Are these wheels toast ?
Old 09-22-20, 09:45 AM
Tomm Willians
Tomm Willians's Avatar
Bikes: Subject to change at any given moment but currently is...... Colnago Mapei, Colnago C40, Wilier Triestina Carbon, Wilier Triestina Ramato, Follis 472, Peugeot PX60, Razesa, Orbea Terra, Soma Pescadero and 1/2 owner of a Santana tandem.
Quoted: 331 Post(s)
Liked 782 Times in 264 Posts
Attached is a pic of the braking surface on a set of Mavic GEL 280 36 spokes mounted on my vintage Wilier. Both front and back wheels show this characteristic where they seem slightly dished and it seems to take place consistently between the spokes. Can they be trued? Time to replace ?
Tomm Willians is offline
Old 09-22-20, 09:53 AM
cxwrench
cxwrench's Avatar
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times in 1,489 Posts
'Truing' won't fix that. It's totally normal on those light rims.
cxwrench is offline
Likes For cxwrench:
Old 09-22-20, 04:29 PM
Kimmo
bike whisperer
Kimmo's Avatar
Quoted: 1523 Post(s)
Liked 716 Times in 508 Posts
If you can't decide to like the look of it (I've always thought it looks pretty cool}, you could hit the brake tracks with an orbital sander or something and remove the anodising altogether.
Bare aluminium is significantly grippier than that old school hardox surface, particularly in the wet, but it'll wear significantly faster too. The hardox is great protection against the awful galling you get when a little bit of grit stuck in the brake pad snowballs into a chunk of aluminium.
Kimmo is offline
Likes For Kimmo:
Old 09-22-20, 05:00 PM
Tomm Willians
Quoted: 331 Post(s)
Actually I do find it kind of attractive, I was just hoping it didn’t mean my wheels were at their expiration date.
Old 09-22-20, 05:09 PM
aggiegrads
Quoted: 336 Post(s)
Liked 309 Times in 180 Posts
It looks like the rim has a wear indicator in the center of the track. If that is still visible, you should still have some life left.
aggiegrads is offline
Old 09-22-20, 05:56 PM
Pop N Wood
Quoted: 667 Post(s)
Liked 529 Times in 355 Posts
So how does one measure the thickness of an old rim like that to know for sure?
I can't see the wear indicator in that picture.
Pop N Wood is offline
Old 09-22-20, 06:00 PM
Atlas Shrugged
Quoted: 1242 Post(s)
Liked 1,318 Times in 671 Posts
This is a perfect way to destroy a set of wheels and brake pads! Your rim will have traces of abrasive embedded in it post sanding which will embed itself into the brake pads destroying any future rims they will be used on as well.
Atlas Shrugged is offline
Old 09-22-20, 06:39 PM
sweeks
sweeks's Avatar
Quoted: 980 Post(s)
Liked 580 Times in 398 Posts
It's the black line running circumferentially at the middle of the brake track. When the rim around the line has worn away, there's usually less than a millimeter of metal remaining.
Another way to evaluate rim wear is to place a straight edge across the brake track in a "radial" orientation. A pronounced depression in the center of the track is suggestive of wear approaching the need for replacement.
If your rim produces a "thumping" sound or feeling when the brake is applied, it's time to get a new rim.
EDIT: See THIS.
sweeks is offline
Likes For sweeks:
Old 09-22-20, 07:33 PM
cxwrench
cxwrench's Avatar
Bikes: lots
EDIT: See THIS.
There was absolutely NOT a rim wear groove on these rims. It was still years away when these were current. These rims don't have that much wear yet...they're not bad at all.
cxwrench is offline
Old 09-22-20, 08:04 PM
Shimagnolo
Shimagnolo's Avatar
Quoted: 3369 Post(s)
Liked 5,483 Times in 2,841 Posts
The best way I've found to clean up a brake track is a Scotch-Brite pad (or generic equivalent).
Much easer to do with the tire off, so you can wrap the pad around the rim and clean both brake tracks simultaneously.
Shimagnolo is offline
Likes For Shimagnolo:
Old 09-22-20, 08:06 PM
sweeks
sweeks's Avatar
Quoted: 980 Post(s)
The rim wear indicator is a feature of the rim. It is not the result of wear. See THIS.
sweeks is offline
Old 09-22-20, 08:36 PM
cxwrench
cxwrench's Avatar
Bikes: lots
There. Was. No. Rim. Wear. Indicator. On the 280/330 rims. Trust me on this, I've built dozens of sets. This is not my first rodeo as they say.
cxwrench is offline
Old 09-22-20, 08:52 PM
sweeks
sweeks's Avatar
Quoted: 980 Post(s)
I defer to your greater expertise.
sweeks is offline
Old 09-22-20, 08:54 PM
cxwrench
cxwrench's Avatar
Bikes: lots
Thanks. If you don't know for sure, do a little research...there are hundreds of photos online of those rims. The 280/330/SSC rims were made looooooong before indicator grooves or dots were a thing. Like decades before.
cxwrench is offline
Old 09-22-20, 09:30 PM
ThermionicScott
working on my sandal tan
ThermionicScott's Avatar
Quoted: 3870 Post(s)
Liked 2,563 Times in 1,577 Posts
I'd be hesitant to remove any material on these rims if I didn't absolutely need to. They started out only 0.8mm thick.
Originally Posted by chandltp
Originally Posted by noglider
RUSA #7498
ThermionicScott is offline
Old 09-23-20, 04:19 AM
Pop N Wood
Quoted: 667 Post(s)
I would never take a power sander to a set of rims, but I have cleaned them with scotchbrite pad like someone mentioned.
I do use a sander on brake rotors when they get badly glazed, both bike and auto. But I always use a garnet sand paper meant for wood. No metal oxides to work into the metal that way.
Old 09-23-20, 04:28 AM
Pop N Wood
Quoted: 667 Post(s)
EDIT: See THIS.
Thank you. Good info
As for the "thumping" sound, I've had that happen on both bikes and automobiles when an uneven layer of pad material is deposited on the rotor/rim. This is why lots of people advocate "bedding" new brake pads, to get an even layer giving a braking surface with uniform grab.
I've fixed this on bike rims by cleaning the rim with a scotchbrite and some solvent. With car rotors the deposits are usually very visible. I've cleaned them with some success with a sander and garnet sand paper, but anymore now I have better luck replacing the rotor.
Old 09-23-20, 08:46 AM
cyccommute
Mad bike riding scientist
cyccommute's Avatar
Quoted: 6193 Post(s)
Liked 4,192 Times in 2,352 Posts
There is clearly a wear indicator on that rim.
The black line, indicated by the red arrows
Stuart Black
cyccommute is offline
Old 09-23-20, 09:03 AM
cxwrench
cxwrench's Avatar
Bikes: lots
No. That is not a wear indicator. As I've posted a few times wear indicators were not a thing when these rims were made. That groove, like all the others on this rim, is from wear, not manufactured. Stop posting incorrect information and do some research. Find a photo of a 280 or 330 rim with proof of a wear indicator. It's black because it has pad material in it. If it was a manufactured groove it would be thinner where the eyelets are and deeper between the spokes, following the rim wear. But...wait for it...it's the opposite. These rims are thin enough that they 'oil can' as they wear. That's to say they wear more where the eyelets are and slower between them. It's easily seen on many photos. Take a look at some photos and get back to me.
cxwrench is offline
Old 09-23-20, 09:58 AM
cyccommute
cyccommute's Avatar
No, that line in not from “wear”. It is too uniform to be made by any wear mechanism. Something imbedded in the pad would make a groove that is varies more. Look at the wear mark on the rim right above the second arrow. It is small and of variable depth and width. The black groove is even and follows the rim arc exactly. Perhaps Tomm Williams is mistaken about the rim model. The one in the picture has a definite wear indicator groove in it.
The line is black because it was anodized. And why would it be thinner or deeper? The groove is machined into the rim and they don’t vary the depth or thickness. A uniform groove is much easier to machine than one that varies. The groove looks like the ones in this chart. And, if the groove were a wear groove it should vary in depth and width as you’ve described. A uniform groove won’t form from braking.
To quote someone “this is not my first rodeo”,
Stuart Black
Old 09-23-20, 10:06 AM
cxwrench
cxwrench's Avatar
Bikes: lots
Have you looked at any photos of these rims? I'm telling you that these rims NEVER had a wear indicator groove. I've built many wheels with them. Find a groove in these rims...you'll find the exact same rim surface on the 330.
ETA: You can't have a groove machined in these rims because Mavic hadn't even started machining the brake track yet. The rims were extruded, pin and glued and that was it. No welding, no machined brake track, no wear indicator.
cxwrench is offline
Old 09-23-20, 10:26 AM
cyccommute
cyccommute's Avatar
Yes, I have looked at the rims in question and I agree that they don’t have wear indicators. But I have also looked at Tomm Williams‘ picture and there is clearly a wear indicator groove on them.There are gouges from braking as I’ve pointed out but no wear pattern would result in a groove that is uniform in size and shape across a large arc of the wheel. It covers at least 5 spokes in the picture with an even size and evenly spaced from the outside and inside of the rim. That’s about a 30cm arc of the wheel to cover.
Additionally, the rims that Tomm Williams shows have clearly been milled. The transition from the spoke bed to the sidewall in the pictures you show are gentle curves while Tomm Williams’ rims have a very sharp transition that is typical of milled sidewalls.
The rims are obviously not the model of rim that
Tomm Williams thinks they are.
Stuart Black
Old 09-23-20, 10:30 AM
mrrabbit
mrrabbit's Avatar
Bikes: 2001 Tommasini Sintesi w/ Campagnolo Daytona 10 Speed
Quoted: 145 Post(s)
Liked 35 Times in 30 Posts
Mavic GEL series from the 80s and 90s do not have wear indicators.
What's really shocking about the OP photos is that it doesn't appear super light double butted spokes were used.
They appear to be straight 14g or straight 15g.
Normally these would be built with something like 2.0/1.5/2.0 on the front and 2.0 / 1.65 / 2.0 on the rear.
Ugh!
=8-(
5000+ wheels built since 1984...
Disclaimer:
1. I do not claim to be an expert in bicycle mechanics despite my experience.
2. I like anyone will comment in other areas.
3. I do not own the preexisting concepts of DISH and ERD.
4. I will provide information as I always have to others that I believe will help them protect themselves from unscrupulous mechanics.
5. My all time favorite book is:
Kahane, Howard. Logic and Contemporary Rhetoric: The Use of Reason in Everyday Life
mrrabbit is offline
Old 09-23-20, 10:33 AM
easyupbug
Quoted: 566 Post(s)
Liked 560 Times in 404 Posts
Originally Posted by Tomm Willians
...Both front and back wheels show this characteristic where they seem slightly dished and it seems to take place consistently between the spokes. ?
OP, to your questions I had a set and early in their life at each spoke the anodizing wore off first, kind of leaving aluminum bare spots around the rim which could lead you to believe the rims were dished between spokes; I suspect due to deformation from the spoke tension it was the opposite, the rims flared out at the spokes. I also think that is an ugly grove but not a wear indicator and you likely have good good miles ahead.
Oh, and you can measure rim thickness in various spots if it bothers you.
easyupbug is offline
Old 09-23-20, 10:38 AM
cyccommute
cyccommute's Avatar
While I disagree with cxwrench...and with you...about the model of the rim, I do agree with him that what you are seeing is “oil canning”. The eyelets area is resists bending while between the eyelets is somewhat softer. The rim bends slightly as the brake slides over the spaces between the eyelets then flares out again. The result is a slight pulsation of the brakes that you likely won’t feel but it results in an odd wear pattern. There’s nothing really wrong with it. Check the rims occasionally for straight walls by putting a straight edge on them. If they cup, replace them. Otherwise just ride.
Stuart Black
