Replace brake cotter pin with screw?
I'm having some minor brake issues and want to pull the pads out to have a look at them, they're M6000 Calipers and have a cotter pin. I get the pin does the job just fine but I dont like them for removal and installation. With the best I can get my calipers in there I measure the pin diameter at 2.65mm. The pin seems kind of loose so maybe the hole is 3mm or close to, I was thinking I could either use a 3mm through bolt with a nylock on the other side or machine the threads off most of a 4mm bolt and tap the caliper on one side (depending if the existing hole size is appropriate). Option 1 seems better for nothing vibrating loose and will take no or minimal modification to the caliper, option 2 seems more elegant. Anyone done either?
Quoted: 4197 Post(s)
Liked 3,849 Times
Pads are sitting in their shoes under compression. Both because of the clamping pressures the arms provide and the rim rotational force. For decades open ended pad shoes have worked very well, only recently as liability concerns have increased has the pad being better secured in the shoe become a need.
Have you found that your pads extract themselves form their shoes during use? If not the I suspect you're seeking a solution to a problem that isn't happening. Andy
AndrewRStewart
AndrewRStewart
I'm not saying the way the pads are "secured" are a problem, I just don't like it. I, want to remove the pads to look at them so I thought while they were out I'd address that (very minimal) issue.
Bending a cotter pin back to its original shape so it slips out easily and not mar the hole on it's way out takes sone time, and that would be exasperated next time if I reused the same pin. I thought I can make a better solution.
I like that idea. Not a fan of the cotter pins either. If you beat me to this project let me know how it went.
Quoted: 184 Post(s)
Liked 67 Times
The SLX, XT & XTR brakes use the following.......
https://www.nashbar.com/shimano-disc...z98010/p305110
I've seen a post where someone tapped a thread to use these 'pad axles' in Deore brakes, they said the thread is a 4mm x .7
https://forums.mtbr.com/fat-bikes/sh...l#post12697195
Invariably the bolts end up rounded after several pad changes and are somewhat difficult to find as they're not normal bolts. Moreover on a mountain bike they are a pain in the ass as they are small and the bolt head ends up filled with dried mud, and they tend to stick with time, which makes it easier to accidentally round the head.
Cotter pins on the other hand are cheap, you can find them anywhere, can be installed and removed with the pliers of a swiss knife, and are unaffected by dirt / mud, whatever.
Oh, I forgot to say that the SRAM brakes have a safety pin on the bolt (to avoid it coming loose, I suppose) which tends to break after a few removals. It would be easier to just us a big pin like Shimano "cheap" brakes to begin with.
Last week while servicing a Sram brake caliper when attempting to remove the pad retaining or "safety" bolt the head broke off. Come to find out another mechanic had this happen as well. Looks like Shimano knows a thing or two and uses cotter pins on a few of their calipers. Makes sense to me.
Likes For Amt0571:
Quoted: 1438 Post(s)
Liked 1,092 Times
Buy a box of cotter pins (cheap) and use a new one each time. I suspect that Nylok® nuts might not work well due to brake system heat, either coming loose or melting shut.
Perhaps the safety pins we use on aircraft could be used: https://www.aircraftspruce.com/catal...owlingpins.php
Here are some other locking pin ideas: https://www.mcmaster.com/lock-pins/cotter-pins/
Generally bewildered
Quoted: 1152 Post(s)
Liked 341 Times
In this application I think that they use a pin to ensure there's no chance of loss (as can happen with a bolt and nut). And the design doesn't allow you to torque the nut: that would distort the two parts together. Frankly, I don't like the cotter pin in this application. A solid, rather than a split shaft would seem to better handle the significant shear force on this part. To tell you the truth, in this application I like a clevis pin. With a small cotter pin to retain it! I see that Cobba has a picture of such, above.
Likes For Amt0571:
I grew up on a farm. Seems like every time a cotter pin was used/broke it was replaced with a bent nail. Lol. I think that's where my dislike of them comes from. Every time I look and see that pin I think hmm i bet a 4d finish nail could replace that.
Liked 341 Times
I still like a clevis pin for shear duty rather than a split-pin cotter. But I suppose Shimano knew what they were doing.
Quoted: 581 Post(s)
Liked 921 Times
I think the problem that OP is creating for which they are looking for a solution is the removal of the pads in the first place. There is no need to remove pads unless they are worn or you know them to need some other treatment, like filing off a lip or removing embedded metal rim leavings.
For a better look at the pads, just remove the wheel. If the pads are worn irregularly or have a lip, you might as well remove the pad and pad holder as it needs to be adjusted anyways to prevent recurrence of whatever necessitated the removal.
https://bike.shimano.com/en-US/produ.../BR-M6000.html
with the cotter pin in your hand , go to an auto parts store and buy a bag of a dozen of them..
or Home Despot
or Home Despot
Quoted: 1034 Post(s)
Liked 1,290 Times
