Group Advice
Group Advice
Now that the triple seems all but dead in the mid to high range groups what is everyone using? Personally I used Campy 10 sp triples. The prices have climbed to absurd levels. I have no brand preference anymore. Just looking for something with a low gear for a 62 year old guy.
I’m a little Surly
Quoted: 699 Post(s)
Liked 1,299 Times
I just swapped to some Veloce ergos and rear derailleur with a 10sp XT 11-34 cassette and mountain bike crank w/36 & 44 chainrings normally and 22 & 34 when needed.
Quoted: 3503 Post(s)
Liked 1,489 Times
A friend of mine bought a new trike a year ago, I was surprised it came with a triple, crank is a FSA brand, I do not know the model. His is a road triple.
Your Campy cranks if they were the older square taper would have been road triples (52/42/30). But you desire low gears. Does that mean you want a mountain crank instead of a road crank? Or do you want a lower cost road triple?
If you buy a square taper crank, note that Campy uses an ISO square taper, other brands use JIS. Meaning you should not mix your Campy square taper bottom brackets with a non-Campy crank.
If you do not see what you like out there, do not rule out a low budget Vuelta from Amazon. I am using Vuelta crankarms from a square taper compact double on my Rohloff bike, they work just fine.
For non-Campy square taper cranks, I am very happy with Shimano UN-55 bottom brackets. You would need a Shimano type bottom bracket tool, your Campy bottom bracket tools won't work.
Galveston County Texas
Bikes: 02 GTO, 2011 Magnum
Quoted: 1354 Post(s)
Liked 1,249 Times
Mountain Bike Triple 22/32/42 sale - Google Search
FMFXTR 24/32/42t 3X10 Triple Speed 104/64bcd MTB Bike Crankset Crank Chainring | eBay
Fred "The Real Fred"
I know there are cranks available but long cage rear derailleurs and shifters for a triple are gone. Shimano makes Tiagra, SRAM and Campagnolo have abandoned it. Plus Shimano front derailleurs seem to work best with a 53T big ring. Their MTB fronts are not compatible with road shifters. I am not interested in barcons for this build. Sadly I seem to be SOL.
Liked 1,249 Times
Liked 1,489 Times
Regarding long cage rear derailleurs, there are tons of used ones. I like the look of the 1990s vintage XT rear derailleurs, have them on several bikes plus a few spares on the shelf. Pick something that looks nice, check to see what the cable pull ratio is on it and try it if the math looks good.
Science Behind the Magic | Drivetrain Compatibility ? Art's SLO Cyclery
Jtek adapters can be used to change cable pull ratios if you are trying to mix and match.
And for touring and a heavier bike right?
Sunshine
Quoted: 11046 Post(s)
Liked 7,595 Times
Shimano Sora 3x9 STI
Shimano Alivio FCT4060 crankset 48x36x26t
Shimano Sora R3030 front derailleur
Shimano Alivio M4000 rear derailleur
Shimano Alivio or another 9 speed cassette with gearing you want
various 9 speed chain
A Sora triple FD works perfectly fine with an MTB crank with trekking gearing like the one listed. Im pretty sure the spec above is standard on Surly DT and Trek 520.
Likes For mstateglfr:
Quoted: 2629 Post(s)
Liked 1,974 Times
I hate feeling rushed to buying another bike so I can get something like mstateglfr lists. (Though I might get a Sugino crank instead...) In the meantime, my bikes have triples and they're still rideable -- so that's what I'm riding!
n00b
Bikes: Surly Karate Monkey, Twin Six Standard Rando
Quoted: 428 Post(s)
Liked 466 Times
some ideas:
Velo Orange
Rivendell
Sunrace
Interloc Racing
since all of these are making triple cranksets, I'm willing to bet that a phone call or email to them will give you some good ideas of how to set them up with shifters and derailers.
Velo Orange
Rivendell
Sunrace
Interloc Racing
Liked 1,489 Times
I am confused, a Campy brifter, a Campy rear derailleur, why is there a Jtec adapter? Or, is that a cassette with Shimano/Sram sprocket spacing?
On my rando bike I am using a Campy 10 speed brifter for the rear with a Shimano XT derailleur and 8 speed Sram cassette. The cable pull per shift with a Campy 10 speed is almost identical to a Shimano 8 speed system, thus no Jtec adapter needed.
I’m a little Surly
Quoted: 699 Post(s)
Liked 1,299 Times
Mad bike riding scientist
Quoted: 6254 Post(s)
Liked 4,280 Times
Microshift makes triples stuff in 8, 9, and 10. They have shifters as well as front and rear derailers in all three. Perhaps not as good as Shimano but I’ve worked on bikes with Microshift and they seem to work fairly well.
I think you are being overly broad on Shimano front derailers. I’ve used Shimano fronts on outer rings as small as 46 teeth without problems. I would suggest that you don’t look at any of the higher end Shimano front derailers, however. The higher end Shimano front you use...road or mountain...the more finicky it is. Shimano’s Tiagra or below fronts work well and are easy to set up. 105 and above have issues. I’ve use Tiagra and Sora, as well as Microshift, and have had very good experiences with them.
