Are these french threaded?
Quoted: 830 Post(s)
Liked 1,062 Times
Sorry to start yet another thread relating to my Motobecane build woes- but it's almost done! These pedals were given to me off of what I was told was an early 70s Pugeot. However, the spindle ends say L and R not D and G. They need to go on stronglight 93 cranks. Is there an easy way to test without risking damage?
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3846 Post(s)
Liked 6,437 Times
The axles should be standard thread and the cones should be french.
Quoted: 3781 Post(s)
Liked 3,284 Times
pedals are model 36
pedals are model 36
Disraeli Gears
If you screw a French (one of the two standards: M14 x 1.25) into an Imperial (the other standard: 9/16-20) crank, it will be a bit wobbly, because while the thread pitch is close, the Imperial has about a 2% larger diameter. Threads (both internal and external) should be clean when you try this. You shouldn't be able to screw an Imperial-threaded pedal into a French-threaded crank without brute force. A French-threaded crank can be retapped easily for an Imperial-threaded pedal, but not vice-versa (obviously).
"The great thing about standards is that there are so many to choose from".
Bikes: Masi, Olmo, Miele, Masi, Masi
Quoted: 40 Post(s)
Liked 34 Times
I just took a measurement from some French threaded Lyotard pedals and they are .639". For contrast a pair of Look pedals measured .654" The French threaded pedals will tread into a bsc crank loose then appear to tighten up at the end of the thread, but I wouldn't ride on them that way. The Look pedals won't go into the french (stronglight 93) crank at all.
Quoted: 822 Post(s)
Liked 1,387 Times
How about - gently - taking a known set of English pedals and seeing if they'll fit the Stronglights? If they don't go on at all, fine, the cranks are French threaded. As far as these Lyotard pedals go, I would suspect the L and R indicate 9/16/BSC/ISO threads, because the comparable Lyotards on my outrageously French Liberia are marked D and G. You can gently thread these Lyotards into a known BSC crank and see if they feel loose nor not.
FWIW, the only Stronglight 93s I've owned that were French-threaded were on Peugeot PX-10s; all the others had English threads either because (a) someone decided bikes sold in the Anglosphere markets should have 9/16 threads or (b) someone ran some 9/16 taps through to convert them.
Quoted: 830 Post(s)
Liked 1,062 Times
If not, this A08 is near me and I can pick it up for $20 and use the pedals if they look like they’ll clean up alright.Anybody have an idea if they’d be French threaded? Looks like a 75-76ish model.
Old fart
Quoted: 3571 Post(s)
Liked 3,367 Times
QUOTE=polymorphself;21704262]Ah, meaning they wont work, correct?[/QUOTE]
Stronglight crank arms were marked with thread spec on the back side. "14 x 125" is metric (aka "French") thread; 9/16 x 20F is English. Unless you are the original owner, it is possible that a metric-marked arm has been re-tapped to English thread.
Quoted: 830 Post(s)
Liked 1,062 Times
Ah! Well that solves it then. These are metric. 14x125 stamped on them. The Japanese pedals I have just barely begin to go in and then stop, as expected.
Thank you! Hopefully the pedals on the above A08 are French and work out for me...
Bikes: More bikes than riders
Quoted: 1438 Post(s)
Liked 749 Times
I'm pretty sure those pedals with have English threads. I have a similar mixte (from '70), and I replaced the cottered crank and spindle with a square taper spindle and a Sugino crankset, and I'm using the original pedals. The threads don't have a loose fit, and they've been in there for over a year now (I think they'd have backed out by now).
Quoted: 830 Post(s)
Liked 1,062 Times
Friendship is Magic
Bikes: old ones
Quoted: 26247 Post(s)
Liked 10,229 Times
...I have asked this question before of someone, but ever adventurous, I will ask again. Is there some specific reason you don't want to rethread these cranks a little larger, to the now standard 9/16 ? As already stated above, it's easily done, and the only person who will be able to tell looking at the bicycle is you.
I have some French threaded pedals I will never use, if you want them. But they are not those flat platform Lyotards. I'm of the opinion that retapping to 9/16" makes a lot of practical sense in 2020, unless you enjoy the adventure of shopping on the French ebay site.
Quoted: 830 Post(s)
Liked 1,062 Times
Us SPD pedal to FRENCH threaded ADAPTER
On the internet, Amazon, etc, I can see extender adapter for pedals. Are there US to FRENCH threaded pedal adapters? Not too long and weak.....
if not, It would be easy to do ( for someone who knows how!!!!!) It already exists for 1/2 to 9/16.
I love my “new” 1987 Px10 Peugeot, but it’s reAly awkward to pedal without SPD pedals....
thank you!
Quoted: 1629 Post(s)
Liked 814 Times
Hi! First post, and I saw a lot of discussion about that topic, but I haven’t found anything about this:
thank you!
thank you!
72 Line Seeker
83 Davidson Signature
84 Peugeot PSV
84 Peugeot PY10FC
84 Gitane Tour de France.
85 Vitus Plus Carbone 7
86 ALAN Record Carbonio
86 Medici Aerodynamic (Project)
88 Pinarello Montello
89 Bottecchia Professional Chorus SL
95 Trek 5500 OCLV (Project)
72 Line Seeker
84 Peugeot PSV
84 Peugeot PY10FC
Bikes: Indeed!
Quoted: 1504 Post(s)
Liked 3,443 Times
thank you!
thank you!
As a check you could try threading your SPDs into the cranks. If the cranks are French thread you won't get very far.
2. As mentioned above, you can tap out French threaded cranks to 9/16". To find someone who can do this for you look for the oldest bike shop in your area, or let us know your location and one of us might be able to help out.
Brent
Definitely nothing against it! I just don't know how to do it, or quickly I could find a shop to do it. I'm very pressed for time on finishing this. and basically need to figure out the pedal solution by today or have some on the way to me that will arrive before end of week. Will any good shop be able to do this?
