Help me with my wobbly Diverge - Front Futureshock
Quoted: 10 Post(s)
Hello folks! I have recently purchased a second hand Specialized Diverge 2018 model.
I have upgraded a few things on it ( wheels, handlebar, stem and brakes ) and whilst doing some initial riding the front end didn't quite feel 'right' it felt like what a loose headset would feel like on another bike.
It actually seems the front end is wobbling slightly ever so much left and right just a few millimetres , so I watched a variety of Future shock videos and tightened ( even overtightened ) the preload. It made literally no difference.
So I assumed there may be something wrong with the bearings so I purchased a couple of brand new bearings, pulled the whole unit apart cleaned it all up and re-greased and followed the manuals and videos online and set up the pre-load correctly again. The front end feels smoother, but the wobble is still present.
I have taken a video and some pictures but these forums won't let me share any links or pictures until I have 10 posts... But searching Youtube below will at least show you a quick video. As I get 10 posts I will relink the things here. I am hoping someone can help me out?
I am wondering if it is something to do with the spacers which came on the bike.
Youtube: QTWBIZQSq8c
Quoted: 6193 Post(s)
Liked 4,808 Times
I can't tell from the video where the movement you talk about really is. But the way you are shaking it, are you sure the axle or wheel bearings aren't too loose?
Quoted: 10 Post(s)
The movement is horizontal the wheels are brand new, but I have a few wheels I can swap over from my other bikes and some different thru axles. I will give this a try, thanks for the pointer!
Quoted: 10 Post(s)
So a completely different set of wheels with a different thru axle of the correct size did nothing.. I also made sure it was tight enough.
Bikes: 2016 Fuji Tread, 1983 Trek 520
Quoted: 676 Post(s)
Liked 741 Times
I don't have direct experience with that unit, but as with all suspension systems there is a piston/cylinder unit. It looks like there is play between the piston and cylinder. That unit may not be serviceable. A quick search shows a replacement unit costs about $250, so hopefully that's not the problem.
Quoted: 10 Post(s)
Something tells me this May me the problem.
Curmudgeon
Bikes: Specialized Diverge Comp
Quoted: 157 Post(s)
Liked 32 Times
Quoted: 10 Post(s)
I had that issue with my 2018 Diverge Comp. After MANY trips to the bike shop, I determined via my own inspections and diagnosis that the Future shock had completely failed. I insisted on a warranty replacement. While the bike shop was not in agreement Specialized did not hesitate to send me a replacement. Problem solved.
Quoted: 427 Post(s)
Liked 339 Times
What actually wears out on these? If a new unit is $250 and these are failing regularly, that gets my attention as something I ought to look into producing as an aftermarket replacement item.
Do you have any failed units sitting around?
Quoted: 10 Post(s)
Specialized were quite useless in responses. I ended up going back to the shop where it was bought from and sharing what I had found, I think Specialized have now arranged a replacement part.
Tom
Quoted: 5779 Post(s)
Liked 2,576 Times
Why are you reviving a zombie?
Likes For FBinNY:
Quoted: 514 Post(s)
Liked 448 Times
https://youtu.be/QTWBIZQSq8c
Something is amiss in the attachment of the stem to the steerer.
Likes For grumpus:
