Vintage and classic bicycles without kick stands?
#51
Bikes: Miyata 710, Univega Viva Sport, Centurion LeMans, Peugeot U09
Quoted: 212 Post(s)
Liked 111 Times
Look at posts 15, 29, and 41. I’ve scrapped plenty of bikes at my local co-op that had similar damage at my local co-op. Many of them have been relatively nice vintage bikes that weren’t designed for kickstands but I’ve seen plenty of others. Granted, it is usually user error where they go all gorilla on the bolts but it happens. Aluminum frames are even more prone to damage from the kickstand moving on the stay. That erodes holes in the stay which renders the frame unuseable.
That depends on what the bike was designed for. As I’ve mentioned, mountain bikes are a place where kickstands are not only unnecessary and unwanted but present a possible injury hazard. I have a fast road bike that has rear wheel close enough to the seat tube that a 28mm tire rubs on the derailer clamp. It also has a very light frame that would certainly crush if I used a kickstand. I have other bikes that I could probably use a kickstand on but as I’m used to leaning my bike against things, I don’t find any utility in using one on those bikes.
That’s kind of my point. Be careful where you park your bike. I’ve never had a bike topple over when leaned against something. I’ve never seen anyone else’s bike fall over when it’s leaned against a solid object. I have seen bikes blown over while using a kickstand. I’ve had my own bikes blown over while using a kickstand. I’ve never had a wind blow over a leaned bike. Wind really can’t blow over a bike leaned against a solid object because it is either blowing the bike into the object or the object is sheltering the bike from the wind.
No, laying a bike on the ground isn’t a mistake. If you lay the bike down in the middle of foot traffic, that’s not just a mistake but it’s being a jerk. But I’ve seen lots and lots of jerks that park their bikes on kickstands in the middle of traffic...both foot and bicycle...because they have a kickstand.
Yes, you can make valid arguments either way. But people who use kickstands often bring up invalid arguments like leaned bikes are more likely to fall over.
Aluminum frames are certainly more open to kickstand damage. They are also more likely to be damaged by leaning against objects. Again, this is what I've seen. Steel frames are commonly scratched too. The scratch itself is no big deal. But scratches admit moisture, moisture causes rust and rust destroys frames.
People who don't like kickstands often bring up invalid arguments like wind. Don't want the bike on a kickstand blown over? Put it next to a solid object. Or put the kickstand on the downwind side. Easy peasy. And I can't tell you how many bikes without kickstands I've seen leaned against posts and roadsigns, that offer no protection from wind at all. Walls and solid fences don't exist everywhere.
I would really like to hear from a mountain biker who was impaled on a kickstand. I'm thinking that's a bit farfetched.
As you pointed out, a stay can be damaged by overtightening the kickstand. Don't overtighten. Problem solved.
Are we really going to discuss every mistake of every bike rider that makes them a jerk?. This is going to be a LONG conversation. Because there are plenty. Including laying down bikes where they shouldn't. It happens.
Again, there is no right or wrong. For every plus, there is a minus. ,
#52
Quoted: 1857 Post(s)
Liked 664 Times
I'm a fan of them but I wouldn't put them on a road bike since they are not designed for them. Crushing chain stays is an issue.
They are very practical though. And I do not understand why some people would ride a road bike as a daily commuter if practical items like kickstands, locks, racks and fenders are not an option on those bikes.
As for those complaining about weight, we all know most cyclists stand to lose more weight on the person riding the bike than the bike itself.
Likes For Road Fan:
#53
(rhymes with spook)
Quoted: 919 Post(s)
Liked 745 Times
don't ya'll have some bike pRon to watch or something?
Likes For thook:
Likes For francophile:
#55
Bikes: miyata 83 1000,84 1000,83 610,88 ridge runner ,Schwinn 84 high sierra,88 Cimmeron,86 Passage,84 Stumplumper ,83 Mt Whitney,83 Trek 850,Merckx Century,PX10, RB1,XO 1 XO 4,bunch of stuff like that
Quoted: 57 Post(s)
Liked 51 Times
stand
On high end chrome moly racing frames the wall thickness of the tubes is very thin.......the more expensive and lighter the frames.....the thiner the tubes......the manufactures recommend not installing stands on the chain stays.......they are just to thin.......they were not designed for it at all...........many old cro mo racing frames were only rated for a 135 pound rider.......when frames break they almost always break at the drive side chain stay and bottom bracket.......this is where all the stress from pedaling is concentrated........when I buy and old bike I always check this area for cracks.....this is also where most aluminum frames fail...........mountain bikes and touring bike have much much much stronger stays......but a very delicate area........
#56
www.theheadbadge.com
Quoted: 2422 Post(s)
Liked 4,395 Times
If a bike leaning against a wall, fence, tree or any other object is “one flip of the handlebars away from falling over”, so is a bike on a kickstand. The one on the kickstand is even more likely to fall over because the handlebars can be flipped in two directions. Granted, one direction is slightly more stable than the other but it can still fall and it can fall in two directions.
Your descriptions all speak of experiences you'd get with an inferior or poorly set-up kickstand. Try the kickstand on a Social Bicycles or JUMP share bike. Ditto for a good dual-leg stand, like the Ursus Jumbo.
Additionally, as I pointed out, leaning a bike against a wall or something else is away from where people walk. To “flip the handlebars” someone would have to go out of their way to do so. They aren’t likely to just stumble into my bike leaned against something. The same can’t be said for kickstanded bikes. Those are usually parked close to the foot traffic way...often in a manner that blocks the sidewalk.
If you want to go off on a five page discussion to convince the world that kickstands are useless, and that Jacco knows less about bicycle courtesy in the Netherlands than you do, go ahead.
In the meantime, I have three simple (dare I say this phrase?) rules of thumb:
- Road bike? No kickstand.
- Upright bars, IGH, low-end tubing? Kickstand.
- 1930's/40's club bike? Either way - with preference for a kickstand if original, or if the chainstays are already wrecked. XPT top plate preferable to prevent further damage to tubing.
Stamped steel for a BB kickstand, I think, goes back to the late 1950s when I first learned to ride a 20 incher. I wouldn't say they are POS, just heavy and inelegant. The Pletcher is light, functional, off the market and durable, and IMO the Greenfields are light, functional and not durable. Wife's Breezer has a two-leg from Civita (I think) and it is a nice design.
-Kurt
#57
Mad bike riding scientist
Quoted: 6219 Post(s)
Liked 4,218 Times
If there isn’t a wall or fence or something substantial to lean a bike against, I have no problem laying it on the ground. I am considerate about it when I lay a bike on the ground so that it is out of the way but I’m also considerate about standing it against a wall, fence, tree, or even a post.
Stuart Black
Stuart Black
#58
Liked 4,218 Times
All arguments that presume a fairly spacious area to work with - not a shared, narrow street in the Netherlands.
No, it has to do with the undeserved legacy of kickstands within certain cycling factions. It's your belief that people don't use them in large numbers. That may be the case in the circle of riders you know, but not in the greater circle of riders in general. Certainly not within the upright bar and IGH community.
Exhibit A: A mid-1990's Raleigh M-20 Mountain Trail. Fairly modified, but when the frame was given to me, there was a Greenfield kickstand already on it - and it easily cleared the FD. Didn't do a thing to that kickstand except spray it with silicone lubricant.
Stuart Black
Stuart Black
#59
Bike Butcher of Portland
Bikes: It's complicated.
Quoted: 4682 Post(s)
Liked 5,799 Times
Here's my take on kickstands.
If you want one, put one on your bike properly. If you don't want one, don't.
I had a 3 speed Raleigh Sport with baskets that I used for grocery shopping. It had a kickstand, so I used it. Pretty convenient! I think I'll keep them off my Eroica/Cino bike, however. I don't think I'll miss it.
