Need compatible Boost 148 Freehub
Old 09-09-20, 09:05 PM
bike_boy
Lula Mae = 15 lbs.
bike_boy's Avatar
Bikes: 2011 Trek Madone 6.5 w/SRAM Red 22
A bearing has gone bad in sealed bearings of my Bontrager Boost 148 Hub.
What is a better compatible freehub? Will bearings be included with freehub?
I have SRAM Eagle NX 12 speed components.
bike_boy is offline
Old 09-10-20, 09:42 AM
grubetown
grubetown's Avatar
Quoted: 110 Post(s)
Liked 24 Times in 21 Posts
Replace the bearing?
grubetown is offline
Old 09-11-20, 07:55 AM
bike_boy
Lula Mae = 15 lbs.
bike_boy's Avatar
I believe LBS indicated freehub body had an issue as well.
Is a DT Swiss 350 (28 spoke hole) a good replacement hub for a Bontrager Boost 148 hub?
What freehub is needed for SRAM Eagle NX 12 speed?
Is DT Swiss 350 packaged with a set of bearings?
I have seen several complaints that the Bontrager Boost 148 has issues with either the hub or sealed bearings.
There was one who indicated hub can't take the stress of the torque of 1x or 2x drivetrains.
bike_boy is offline
Old 09-11-20, 09:27 PM
grubetown
grubetown's Avatar
Quoted: 110 Post(s)
Technically if your hub is bad, any hub is better
  1. 350 is a good solid hub
  2. You will need the SRAM XD driver
  3. The hub will come with bearings
Old 09-12-20, 06:36 PM
bike_boy
Lula Mae = 15 lbs.
bike_boy's Avatar
But, from some reviews I read it looks like SRAM Eagle GX requires XD Driver. Whereas, 12 speed SRAM Eagle NX does not
need XD Driver as it can use a standard SRAM/Shimano 10 speed freehub
bike_boy is offline
Old 09-15-20, 07:20 AM
grubetown
grubetown's Avatar
Quoted: 110 Post(s)
Apologies as I misread the NX part. You are correct NX does not require XD driver.
Old 09-16-20, 07:10 PM
bike_boy
Lula Mae = 15 lbs.
bike_boy's Avatar
It's all good. Thanks for your input. LBS gave me a spare rear wheel until freehub & bearings come in for Boost 148 hub.
I may still look into getting DT Swiss 350 hub in a few months
bike_boy is offline
