Locating a fabricator
n00b
Bikes: Surly Karate Monkey, Twin Six Standard Rando
Quoted: 428 Post(s)
Liked 466 Times
I have a steel CX frame with limited room for tire clearance between the chain stays. I am willing to pay a fabricator to modify the frame by any means necessary to do this, but I can't find one to do this. I have asked on every forum, Facebook group, and red_it page I could think of no zero skilled craftspersons have come forward to offer their services. I have always heard that steel is easy to work with, but it's pretty hard when metalworkers apparently no longer exist. Any tips for finding these reclusive folks in central Texas?
I have tried adding dimples between my chainstays: waste of money and shattered several tools in the process. Chumba is nearby but they won't work on other companys' frames, which is fair.
Quoted: 4206 Post(s)
Liked 3,870 Times
I wonder if it's more about no one wanting to take on this modification... There's lots of us steel working guys out here. Andy
AndrewRStewart
AndrewRStewart
n00b
Quoted: 428 Post(s)
Liked 466 Times
I can't find a metalworker PERIOD. I think I am looking in the wrong place, but I don't know where to look.
Liked 3,870 Times
Have you tried to ask the LBSs? The shops that are older and/or focus more on service might be better then those who drink the current corporate Kool Aid.
https://www.velocipedesalon.com/foru...ors-43632.html Here's another forum's list of framebuilder "mentors" to try contacting. I believe at least a couple are in TX.
A few of us have made rather specialized tools for stay denting. A general metal fabricator might understand the issues but doubtfully have tooling. Andy
AndrewRStewart
AndrewRStewart
n00b
Quoted: 428 Post(s)
Liked 466 Times
I asked around at some shops and the only place that came up is Violet Crown Cycles. Their website has been taken over by a casino and they have not used their Facebook page in a few years.
The list on Velocipede Salon should be handy. I occasionally post on that forum as well and my questions were never successfully answered there either.
Quoted: 2338 Post(s)
Liked 2,822 Times
what frame and how big are you trying to go?
n00b
Quoted: 428 Post(s)
Liked 466 Times
Traitor Crusade. Barely has room for 700x35 and my tire measures 38mm at the widest point. The tiniest bit of mud locks up the bike. 38mm is not enough for the terrain I ride, so looking to get 42 in there. I've tried dimpling it myself by several methods and only managed to smooth my dropouts together.
Wife put a hard no on buying something new. This is my life: buying cheap **** and nickel and dining myself into something that almost works but always misses the mark.
Liked 2,822 Times
Likes For squirtdad:
Liked 3,870 Times
As Clint said, "a man needs to know his limitations". Andy
AndrewRStewart
AndrewRStewart
Likes For Andrew R Stewart:
Randomhead
Liked 3,698 Times
I would have to see a picture before offering any opinions. I think you might have to ship the bike.
People use a die in a bench vise to do this, I can't imagine you breaking that.
n00b
Quoted: 428 Post(s)
Liked 466 Times
chainstays on my Traitor Crusade
I think the cost of shipping this frame anywhere would make it totally not cost-effective. the whole bike was $600.
I made a few attempts at dimpling it. I have a bench vice but there is not enough room between the chainstays for either side of the vice to fit between them. I made a few dies out of various materials and none of them worked. I shattered a c-clamp immediately while making another attempt. most of the good dies I have seen require some welding and machine work. if I had access to the tools needed to do that, I'd just modify the frame with those rather than trying to smoosh it.
Randomhead
Liked 3,698 Times
Thanks for the picture, that clarifies the situation a lot. I think your problem is that it's too close to that bridge to make much headway.
C-clamps aren't what they used to be. A good one costs quite a bit of money, which nobody wants to spend, so we can only get cheap ones. One the right size is most of $200 on mcmaster carr.
Likes For unterhausen:
n00b
Quoted: 428 Post(s)
Liked 466 Times
that's what I was thinking. I was hoping to find someone who could cut that bridge, widen the stays, and weld a new bridge in there. I don't care what it looks like—it just needs to be functional and allow a tire that does not beat the snot out of me on the dirt. most likely, that won't be cost-effective. buying something new is not an option either, so I guess I'll ride this until it breaks (or I do). I'll probably go first because this thing is a tank.