#60
Overdoing projects
Quoted: 784 Post(s)
Liked 1,238 Times
Look @cyccommute you are clearly very anti-kickstand for whatever reasons that might be. I'm a fan of them on the right bikes. I wouldn't put one on a road bike, or at least not one that crushes the chainstays like that.
I have given my reasons why I see 99% of the bikes in the Netherlands wearing kickstands (and heavy-duty motorcycle locks and most of them fenders...). The US has a different bicycle culture and infrastructure, and that's fine.
In the meantime, enjoy some loaded vintage bikes with kickstands:
#61
Liked 4,395 Times
As I said, my rule of thumb, not yours. It's personal preference.
Six quotes not attributable to my previous posts - not my arguments.
Better yet, I can have the mods look at our interaction. As both an independent party and our hosts, they can advise who's out of line.
When was the last time you saw a right-handed kickstand?
What was that thing you said about "making claims that aren't true?"
-Kurt
Let’s talk about that “shared narrow street” shall we? Look at the bike marked by the red arrow. It’s obviously on a kickstand. The very first thing I noticed was the the bike is out in the walk way. If the bike were leaned against the wall, there would be more room for someone to walk down the sidewalk. As the bike is positioned in the picture, there is much less room to walk past it.
-Kurt
Likes For cudak888:
#62
Homey
Quoted: 2427 Post(s)
Liked 1,406 Times
I cant believe the ire going hard in this thread over kickstands. And the name calling? Can that be left on the playground?
You guys need to reel back a little please.
Likes For Siu Blue Wind:
#63
Quoted: 753 Post(s)
Liked 737 Times
I think a kickstand is nessesary on any bike with luggage. Funny thing is that I picked up one of those double legged esee stands for touring bike #1 and it was a no go. I tried to put it on touring bike #2, also a no go. I then tried to put it on a 26" I blame Grant Peterson bike and again, no go. It's in a box and I plan on takeing it out when touring bike #3 gets rebuilt. #3 is a 90's Cannondale T700, and I have no expectation that the two will play well. I ended up useing esee chainstay mounted stands on two of the bikes, but needed to put VO rotation damping springs on both of them to keep the upright with handle bar bags or baskets. One perceived downside is a weird oscillation that makes rideing with no hands sketchy. Could just be the luggage though.
#64
Liked 4,395 Times
Wouldn't it be nice if the top clamp from XPT kickstands were still made? The XPT's were never that great as a stand, but they have a great top plate that pinches the stays from the inside edge - rather than smushing the stays. The chainstay bridge prevents slippage backwards.
Sure, there'd be some exceptions to fit, and they'd only work on older bikes coming into shops today, but they're a suitable, elegant solution - even if it's just for a city bicycle. I'm surprised Problem Solvers never jumped on this.
They even work if installed on a bike that was previously abused by a conventional kickstand:
I've also modified one to work on a later Raleigh Sports. These ditched the chainstay bridge for a woefully weak kickstand plate. The plate is barely study enough to resist front-to-back twisting. This eliminated the problem and looks sharp (yes, it's been sprayed black to match the rest of the bits).
-Kurt
-Kurt
#65
Liked 4,395 Times
The oscillation is amplified by the luggage, but it'll be there without it too. It's just something one has to live with if they have a steering stabilizer installed.
-Kurt
#66
Quoted: 212 Post(s)
Liked 111 Times
So you didn’t look at the pictures or you thought they were fake or you think the people posting them are lying? Which is it? You said you’ve never seen a crushed chainstay. Those are examples of crushed chainstays.
Rust destroy steel frames. Aluminum is pretty inert to just plain water. Add salt and aluminum will corrode but that takes a fair amount of salt and a fair amount of time. Salt will also do the same to steel. But neither a steel frame nor an aluminum frame is going to fall apart due to a bit of scratching. But bikes are going to get scratched for a variety of reasons. Falling over while parked with either a kickstand or when leaned against a wall is not really all that high on the list.
