Preferred Gear Ratio
Likes For FiftySix:
Quoted: 1062 Post(s)
Liked 665 Times
Slowpoke here: 46:19 on 27" wheels, which works about to about 65 gi. These were the parts that I found in the bin when I threw the bike together, and the ratio suited me pretty well. There are a couple hills in my locale that I can barely crawl up.
Likes For Gresp15C:
Quoted: 346 Post(s)
Liked 398 Times
Here is just a bit more to expand on the great info and explanation that 79pmooney provided on "gear number" and how to calculate it.
IF YOU TAKE THAT "Gear Number" and multiply it by pi .................that will give you the NUMBER IN INCHES you travel with each revolution of the pedals.
REMEMBER THAT pi is 3.14
.....so "GEAR NUMBER" X 3.14 = amount in INCHES that your bicycle travels with each revolution of the pedals
Then take that RESULT IN INCHES and divide by TWELVE to convert into FEET which may will be more meaningful and easier to visualize.
(*****alternatively you could convert that RESULT in inches into METERS, YARDS or whatever measurement makes you the happiest!*****)
____________________________________________________________________________________________________ _________________________________
---------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------- To Recap and Summarize what 79pmooney briefly but expertly explained earlier:
TEETH ON FRONT SPROCKET divided by TEETH ON REAR
take that and MULTIPLY it by 27 or 26 depending on the size of your bicycle's wheel (USE 27 for 630mm(27)... and for 622mm(700C)....)
(USE 26 for the 597mm schwinn tire, the 590mm common 26 x 1 3/8 tire, the 650 a, 650b, 650c tires, the old 584mm, and 559mm tires....)
Example: 45 teeth on front sprocket ........ divided by 15 teeth on rear = 3
3 X 27 = 81 gear number
IF YOU WANT TO KNOW HOW FAR YOU WILL TRAVEL WITH EACH REVOLUTION OF THE PEDALS,
Take that 81 gear number and multiply it by pi and that will give you the total in inches that you travel with each pedal revolution.
So you would multiply 81 X pi ...................which would be 81 X 3.14 since pi is 3.14 when limited to just two decimal places....
Even Jethro Bodine can do this simple calculation.
I know you probably think it is too simple to be useful but as 79pmooney pointed out, this has been around for ages and it is very useful.
FIFTY YEARS AGO,SCHWINN and other manufacturers routinely stated the "gear number" for each and the overall wide range for ten speeds and five speed bicycles.
____________________________________________________________________________________________________ ____________________________________
It is important that you select the appropriate (27) or (26) to be your wheel size in the simple calculation.
Why? Well I hope this ancient example is okay, since I am an ancient Schwinn rider and collector.........
The ancient early seventies to late seventies FIVE SPEED Collegiates and FIVE SPEED Suburbans have the exact same freewheel(32-26-21-17-14) and 46 teeth front.
The SUBURBAN has 27 x 1 1/4 630mm wheels --and-- the COLLEGIATE has 26 x 1 3/8 those 597mm wheels.
Well excluding the math computation.................IF YOU WERE TO COMPARE the 46 teeth Front and 17 teeth REAR combination (which is 4th gear on these ancient schwinns)
Well that 27 inch wheeled SUBURBAN would have a 73 gear number for that 46 Front and 17 Rear .....and travel a distance of approx 19 feet with each crank revolution.......................................that 26 inch COLLEGIATE would have a 70 gear number for that 46 Front and 17 Rear and travel a distance of approx 18 feet with each crank revolution...................so what you already knew but probably didn't much consider and that is that yes the wheel size does influence the overall gearing, and as you can see that having identical front and rear sprockets on different bicycles can't be considered exactly the same in overall gear ratio UNLESS the wheel diameter is indeed the same between both bicycles.................or more or less the same where the slight variance or difference is immaterial and not meaningful.
