Dura Ace pedal removal
Bikes: 1983 Univega Super Strada, 1986 Panasonic DX5000, 1984 Fuji Team 85 Univega Gran Turismo, 1984 Lotus Unique, 1987 Centurion Expert, 1987 Centurion Ironman Master,
Quoted: 677 Post(s)
Liked 460 Times
Just picked up a bike that has dura ace ax7300 pedals. It looks like it takes a special wrench for removal. Does park tools sell this? Couldn't find it on their website.
Quoted: 2338 Post(s)
Liked 2,822 Times
don't know about the tool but those pedals and cranks are a non standard one off that had very limited production time as the design was not accepted at all the pedal threading is not standard, much larger than normal, so to use non AX pedals you will need to find an adapter..
cant tell. but is there a hex hole on the end?
VeloBase.com - Component: Shimano PD-7300, Dura-Ace AX
Only Dyna Drive pedals were odd, those have a huge crankarm end hole
otherwise 9/16"x20tpi R&L thread.... hex socket in the inside end of the pedal axle perhaps?
Quoted: 677 Post(s)
Liked 460 Times
Quoted: 677 Post(s)
Liked 460 Times
I'm wondering do you service the bearings without removing the pedals?
Saw the many flats around it ts outside edge? that is wher you unscrew it , big open end wrench 1/8" thick*
if you're lucky they used something like threaded *headset wrenches which are 32 or 36 mm..
inside hex is a bearing ball race adjustment.. I note its steel by the rust..
If I were you & wanting to ride the bike ,not just display it ,
I'd take the whole crankset out , auction it, and put something else on the bike frame..
Quoted: 1814 Post(s)
Liked 923 Times
I had some of those- don't recall needing anything more than a wrench to remove them,
but as fietsbob recommends above, I swapped them out for similar vintage cranks that take more useful pedals.
Quoted: 1163 Post(s)
Liked 442 Times
You need the correct Shimano DD (Dyna Drive) wrench to not mess up the flats on these pedals. There is an eBay seller in Poland that makes a copy of this wrench.
Quoted: 677 Post(s)
Liked 460 Times
Liked 2,822 Times
as i noted earlier, no you need an adapter and not sure how great that is in practice....no hands on
Quoted: 677 Post(s)
Liked 460 Times
Ok I think I could service these pedals except for the fact that 1 dust cover is broken and the other is missing completely
and I really doubt that I can find replacements
Quoted: 1944 Post(s)
Liked 2,164 Times
https://www.ebay.com/itm/New-cranks-...sAAOSwaB5XpdTz
John
Bikes are okay, I guess.
Quoted: 2647 Post(s)
Liked 2,446 Times
In my toolbox. I also have NIB pedals and a used pair, and some cranks.
Quoted: 677 Post(s)
Liked 460 Times
Liked 2,446 Times
Maybe on the old pedals. I'll look. Would not want to K-ball (cannibalize, old military term) the new ones.
Liked 2,446 Times
Quoted: 677 Post(s)
Liked 460 Times
Liked 2,446 Times
Quoted: 677 Post(s)
Liked 460 Times
