Brakes - where do you stand?
#102
Quoted: 3345 Post(s)
Liked 1,054 Times
One additional thot on bikes with disc brakes. The drop outs are wider, and therefore there is less dish in the spokes, and that makes the wheel stronger.
#103
Quoted: 4731 Post(s)
Liked 3,832 Times
Methinks you forgot you are in the 50+ forum section. At this point of life, you are not talking about racing situations, so for example #3 wheel change is not much of an issue.
#2 also mostly doesn't apply unless you travel with your bike and need to have at least the front wheel off or both for air travel. Another situation might be if you use an indoor trainer (that one for which you need to take the rear wheel off). Also, I'd think, most of us in this age bracket don't keep extra wheel sets to swap depending on the kind of rides in the offing.
#6 I'd say, most of us at this age bracket are not chasing a gram of weight here and there.
However #1 & #5 may come up for everybody at some point and when it does, it can baffle even reasonable skilled bike mechanics. BTW by the noise is not meant that brakes are miss-adjusted as somebody above here seemed to imply, but the horrible noise that sounds like abused pig squealing when you brake in damp weather conditions or maybe because of pads contamination (?).
I am sure not all at 50+ are like that but I'd think those are exceptions to the rule.
And there are always aesthetics at play, bike needs to be pleasing to one's eye regardless of age. Myself I'd say, not all disk bikes are ungainly, or not completely so. I imagine I could live with one too, especially if that was like S-Works or Bianchi or some such fancy bike like that in the $10k+ range which I think someone posted pic of above here...
Also, as much as I can see the disc utility on mountain bikes, most of them look more ungainly with them than road bikes do. That's because of smaller wheel sizes and overall smaller sizes of MTBs, which makes the disc more prominent than is the case on road bikes. On the other hand, MTB looks are 'too busy' anyway, you have prominent shock absorbers and what not, which makes them look like some piece of machinery anyway. Road bikes by contrast are, or can be a study in elegance, simplicity, sleek lines, which simply doesn't apply to stout build of MTBs which is needed to take the terrain abuse....
To mind comes a comparison - road bike are like Elves where MTBs are like Hobbits
I don't travel by car with bike very often (maybe two rides/year pre-COVID) but I swap wheels all the time. For different rubber, different cassettes .. Take the wheels out to clean the bike. It's so easy and I take it so for granted, Why would I want to change?
Lighter bikes? They get nicer and nicer as I age and the rack gets higher and higher both seemingly and literally as my height shrinks.
Ben
#104
Liked 3,832 Times
I haven't got there yet so this is just speculation but doesn't this affect Q-factor? For my knees, large Q-factors (much over 145mm)is a deal breaker.
#105
Bikes: '06 Bianchi Pista; '57 Maclean; '10 Scott CR1 Pro; 2005 Trek 2000 Tandem; '09 Comotion Macchiato Tandem; 199? Novara Road; '17 Circe Helios e-tandem:1994 Trek 2300
Quoted: 146 Post(s)
Liked 92 Times
No cables, but just look at those ugly wheels. Sorry!
#106
PBP Ancien (2007)
Bikes: Cannondale CAADX (for commuting), Cannondale CAAD12, Cannondale CAAD12 Team CNCPT, Giant Contend 2
Quoted: 77 Post(s)
Liked 156 Times
The popularity of discs is having an affect on rim brake prices and I've just picked up some Dura Ace 9100 in the UK (aka rip-off Britain) for $260.
#107
Guest
Quoted: 1346 Post(s)
Liked 3,269 Times
Another old guy here. Here's how my bikes brake:
Mountain bike: Hydro discs
SS Cyclocross: Cantis
Geared Monster Cross: Cantis
Road: Caliper
BMX cruiser: V-brakes
Future bikes will probably have discs, but due more to their ubiquity than my preferences.
Road: Caliper
#108
Quoted: 8148 Post(s)
Liked 8,800 Times
Remember most mountain bikes come with single ring cranks so that would make the Q less critical.
Another factor with regard to chainline is chainstay length. Mountain bikes come with different length stays depending on the desired ride.
#109
Quoted: 252 Post(s)
Liked 67 Times
... I notice that disc wheel changes are so fast and easy that at the world's greatest bike race, they frequently don't just change the rear wheel, they do both wheels, drivetrain, frame. cockpit, brakes and seat all at once. ...
Ben
Ben
I take my road tires into a terrain on occasion and it wouldn't come to me to swap wheels for more appropriate tires. But that is more to my being cheap, also I do at most only several miles in off road conditions inserted into my otherwise smooth road ride. I just adjust my speed to the terrain and when it gets real bad, like road washed out with big rocks only left to ride on, I dismount. But most folks who are careful about their wheels would also dismount even if on MTB with proper tires for such terrain.
#110
Bikes: Habanero Titanium Team Nuevo
Quoted: 396 Post(s)
Liked 183 Times
I don't normally ride in the rain at least on purpose but got caught yesterday in downpour. Frankly my rims brakes work fine but I can see the benefits for the disc after this ride.
#111
Quoted: 252 Post(s)
Liked 67 Times
Also, this is nice granite, mostly with rounded edges from glacial process. I live in area where rocks tend to have relatively sharp edges.
I ride 700x23 run of the mill tires, nothing special, currently I have Vittoria Zafiro (spelling?) but some cheap ones from their lineup, and I take them on grass with soft ground, forest roads and rough gravel service roads that vibrate the hell out of you, in short, places where you don't see anybody on a road bike as a rule. Of course, some pro races in EU ride on even worse surfaces and not slowing down to save material like us normal folks do, who don't have access to unlimited bike supply from the car following you...
