why grease seat post?
I've read that greast helps prevent rust and keeps the post from "freezing" in place.
As a casual biker, will I really need to adjust the seat height? Is the point that the
seat may slip down and then freeze in a spot that's too low for my body?
On Your Left
Quoted: 3004 Post(s)
Liked 2,433 Times
If you have a carbon fiber bike, it won't rust.
Forum Moderator
Quoted: 3090 Post(s)
Liked 6,599 Times
Over time, metals like an aluminum seatpost and a steel seat tube can fuse through oxidation or bind through friction. Simply applying a coat of grease between the two provides a barrier against corrosion.
https://www.missionbicycle.com/blog/...st%20corrosion.
Likes For cb400bill:
Likes For ofajen:
Quoted: 7652 Post(s)
Liked 3,473 Times
I have heard it called "galvanic welding" or something .... but a seat post can bond electrically with the seat tube, and you will go through all kinds of backyard mechanical improvisations and uncivil vocabulary exercises before you get the sucker free ... and sometimes you will do irreparable harm in the process.
From what I hear .....
Likes For Maelochs:
Quoted: 4227 Post(s)
Liked 2,488 Times
vespertine member
Bikes: Yes
Quoted: 687 Post(s)
Liked 220 Times
Quoted: 6963 Post(s)
Liked 10,963 Times
Likes For Koyote:
Clark W. Griswold
Quoted: 4355 Post(s)
Liked 3,994 Times
Because every single mechanic on the planet will want to kill you for allowing parts to seize.
For aluminum or steel posts in aluminum or steel frames use grease
For titanium use anti-seize/copper paste
For carbon posts or posts in carbon frames use carbon paste
Don't let your seatpost or any other parts get seized on any of your bikes.
Quoted: 1068 Post(s)
Liked 786 Times
Quoted: 18415 Post(s)
Liked 15,545 Times
The real question is: Why not do it?
Likes For indyfabz:
SE Wis
Quoted: 2747 Post(s)
Liked 3,395 Times
Half way there
Quoted: 986 Post(s)
Liked 880 Times
Never have to adjust a seat post? This is dreaming. I have to drop my saddle to prevent interference when transporting 2 bikes on my platform rack. Even if you don't have to do this, a change of saddles, pedals, or shoes will have you making small adjustments. Stuck seatposts are not common, but so easy to prevent with a dab of grease. Just do it!
Likes For Moe Zhoost:
A small amount of grease will help prevent the post from sticking in the frame. It actually helps keep it tighter also. I was a bike mechanic in my younger days and we greased the posts of every bike we assembled.
A guy I know bought a used steel fat bike. He needed to use lye to dissolve the old seat post to get it out.
Quoted: 7348 Post(s)
Liked 2,470 Times
You may think you have it set at the right height, but much later, you may need to change it. You may discover it's been too low or high for years. Or you may want to loan your bike to someone. You may want to sell it or give it away. You may want to take the seat post and seat out to jam it into a cramped car or other small space. Grease the seat post every year to prevent this problem.
Quoted: 1062 Post(s)
Liked 665 Times
Amusing anecdote: I went to a bike auction a few years ago, to raise rent money for the bike co-op. I bought a couple bikes for parts. Two or three of the people, including me, had brought a small number of tools and were checking seatposts. A stuck seatpost meant the bike went back on the pile, no bid.
Chemistry 101
Specifically lithium grease creates a barrier between aluminum and steel (iron alloy). Whenever the outside electrons of two elements adds up to 7, an ionic bond occurs (galvanization). Same reason why you put Never-Seize on spark plugs.
Likes For bg18947:
Old fart
Quoted: 3588 Post(s)
Liked 3,400 Times
Perhaps at some point you will replace the current saddle with one that has a slightly different rail-to-saddle-top distance. Or perhaps you will suffer an injury or age-related change that limits your knee range of motion, requiring a shorter crank arm and different saddle height. Perhaps you want to sell the frame to someone else who needs a different saddle height. And so on…
The same phenomenon happens with modern automobiles and their aluminum suspension parts too. Ever try to replace a wheel bearing hub in an aluminum steering knuckle, if you live in the salt belt? I've had to remove the steering knuckles from the car and chisel out the bearing from behind a few times. This was never a problem on older cars with steel (or is it iron?) components. The dissimilar metals we see now react with the moisture and salt almost as if they've been welded together.
Quoted: 2604 Post(s)
Liked 1,933 Times
I think I recall reading that greasing the seatpost (lightly, please!) also helps prevent binding when you're tightening the bolt. There's supposedly a possibility that with a dry seatpost, it'll grab the seat tube so that you'll tighten the bolt to spec. Then you get on the bike, start riding, and the vibration shakes the seatpost free, which then falls under your body weight.
Am I remembering correctly, or just dreaming?