Randomhead
Liked 3,698 Times
What size is that tire, looks like a 38mm? Have you thought about going 650b?
n00b
Quoted: 428 Post(s)
Liked 466 Times
I tried a 32mm Gravelking SK and had to live with the compromise of riding with pressure so high that it rattles the fillings out of my teeth, or walk home every time due to slicing tires. I went though a few tires that way. so far, the 35(38)mm is the bare minimum I can tolerate. 40-45 would be perfect though. i'll take a bit more weight if it means I don't have to tiptoe over all the "interesting" terrain. I'm not racing anyone, just exploring in places where riding my mountain bike is like slogging around with cement blocks strapped to my ankles.
I borrowed a 650B wheel with a 42mm tire and it and the tire was too wide to even fit in the frame and spin at all. the space between the chainstays is the same where a 700C and a 650B tire pass through the frame. so 650B is a dead end as well. I might be able to it with a 26" wheel but then my cranks are getting dangerously close to the ground.
Quoted: 321 Post(s)
Liked 263 Times
You could just delete the bridge. They don't really serve any purpose other than being something to attach a fender too. What's strange about the picture is how much clearance there is for the chainring, like it's got an MTB chainline, in which case they could have easily given you more tyre clearance.
n00b
Quoted: 428 Post(s)
Liked 466 Times
that's a 39t chainring on a road double crankset with the ring mounted in the inner position. I can easily fit a 42t on there in the same spot. there's gobs of room in there and the bike was sold with a 36t ring with a 16t cog for cyclocross racing. they could have spread those stays and made a ton more room.
Randomhead
Liked 3,698 Times
I was thinking it would be easier to dimple the stay where it would need to be dimpled for 650b. I thought about mentioning that you could just delete the bridge. I always put bridges in, but that's because I want to be able to mount fenders. You can't mount a fender on that bike with the size tires you want to use, so it wouldn't be a big loss.
Quoted: 3464 Post(s)
Liked 2,829 Times
When I see that image, steel frame does not come to mind. Looks budget aluminum. nicked clear to the metal, no rust... (found the model - claimed to be steel)
The comments of 650b would help, but entail a whole other cascade of cost.
there is little real estate to work with.
There is a time to call it a day, sell it and buy a used something else.
After looking at the bike on an old website- I think the path of least resistance is a different frame, or entirely different bike.
n00b
Quoted: 428 Post(s)
Liked 466 Times
New frame is definitely not in the budget or I would have done that a long time ago. New bike is absolutely out of the question. That's why I am so desperate to make this one work cheap.
Randomhead
Liked 3,698 Times
use lower tire pressure? Or get a redshift suspension stem, people seem to like them
The lumps in the weld definitely say steel to me.
n00b
Quoted: 428 Post(s)
Liked 466 Times
I am using the lowest pressure I can manage without bashing the rims on the ground. Yes, the tires are tubeless. If I go any lower than 35psi, I get rim dings. I weight 160 pounds.
A suspension stem does nothing for the rear wheel. My hands and wrists are fine because the bike fits. I could fit a much larger tire in the front but that is not the problem. I larger front tire would only encourage me to let the front wheel write checks that the rear can't cash, so to speak.
A larger rear tire would help, which is why I want to modify the frame.
Randomhead
Liked 3,698 Times
I used to ride my 38mm tires at 20psi, but I do have a dent to show for it. Suspension seatpost then.
You don't' really have enough space to get 5mm on both sides for 700c tires. 650 will move you back where the dent isn't so deep. That's expensive too though. There is always the risk that you are going to permanently damage the frame.
n00b
Quoted: 428 Post(s)
Liked 466 Times
if what you're saying is that modifying this frame is absolutely impossible for any metalworker to pull it off, or at least at a cost that is reasonable considering the cost of the bike and my limited budget, I guess I am screwed until I win the lottery (which is also impossible because I don't throw away my money on that, just crap bikes that never suit my needs) so I can afford a bike that will hold up for my riding style.
Liked 3,870 Times
So here are two ideas for a tool to crimp the stays with. For built frames i find the second one is better as it has more fit clearance WRT the other stay. I could be tempted to loan one of these... Andy
AndrewRStewart
AndrewRStewart