Last time I destroyed tire was paradoxically on a smooth road that had a fresh pothole in it, so it had sharp edges. I had snake bites on both wheels (each double - each side of the inner tube) and one of the tires was a write off.
#112
Guest
Liked 3,269 Times
Whether caliper, cantilever, V-brake, or disc, I’ve never once not been able to slow, stop, or otherwise control my speed when I pull the brake lever. Why? Because I know how to adjust and maintain my brakes, whatever type they may be.
So get what you like for whatever reasons you have. If you’re looking for others to validate your choices, you need to ride more. Eventually you’ll stop caring about how others feel about these things.
#113
Guest
Liked 3,269 Times
Yeah, sometimes things got a little sketchy, but a lot of us old guys somehow managed to survive riding and racing in the elements without disc brakes for years. Must have been our mad skills!
Likes For Rolla:
#114
It's MY mountain
Bikes: Klein, Merckx, Trek
Quoted: 4297 Post(s)
Liked 2,929 Times
I've survived riding and racing for years and it's those experiences, especially off-road, that inform my understanding of the limitations of cantis and linear pull brakes. And the distinct advantages of discs when it gets fast and nasty.
Claiming that you've never not been able to slow, stop, or otherwise control your speed simply because you know how to maintain and adjust your brakes is laughable.
#115
Guest
Liked 3,269 Times
I'm talking about equipment, and experience riding in challenging conditions.
Likes For Rolla:
#116
Liked 1,054 Times
Actually for cyclist that ride steep long down hill roads in the mountains, disc brakes wont over heat your rims and blow out a tire at speed. Can you say road rash.
#117
Guest
Liked 3,269 Times
My only "claim" is that I've maintained my brakes so that they've performed well when I've needed them to.
Evidently, you're convinced that I've denied that disc brakes have advantages over rim brakes. This is not the case.
#118
Bikes: Nashbar Road
Quoted: 2934 Post(s)
Liked 341 Times
I've been a fan of disc brakes dating back to the time that everyone on BF informed me that they'd never be available on stock road bikes because there was no real advantage.
Now with mechanical discs on a cheap MTB and still Sora level calipers on my road bikes I am completely satisfied with either. If my next road bike, if any, comes standard with hydrolic discs, it's all good. I won't give it a second thought.
#119
Zip tie Karen
Quoted: 1465 Post(s)
Liked 1,542 Times
[yawn] Oh, sorry. I was napping. What is the question again?
Yes. Brakes. I'm in favor of them. Except if you're a fixed gear rider and a stud, or a track rider, or both. Then, they'd be optional.
I cannot see riding an MTB without hydraulic disc brakes. Especially as I age and am becoming more risk averse. Healing from a broken bone takes longer than it used to.
I will add that I was forced to keep the DiaCompe 981 cantilever calipers on my '88 Fuji tourer. Trying to find a modern lever with the right pull ratio has been a challenge. Even with KoolStop post-mount pads, the braking has been … sketchy at best to downright terrifying under load. Recently, I swapped in TRP clone levers and voila! Improvement!
Otherwise, I really like rim brakes a lot. The new R8000 calipers and older 5800 calipers are quite excellent even with the stock Shimano pads. Quite excellent.
#120
Guest
Liked 3,269 Times
I never said that, so I guess you're just arguing with yourself now. Let us know who wins.
#121
Bikes: Turner 5-Spot Burner converted; IBIS Ripley, Specialized Crave, Tommasini Sintesi, Cinelli Superstar, Tommasini X-Fire Gravel
Quoted: 392 Post(s)
Liked 370 Times
I'm only convinced that you imagine that "properly adjusting and maintaining your brakes is the key to being able to slow, stop, or otherwise control your speed when you pull the brake lever" is the key, regardless of conditions.
Not all brakes slow, stop, or otherwise control your speed in many conditions.Which gets back to my first reply - experience.
#122
Quoted: 2964 Post(s)
Liked 1,159 Times
6 pages of discussion/arguing on rim and disc brakes when in the end (within the next year or so) all you are going to be able to buy is disc brake bikes.
Not even sure why this is being discussed anymore. Discs are superior in every way and are what the majority of people want and that's what the manufactures are going to make and sell.
Recently a buddy of mine was trying to sell me his 2018 Trek Emonda with rim brakes. A really nice bike that weighs about 15 pounds. I jumped on it and gave it a spin. The stopping power of the rim brakes was very disappointing compared to the disc brakes on my road bike. No disc brakes = no sale.
#123
Guest
Liked 3,269 Times
I'm glad you quoted me, because it helps to illustrate the absurdity of your responses.
I never said that every well-maintained brake will work equally well for every rider under every imaginable condition.
I never denied that disc brakes have advantages.
I never denied that rim brakes have limitations.
What I said is that all of my brakes -- both rim and disc -- have always worked well for me, and that I credit conscientious maintenance for their good performance.
Why this irks you so is mystifying, but not worth investing more effort into solving. Have a nice flex.
#124
I'm starting to agree with this. After my trail ride yesterday, I thought my rim brakes were going to fail, I was on them so hard at times. And being a 52-year-old just returning to biking, my risk tolerance is far lower than it was 30 years ago! Fortunately my old hardtail MTB has mounting bosses for disks, so a conversion is in my future. I had never test ridden any bike with disc brakes of any kind until this year, and I must say I much prefer them over rim brakes.
Likes For OldYankee:
#125
Liked 1,159 Times
