Canti to V brake on a Surly LHT?
Quoted: 546 Post(s)
Liked 469 Times
Does a Surly LHT have the proper frame mount to change from Canti to V brakes? I realize the proper levers will be necessary, just wondering what if anything I need to mount them to the frame.
Expired Member
Quoted: 3702 Post(s)
Liked 5,537 Times
Should be a straight forward easy swap if you have the right levers.
Likes For shelbyfv:
Mad bike riding scientist
Quoted: 6228 Post(s)
Liked 4,231 Times
V-brakes and cantilever brakes are interchangeable with regards to the brake bosses. I’m rather surprised that Shimano didn’t require completely different brake bosses back in the 90s when linear brakes were first introduced but even Shimano can’t screw everything up all the time…they try but sometimes they make small mistakes that we can be thankful for.
Stuart Black
Stuart Black
Likes For cyccommute:
Bikes: More bikes than riders
Quoted: 1446 Post(s)
Liked 763 Times
If it doesn't have a rear cable stop and it doesn't run full cable housing, then you can either run full cable housing yourself with zip ties or other clamps or you can install a clamp-on cable stop. Some frames designed for cantilever brakes don't have a rear cable stop, and use a steel "noodle" or some other conveyance to pass exposed brake cable around the seat tube and back to the cantilever straddle wire. Linear pull/V-brakes require cable housing to the brake arm noodle so you'll have to figure out what to do there if your frame lacks a rear cable stop. If you need a clamp-on cable stop, you can get one from Problem Solvers, Origin8, and likely other outfits as well.
Quoted: 559 Post(s)
Liked 419 Times
Instead of swapping to V-brakes, have you considered upgrading to Avid Shortys?
You'll have the ease of installing road pads and not mess with aligning canti pads.
Clark W. Griswold
Quoted: 4407 Post(s)
Liked 4,052 Times
You can mount Shimano's V-Brakes to anything with canti mounts you could also do another brand of linear pull brakes with the proper mounting or with Problem Solvers Travel Agents. Though it is possible maybe a different cantilever brake might be something to look at if you don't want to change levers or don't want to be stuck with the less than comfortable Tektro or Cane Creek levers for long pull stuff.
SE Wis
Quoted: 2750 Post(s)
Liked 3,407 Times
While not the case for a LHT, some early years canti brake bosses are too narrow for using V-brakes (Linear pull for the pedantic) and even some newer cantis (55mm-65mm)
Quoted: 546 Post(s)
Liked 469 Times
My reason for asking is that I am going to try some beach cruiser type bars on my LHT and I already have a parts bike with V brakes, levers, and Deore 9 speed shifters and wheels to swap. I have always preferred the braking on V brakes to any Canti brakes I've owned.
Quoted: 559 Post(s)
Liked 419 Times
Why?
For commuting and light trails, rim brakes are rim brakes.
There is no substantial advantage for one over the other, other than "how they feel".
For me, when wheelsets are true and I mean TRUE, I love setting my canti levers so they only have to be touched for it to brake. That means my pads hover 1mm from the rim.
Liked 4,231 Times
Perhaps in rare cases but I’ve never run across one and I’ve swapped hundreds of v-brakes across all kinds of model years and have yet to run across one that is too narrow.
Stuart Black
Stuart Black
SE Wis
Liked 3,407 Times
https://velo-orange.blogspot.com/201...izing-psa.html
https://www.bikeforums.net/bicycle-m...-v-brakes.html
Liked 4,231 Times
Consider yourself lucky.
It’s really not that much of an issue.
Stuart Black
Stuart Black
Bikes: 2019 26" surly long haul trucker, 1984 fuji espree (converted to fixed/single), 1999 fuji touring series
I have a LHT with v brakes, it's fine.
Quoted: 546 Post(s)
Liked 469 Times
I don't hate canti brakes. I have just always had better brakes with V brakes. Maybe they did need adjustment. My reason for switching though is that the drop bar levers won't work with the upright bars I was thinking of mounting. I have V brakes and levers on a parts bike handy as soon as I pick new handlebars.
Likes For RH Clark:
Expired Member
Liked 5,537 Times
Sounds like a good plan.
Absolutely not. I had Cantilevers on my Tricross and they were abysmal, no matter how much I messed wiht them. Not simply “no as good” but “wicked dangerous”. Swapped them out got the trio v-brakes (no travel agent) and it’s 100 times better. Perfectly functional and safe bicycle now. As long as the fork doesn’t implode. Looks Bodge tho. Anyway…
2023 Salsa Journeyer
2023 Rad Rover 6
1980ish Raleigh Marathon (Vintage Steel)
2006 Trek 820 (Captain Amazing) RIP
2010 Specialized Tricross (Back in Black)
2008 Specialized Roubaix RIP
"I'm built like a marine mammal. I love the cold! "-Cosmoline
"MTBing is cheap compared to any motorsport I've done. It's very expensive compared to jogging."-ColinL
Rides:2023 Salsa Journeyer
2023 Rad Rover 6
I always found cantis a bit spongy, and switching to V-brakes made a big difference for NYC riding.
Quoted: 348 Post(s)
Liked 792 Times
Cantis can be great, or not so great. I think they get a bad rap more than V/linear pulls because there are a lot more variables involved in proper setup of cantis, whereas v brake setup is generally pretty simple.
Quoted: 348 Post(s)
Liked 792 Times
I say this as someone who’s done thousands of miles of loaded touring in the mountains with cantilever brakes.