____________________________________________________________________________________________________ _____________________________________
here is another speed at cadence chart that you can see at the same bikecalcDOTcom site that Ga Dude posted earlier.
https://www.bikecalc.com/speed_at_cadence
Likes For Vintage Schwinn:
79pmooney and I are among the very few (I would guess) people posting on BikeForums who have been riding fixed gear for decades. In my case, I got my first track bike (a Helyett Jacques Anquetil model with Reynolds 531 frame and pretty junky French components) in September 1964, so almost 56 years ago. I used a 51/19 gear combination, which is 70.5 gear inches.
Now, at 68, I mostly ride a Specialized Langster (the aluminum model from the first year of production) or a Felt (aluminum) TK2. Both have 48/18 gearing, which is 70.1 gear inches. I think I'm about ready to go to a 19 tooth fixed sprocket, though.
Likes For due ruote:
Thank you very much!
I’ll use this information for the rest of my days!
Cheerfully low end
Quoted: 646 Post(s)
Liked 1,044 Times
Just this afternoon I set up my ‘88 RockHopper as a SS again, this time with 42/16.
Last time I ran 42/17 but that seemed a bit low so this time I did 42/16. That seems about right since we have an abundance of hills.
I’ve been riding just the 42/16 combination of a 1x7 gearing for the last week or so to make sure it would work out.
Otto
Otto
Likes For ofajen:
When I first started out with my crappy Retrospec "fixie" and I was 7 years younger I was running a stupid 53/16 (87.1 GI) ratio with mini aerobars. At the time it made sense, I was commuting on that gear on flat roads and I felt safer keeping up with traffic. I watched tons of UCI track videos, emulated how to do track starts, getting into the aerobars, and loving the feeling of going as fast as possible. According to my cateye I was averaging 23 mph and hitting 32 mph top speed give or take a few depending on the day. On a ride with some roadies I hit 36 on a sprint before I had to slow for a traffic light.
In recent years I've dialed it down to 48/16 (78.7 GI) which i feel comfortable at. I did all my vacation rides on that gear (anywhere between 45-80 miles) and my natural selected cadence put me around 18 mph on flat straights, which if I'm honest it was to keep warm on one trip because it was raining and 45 F, the effort kept my core warm.
I ride very relaxed and slow gearing. It helps with hills, and also I'm slow in any case.
On my SS/FG, I run 47/21 SS and 20 FG.
On my around-town beater, I run 34/18.
On my mountain bike, I run 32/19.
Likes For crankholio:
Bikes: 2016 Surly Cross Check, 2019 Kona Rove ST
Quoted: 284 Post(s)
Liked 313 Times
Well, I gear low, 42x19 for me. I've got 16 and 17t cogs in my bin, but I live right next to the mountains and my ss sees lots of steep fireroads and trails (even right out my front door the first thing I hit is a 20% grade). And I just turned 60. Those are my excuses!
Likes For pbass:
Cheerfully low end
Quoted: 646 Post(s)
Liked 1,044 Times
Last weekend I also set up the ‘80s Schwinn road bike as SS, again with a 42/16 (roughly 71 gear inches).
That bike has a rear freewheel, so it’s using a SS freewheel I got at the LBS. I un-dished the wheel enough to get the chainline correct.
That bike is a total blast to ride! 👍
SS really works well for me around here, as we have only hills up to the level of river relief, typically 100 feet elevation up to 200 feet in the bigger ones. My usual rides only have hills up to about 100 ft elevation and on the steeper ones I typically just stand up and ride all the way up.
Also, a lot of my rides spend a fair amount of time on converted rail trails that have only modest ups and downs.
Otto
Otto
I'll be 66 in a couple of weeks and my fixed road bike is 49-17 which is 76 inches. I ride an 18.2 route selected for as few large hills as possible, at least 4 days a week. A normal time is about an hour and 15 minutes including warmup.
This gearing is pretty perfect for the route I ride and my strength and endurance. Can handle the hills both up and and down and decent speed on the flatter areas of my route.
Likes For Lakerat:
Quoted: 4806 Post(s)
Liked 3,928 Times
I rode my namesake today fixed up to the ridge line of the Chehelem :mountains"s southwest of Portland (1500' staring at around 200.) My old Peter Mooney is now set up fix gear with 3 separate chainlines. This was a challenge. I needed the gearing range to match the custom fix gear I mentioned in my post last page since I am nine years older than I was when i got that bike and the hills haven't gotten any lower. Now the big challenge with the Mooney is that the dropout is a fairly short standard Campagnolo horizontal dropout of the 1970s. Sliding the wheel to change cogs allows for fine gear tuning only.
So 3 chainlines. 3 completely separate gear systems except: all run with the same chain and each combo adds up to close to the same number of teeth so the hub stays in nearly the same place.
I left the house on the 44-17. (70") Got to the climb. Stopped and moved the chain inboard front and rear to 38-21 (49") Stopped at the top, turned the wheel around and moved the chain to the outside chainring. 46-13 (96") Rode down a 9% 2 mile small country road using plenty of brake (alternating front and rear) and backpedalins some for a nice easy descent in light that is tough on my eyes. Got to the bottom, went back to the original 42-17, added a couple of extra miles and rolled home.
Now, let me explain the "triple chainline". It is a combination of a double sided track hub (fix-fix), a triple crankset and a 'dingle" double cog on one side of the hub. (All cogs 1/8") So, starting in back - I run that "dingle, 17-21 on one side of the hub. I run my small cog (today the 13) on the other, I also dish the hub slightly so the dingle moves in about 2mm and the small cog out 2mm. The dingle was made with two separate cogs that I bought new. The 21 was flipped so the cog is right next to the spokes. (Chain goes exactly the speed of the spokes so minor contact doesn't matter.) A framebuilder cut out the center of the 17 so it slid nicely over the "inboard" (now outboard) portion of the 21. He made a steel "washer" as a spacer between the cogs and brazed the three parts together.
In front, I run an old Sugino 110 BCD crankset on a short Phil Wood bottom bracket. Three 1/8" chainrings. The two small ones are set like a normal double, 38 inside and 42 outside, Then the big difference. I run the third cog outside the normal outside, using custom long bolts and spacers. The bolts are 8mm flat heads with the heads on the inside, nice big stainless steel nuts on the outside. That 46 tooth large chainring is close to the crank but there is no front derailleur so it is not a big deal.
So, each chainring lines up (almost perfectly - certainly within the variations of crank locations on a tapered spindle) with its respective cog. This is NOT a 3 X 3 = 9 possible combinations, This a bike with three different velodrome worthy chainlines but none of them on the track standard line. My lowest gear is inside the track standard and the flat ground gear is outside that line. High gear another step outside that.
This was not an easy project. I designed it on a CAD program (with many trips to the shop with calipers). Had a framebuilder with real machining skills (Dave Levey at TiCycles) made the dingle and the chainring bolts. The bolts took two tries. A place where there could be no play but I still had to be able to assemble it!) And yes, the crankset assembly is time and patience consuming. But the end result? A classic English fix gear road bike that handles like a dream (thank you, Peter Money) AND I can take it into real hills as a 67 yo, Going up, I get to keep my knees and have then have a blast coming down. (The road limits my speed, NOT my ability to spin and the crotch damage I am willing to accept.) Best of all, every inch of the ride is fixed.
The Mooney has finally found its true calling. It was conceived as a bike that could be ridden in the lower 48 states 12 months of the year, do fast club rides, climb (I'm a born mountain goat), tour, and do a little off road. It's done all that. And its first calling - be the place I could go anytime to keep my sanity after a major TBI that made for years of recovery. I had no idea where I would be living. So when I ordered that bike (with a sole job of being my sanity link) I had no idea exactly what it was going to do or need, So it's a real all-arounder. Doesn't do anything really well. Not until 3 years ago when I took advantage to the long chainstays and big tire clearances and horizontal dropouts (just in case I ever wanted to go fix gear) and set it up to ride Cycle Oregon's ride to Crater Lake with miles of gravel. Did this crazy conversion so I could enjoy the gravel fixed on big tires. Yes, it worked! Really well. But I had to try fast tires also, of course. And wow! This is what this bike was made to do! So at year 38 it found it's niche.
