Keeper?
#126
Semper Fi
Quoted: 1172 Post(s)
Liked 358 Times
Bill the Decrepit OG
Semper Fi, USMC, 1975-1977
Likes For qcpmsame:
#127
smelling the roses
Quoted: 7081 Post(s)
Liked 901 Times
Yes. Refunded. But I have another issue. Over at Totally Tubular, they are espousing very low pressures on tubulars. And you can't get them high enough. You must be riding very good roads.
Likes For seedsbelize:
#128
Quoted: 1857 Post(s)
Liked 664 Times
It came as a surprise to me when I found them on-line. I was settling for the 23 Rallys after the old Giro that was 22 only. That little bit of extra air volume and contact patch is most welcome. I cannot ride as high/hard air pressures and the young'uns here require. Nothing way low, usually between 95-100 is plenty for this OG.
Likes For Road Fan:
#129
Semper Fi
Liked 358 Times
I've been decrepit for quite a while now
#130
Liked 664 Times
#131
Quoted: 2588 Post(s)
Liked 4,824 Times
DD
Likes For Drillium Dude:
#132
Liked 664 Times
DD, for me it's not a trend. I started riding tubulars on the streets of Chicago when I was 18 and bought a bike with tubulars. It took a while to learn how and where I could get enough pressure to harden the tire (21 mm cottons, I was afraid of destroying the skinny little rims in the first month of riding). I also noticed harshness and did not have the spare $$ start fine tuning my tire selection. I didn't even own a capable pump, beyond the Silca Impero that came with the bike. I tried just bleeding down the tires a tiny bit, and whatever I accomplished helped the ride a lot and did not make it feel slower. I also did not start destroying rims. After I had a Silca Pista, I could see the pressure, and the good spot was between 90 and 100. That's just the way it worked.
I never timed myself, so I don't know if harder was faster (typical roadie wisdom, even in the 1970s), or if a little softer was faster (Bicycle Quarterly wisdom). I just know I liked the 95 psi area a lot better than 110 and up.
Likes For Road Fan:
#133
smelling the roses
Liked 901 Times
I'm finding that, with higher pressures (110) the tire (almost) skates over the bumps in the chipseal. Higher than that might be better, but the top rating of the tire is 110. I'm not seeing a lot of difference at 90. But it's a 22mm tire. The 25mm at 90 feels squishy, and I have never enjoyed that sensation. On a side note, I forgot to check the front tire of my town bike, yesterday, and rode it at around 25 psi. A lovely ride. Another 25mm tire. Even my town bike is a road bike, with upright bars.
#134
Liked 4,824 Times
Still and all, the experience of riding this bike is awesome, and some of that comes from the tubular wheelset, for sure. For one thing, the wheels being lighter, they spin up quickly - and take less effort to do so. They also keep going with less effort. The next true test will be to take them up a long, long climb and see how they feel climbing while seated - I already know what it feels like standing up and making an effort.
So, I'm not giving up on them because I'm seeing the beneficial side already; just wish I'd gotten the tires I ordered and didn't have to be concerned currently about being careful with lower-than-used-to pressures.
From today's ride:
DD
#135
Quoted: 1607 Post(s)
Liked 2,216 Times
WRT the comment about the bump due to the valve not seating in the rim. I am in the process of reading "The art of Wheel Building" where the author states that this is sometimes a problem. His solution or minimizing the impact, is to champfer the valve hole. The example picture shows material being removed toward the side wall of the rims.
hoping to get out today for a ride later. Temps should be really good!
Enjoy the ride!
Enjoy the ride!
#136
Bikes: '8? Ciocc Mockba 80, '82 Ron Cooper, '84 Allez, '86 Tommasini Racing, '86? Klein Quantum, '87 Ciocc Designer 84, '95 Trek 5500, '98 Litespeed Classic, '98 S-Works Mtb
Quoted: 226 Post(s)
Liked 309 Times
Enjoy the ride!
Enjoy the ride!
Dean
Roll Me Up and Smoke Me When I Die
Likes For Dean51:
