Crank removal
Bikes: 1980's Spectrum 10 sp Campagnolo Centaur, 1990 Eddy Merckx 10 sp Campagnolo Centaur, Bushnell Tandem, Co-Motion Speedster Tandem
Quoted: 185 Post(s)
Liked 102 Times
Crank removal
I picked-up a bike which I'm planning to use the parts as modern build on a vintage bike. I've only ridden and maintained vintage bike where the crank fixing bolt was removed by loosening a 14 or 15mm bolt and then a crank puller tool that threads into the crank. Is this taken off the same way by just loosening the allen head bolt or is it done differently. I've heard some have a self removing capability that if not done right might mess things up. Thank you for sharing your knowledge!
Quoted: 645 Post(s)
Liked 797 Times
Looks like a standard Campag crank bolt. All of my Campag cranks (8sp-10sp) were/are set up this way. Remove the bolt counterclockwise with a 8 or 10mm (can't remember) Allen wrench, make sure to recover any washer that might be in there, then use a standard crank puller to remove the crank. Don't forget to grease the puller threads and screw it in all the way before you start leaning on it.
Quoted: 185 Post(s)
Liked 102 Times
Thanks, this gave me confidence as I was pulling the crank and bottom bracket.
Likes For Paul J:
Quoted: 668 Post(s)
Liked 529 Times
Man, pretty frame. I love a lugged frame.