Oh, the Mooney' s name is Pete. (Not Peter like its builder or my brother and uncle. Just Pete.) Pete will be painted on the top tube when he gets the deserved paint job in the coming year.
Ride fix gears for 35 years as much as I have and you will start thing about a custom to do what you really want. At 40 years, you might do something crazy. Just warning ...
Ben
Ben
Likes For 79pmooney:
Cheerfully low end
Quoted: 646 Post(s)
Liked 1,044 Times
Otto
Bikes: 2021 Litespeed T5 105, 1990 Gios Compact Pro 105
Quoted: 167 Post(s)
Liked 325 Times
From my brief searching, not many singlespeed complete bikes offer a 53 chainring. If I like 53 / 18 on my multi-speed, what gear ratio would be close to that with a chainring in the 40s?
Cheerfully low end
Quoted: 646 Post(s)
Liked 1,044 Times
47/16 = 2.9375 or 79.3125 is as close as you will come in the 40s.
Edit - if you can do 50/17, that is 2.9412 or 79.4 gear inches and would be even closer.
Otto
Likes For ofajen:
Slowpoke
My Shinola Detroit Arrow was 38/18 and I was spinning out. I changed it to 38/16 (65 inches) and that works out better for me (68 YOA with bad knees). I use the bike for short rides, seldom over 10 miles, at around 10-12 mph.
Not actually Tmonk
Bikes: road, track, mtb
Quoted: 2638 Post(s)
Liked 3,151 Times
42/17 - road easy
42/15 - road fast
52/15 - (outdoor) track
42/15 - road fast
"Your beauty is an aeroplane;
buy my bikes
Bikes: my very own customized GUNNAR CrossHairs
Quoted: 519 Post(s)
Liked 428 Times
interesting thread - I have a 42t x 16t (71 inches) freewheel on my s/s. I'm going to switch to a 38t x 16t (66 inches).
I'm struggling a bit on the up hills, which are not really much to worry about in the south east corner of the Nations High Five. But my knees are good and I want to keep it that way.
- QUESTION: I'm struggling to find what kind of chain to use as I mix and mis-match chainrings and cogs. I got a bit of a click-y drive train and I suspect I have the wrong chain with the freewheel.
I think my SHIMANO freewheel is supposed to use a 1/2 x 1/8in. I am using a single speed chain, but what size? i dunno.
any pointers to threads discussing this in detail would be helpful. thanks.
like this, but more basic-er: https://www.parktool.com/blog/repair...-compatibility
no, i really don't know what i'm doing with these single speed set ups....
cheers!
cheers!
Cheerfully low end
Quoted: 646 Post(s)
Liked 1,044 Times
cheers!
cheers!
You can use 3/32” chain for single speed ONLY if both your chairing and cog are 3/32”.
If either component (or both) are 1/8”, then a 3/32” chain won’t fit and you must use a 1/8” chain.
Otto
Likes For ofajen:
Ups!
Fixed Gear Forward Indie 1.0 - 46T/16t=2,88
Fixed Gear Polo&Bike virens - 48T/17t=2,82
Fixed Gear SE Bikes SE Tripel 2015 Vatte Black - 42T/18t=2,33 (winter)
New Fixed Gear - (48T/17t)x(53T/22T)=6,8
Ups!
Yes, by the way, gear ratios are not correctly specified without the tires used. Therefore:
Indie: 700x33c Maxxis Mud Wrestler 62a WireTPI60
Polo: Mitas PHOENIX RACING PRO 23-622 (700x23C) ROAD
SE: Schwalbe Marathon Winter front tire 240 spikes (28" x 1.35 / 35-622) Schwalbe Marathon Winter rear tire 240 spikes (28" x 1.60 / 42-622), RaceG Both four rows.
NFG: MICHELIN 1,4 wild Run'r 26x1,4 (35-559)
Likes For y0x8:
