'd be thinking closer to 70. But then, I've never been a spinner uphill. IF I geared that way, I'd just slow down.
Ben
79pmooney is offline
Likes For 79pmooney:
Old 05-11-20, 02:26 PM
unterhausen
Randomhead
Liked 3,696 Times in 2,517 Posts
This question reminded me of when Paul Rozelle climbed Venteux 3 1/2 times on a fixed gear. But that was "only" 16000 feet. Paul Rozelle?s 24-hour, pre-PBP, fixed-gear, Mont Ventoux ride | The Bicycle Story
unterhausen is offline
Old 05-11-20, 02:44 PM
MetinUz
Quoted: 34 Post(s)
Liked 8 Times in 7 Posts
Most climbs I would consider an Everest attempt have tricky descents, so not a good place for superlight tubular wheelset and only a front brake, especially when you're fatigued from hours and hours of climbing. The only place I might consider it would be Monitor or Carson Pass in the Sierra Nevada, with smooth pavement, gentle curves and good sight lines.
MetinUz is offline
Old 05-11-20, 06:43 PM
clasher
clasher's Avatar
Quoted: 229 Post(s)
Yeah, totally depends on the local topography. Around here I have no large climbs to do everesting, the biggest hills anywhere close to here are 30m or 40m perhaps. There's been a few riders that have done it on the short steep hills we have. I was looking at one hill I like to ride and it'd be a 197 laps of it to everest. I probably wouldn't bother trying it with my theoretical setup since I don't have fancy light wheels and I like having two brakes too.
clasher is offline
Old 05-14-20, 09:48 AM
adamrice
mosquito rancher
adamrice's Avatar
Bikes: Bob Jackson 853 Arrowhead; Felt VR30; Kinesis UK RTD; Hujsak tandem
Quoted: 206 Post(s)
Liked 181 Times in 133 Posts
I just ran across this today: Everesting on a fixie with a hormone headwind.
Adam Rice
adamrice is offline
Old 07-10-20, 06:59 PM
woodcraft
woodcraft's Avatar
Quoted: 1814 Post(s)
Liked 923 Times in 569 Posts
I remember seeing a youtube video of a guy doing that (fixed gear)- maybe in London.
He went up a modest urban hill all night and more, coasting down w/ feet off the pedals.
woodcraft is offline
Old 07-10-20, 07:11 PM
woodcraft
woodcraft's Avatar
197 laps- that's not many.
Old 07-11-20, 11:05 AM
clasher
clasher's Avatar
Quoted: 229 Post(s)
Originally Posted by woodcraft
lol that's a lot of repeats! The one I had in mind has bad elevation on the strava segment, ~20m instead of 45m so I'd be over 400 for sure. I think I'd just drive to a slightly longer hill and do less repeats, dunno if I ever will try it or not.
clasher is offline
Old 07-12-20, 12:29 PM
woodcraft
woodcraft's Avatar
I've mapped out routes with 12 laps (2,443'), 20 laps (1,480), and 33 laps(875).
I've done close to 20k on a DC, but only 10k strictly laps- don't know if I'll ever do it either, & certainly not on single speed.
Old 07-12-20, 12:38 PM
DrIsotope
Non omnino gravis
DrIsotope's Avatar
Quoted: 4905 Post(s)
Liked 1,731 Times in 958 Posts
Laps don't count. The ascent and descent must be the same road/path/trail/whatever. So in order to count, it's hill repeats. The grade needs to be steep-- the nutters really going after it are only looking at +12% average-- unless you want to spend 24 hours grinding it out.
A hill like the one Contador used would be fine on a SS, you'd just have to find the gear ratio you could comfortably climb it on, then just coast down. His hill was under 1km long, and he repeated it less than 80 times, IIRC.
DrIsotope is offline
Old 07-13-20, 11:32 AM
woodcraft
woodcraft's Avatar
If that was referring to my post, the laps are up & down the same climb.
It doesn't seem like the grade would change overall time much since steeper ascents would be at a slower speed, unless it was so flat that the descents were slow.
Old 07-13-20, 08:21 PM
unterhausen
Randomhead
Contador's strava is pretty interesting. Too bad I can't climb that fast on 250 watts. https://www.strava.com/activities/3721627590
Old 07-13-20, 08:33 PM
DrIsotope
Non omnino gravis
DrIsotope's Avatar
Would have been interesting to see his data with power. His average speed is 12.2mph, but he averaged ~43mph on every descent, and broke 60mph multiple times.
Even at his flyweight, it would have taken his ~365W for an average ascent early on. By the end, he was probably somewhere in the 270-280W range... which is less than what I would have to put out just to avoid tipping over on a 13% grade.
Old 07-14-20, 05:53 AM
unterhausen
Randomhead
did I misread the power for each climbing segment?
Most segments are 350-ish and the low power ones are 250-ish. My 4 minute power is nowhere near 350, but 250 is doable.
Old 07-14-20, 06:21 AM
joesch
joesch's Avatar
Quoted: 601 Post(s)
Liked 779 Times in 497 Posts
Paul Rozelle rode each of the three roads and the unpaved fire road that lead to the summit in order to earn a medal that the Club des Cinglés du Mont Ventoux awards and then the PBP a few days later. This was an amazing achievement and hard to believe on his SS setup.
joesch is offline
Old 10-07-20, 10:09 AM
hsuBM
jj
Quoted: 140 Post(s)
Liked 110 Times in 78 Posts
Beryl Burton would’ve done it with a 52t ring driving a 16t fixed cog.
i would not.
hsuBM is offline
Old 10-09-20, 08:08 AM
Tourist in MSN
Quoted: 3459 Post(s)
Liked 1,465 Times in 1,143 Posts
You might have better luck with a three speed.
https://cyclingtips.com/2020/08/6-2-...esting-record/
Tourist in MSN is offline
Old 10-10-20, 06:49 PM
anotherbrian
Quoted: 41 Post(s)
Liked 9 Times in 7 Posts
It isn't obvious from the picture, but given all the other optimizations I hope he straightened the chainline with those 3 gears by putting spacers behind the cassette as well.
anotherbrian is offline
Old 10-10-20, 07:36 PM
unterhausen
Randomhead
I don't think he did put spacers behind. Maybe it's one of the newer cassette bodies where that's not really possible
Old 10-11-20, 06:39 AM
Tourist in MSN
If he moved the sprockets further to the right, would the parallelogram shape of the rear derailleur put the cage too close to the sprockets? I suspect that the last thing he wanted to do was to make any changes that had the potential to cause any shifting difficulties.
I suspect a better way to improve chainline would be to shift the chainring position with spacers. But, I am not familiar with that crankset and then frame clearance could be an issue too, so maybe that is not practical? From the photo, if any spacers were added, I can't see it.
Photo from article at:
https://cdn-cyclingtips.pressidium.c...3-1080x653.jpg
As chains get narrower with more speeds, is chainline less critical?
I have about a 5 or 6mm chainline error on my Rohloff bike, that has a relatively wide 8 speed chain and that does not appear to cause any increase in friction or reduction in chain life. I wanted my Rohloff bike to have a Q factor that was similar to my derailleur bikes, thus the crankset spindle is about 10mm shorter than it should be. But I would not want to have chainline error greater than that.
Old 10-11-20, 07:00 AM
unterhausen
Randomhead
I'm sure the thought was that it works on a normal bike, it will work without the extra sprockets.
The people setting records now are doing it on steeper hills. Might be okay to climb on a fixed gear, but descending wouldn't be as much fun.