”Put it next to a solid object”? Like a wall? Perhaps you should lean the bike up against the wall to keep it from falling over.
You can’t always determine which is the “downwind side”, especially here in the US Mountain West. The mountains here cause the wind to be very turbulent. It’s hard to determine which direction the wind will gust from at any given moment. It can, and does, gust from 360° throughout the day.
Because most mountain bikers wouldn’t put a kickstand on a mountain bike while riding off-road. The rougher the terrain, the less likely you’ll find a mountain biker putting a kickstand on a mountain bike.
Nope. Not “problem solved”. People make two mistakes when it comes to kickstand installation. Either they put it on too tight to begin with...that’s a general problem that most people have when working on bike anyway...or they don’t tighten it enough. If they put it on too tight, they crush the stay. If they put it on too loose, the stand rotates and the bike falls over. When it’s too loose, they generally overreact and over tighten, crushing the stays. If the bike is an aluminum bike and the kickstand is too loose and rattles around, it erodes the soft aluminum.
Yes, it happens. But there is nothing about leaning a bike against something that makes the bike be in someone’s way more than when using a kickstand. Nor is a leaned bike more likely to fall into someone’s path so that they trip over it than a kickstanded bike is.
But leaning a bike against something is more wrong than using a kickstand, right? While I don’t agree that there is necessarily a plus for every minus, don’t go making up minuses.
If you have never run into a bike with rust on the frame due to a scratched finish you would be the first. Congrats!
I was not aware you live in the "US Mountain West", that magical land where there are no prevailing winds or updrafts or even weather. Where the air simply circles around and around, day in, day out. How incredible.
I believe you when you say "The rougher the terrain, the less likely you’ll find a mountain biker putting a kickstand on a mountain bike" . Rough terrain is no place to be accessorizing your bike. Do that in a shop!
I can't believe how lucky I have been since I have installed many kick stands and not ONCE has it been too tight or too loose. What a miracle! Incredibly I have also been able to install cable stops, derailleurs, shift levers and numberless other parts, fitted around frames without crushing a single tube. It defies logic.
At this point I'll finish, because, well, I have a life.
All the best!
#67
Overdoing projects
Quoted: 784 Post(s)
Liked 1,238 Times
Then again, it's probably Amsterdam we're seeing here, you have no business going with a car into the city center unless you live there (most choose not to buy a car) or because you are a business that only drives through to deliver something.
So that road in the middle is mostly used by cyclists and pedestrians.
Likes For JaccoW:
#68
Myrtle Beach Crab
Bikes: enough one would think, but thinking isn't my strong point
Quoted: 271 Post(s)
Liked 541 Times
to be fair and honest (a seldom occurrence due to an overperforming snark gland..), i did order an upstand that was referred to on this thread for one of my bikes that has stamped dropouts... which will serve the extra benefit of offering a spacer for the QR lever side. and of course the inevitable opportunity to loose the detachable folding stand at some point in the future.
#70
PM me your cotters
Quoted: 1137 Post(s)
Liked 590 Times
I'm surprised I haven't seen anyone mention these: Bolt on Kickstand Rear Axle double mount for 26" wheel, steel black with spring
Or these, similar/same: https://www.bikeberry.com/rear-axle-kickstands.html
I've seen them on bikes abroad, but maybe two total in the last couple decades here in the US?
Liked 4,395 Times
-Kurt
Likes For cudak888:
#72
RUSA #3100
Bikes: Yes
Quoted: 237 Post(s)
Liked 505 Times
This has got me thinking. If I put a kickstand on my Bianchi L'Eroica bike would that make people love it or hate it more?
https://utahrandonneur.wordpress.com
#73
Liked 4,395 Times
Just my personal opinion, of course.
-Kurt
#74
Quoted: 604 Post(s)
Liked 1,063 Times