Stuart Black
Stuart Black
Clark W. Griswold
Quoted: 4445 Post(s)
Liked 4,102 Times
If I were you I would look at a Sugino Alpina2 Triple or René Herse cranks (which can be had in whatever gearing pretty much)
For derailleurs I would probably go XT 11 speed at the rear and if you can get it a CX-70 at the front but if not maybe consider a GRX and potentially a slightly longer spindle B.B.
For shifters the choice is easy Gevenalle GX shifters which use a bar-end/downtube shifter on the front of a brake lever so you get a proper brake lever and a really handy shifter one of which is friction which I think is better for triples anyway. You can also do a Hydraulic version as well that uses TRP Hylex calipers. The nice thing is you have MTB shifting on a drop bar without any odd adaptors.
Sadly full group sets are rare in touring. Shimano sort of comes a little close with the T8000 Trekking gruppo but mostly that is found in Europe and is flat bar so you would need to use a different shifter or adapters for drop bar.
Personally though I would go with a 2X11 (or maybe 12) similar set up as above but ditch the triple and use a White Industries (or other crank with customizable chainrings) and a wide range cassette. You may not get quite as low of a gear and not as high but you can get a pretty close range. I am planning a 44-30 with an 11-42 out back and that does get me most of my triple that I need most of the time and honestly for the bike it is going on it plenty and if I needed more I could do a 28 at the front or 11-46 at the back and be fine.
Likes For veganbikes:
Liked 4,280 Times
That said, the lack of a coherent group for either I see as a plus. I push the limits when it comes to gearing range and being able to mix and match enables me to do things with gearing that Shimano never envisioned.
I’d stick with the triple, use a 9 or 10 speed, and forgo that extra gear or two. The gearing is tighter and more useful over a wider range of terrain.
Stuart Black
Stuart Black
Although it’s hardly a news flash, I really hate wide range doubles. Yes, they have the range of a triple but they have a giant hole in the middle of the range that requires a lot of jiggering after a shift between rings to get the gear you want. It’s all herky jerky where a triple is nice and smooth. It’s almost like the people who design 2x systems have not idea how gears work on a bike.
Clearly 11 and 12 spd stuff will most often have cassettes with jumps very similar to 9 spd, but with those added higher teeth counts, so they can be fine all in all.
But as you say with the underlined statement, you do have to wonder about the thinking going on. Im sure a big part of it is economy of scale, and reducing product lines to streamline production over lots of bikes.
I wonder though how much of it is just going with joe or jane blow rider who just doesnt get using a triple, and so simplifiying stuff appeals to a lot of casual riders.
I know we sound like a bunch of grumpy old bastards who dont accept new stuff, but a triple for touring still really does have real life advantages--especially if you take into account not only having a wide range of gears, which is just plain nice, but then also the possibility of having closer shifts due to more gears---that said, I still dont have personal experience past 10 spd for chain longevity etc, so I cant really say how 11 spd is in real life, let alone 12.
Liked 4,280 Times
I mountain bike as well and I don’t see the appeal of 1x there. It’s okay if you ride loops around the bike park or if you are racing a circuit, I suppose. But I ride over long enough distances that having a wide range of gears is worth the (slight) complication of the triple.
I once read something in Adventure Cycle magazine from the guy at SRAM who is the force behind going to 1x. He said that changing the chainwheel on a 1x completely changes the character of the bicycle. I fully agree. What if you carried along the chainrings and had the is nifty little device that switches between those chainrings? It would completely change the character of the bike. Why has no one invented such a system?
The other issue is that component manufacturers are racing companies who also happen to sell some bike stuff. Racers have looked down on triples forever. Even the low gear is derisively called a “granny” gear because only old grannies need one. I have not problem using a low gear...even a lower gear than most people even think is possible. It doesn’t challenge my manhood to do so. I’m actually kind of proud to have a 730% range...from 114 gear inches to 15 gear inches. I can ride up most anything and down have to coast down the other side.
Stuart Black
Stuart Black
Likes For cyccommute:
Last year I ran a Suntour XC Pro triple crank with 10 speed rings on it with my Record 11 speed Campagnolo drive train and it worked just fine. I did not set it up with the granny gear, but am certain that I could if I played with it enough. There are all sorts of combos that will work, new as well as old stuff.
Clark W. Griswold
Liked 4,102 Times
There were full(ish) groups for touring bikes in the 80s. They got used on mountain bikes. Shimano and SRAM really screwed the pooch when they decided to change everything. Shimano going to Dynasys was just stupid and SRAM’s fascination with 1x drives me up the wall. I have 9 and 10 speed systems in both brands and I really like the way SRAM works but I’m not going to 1x.
SRAM going 1x isn't hard to figure, their front derailleurs where never that great and maybe that was down to patents but probably down to SRAM just not really wanting to have a proper FD.
Yeah with any set up you can have gaps but I do like 1x in certain situations obviously long distance touring, no thanks but it does have a place. It will not have all the gears and that can suck but it also makes the ride interesting. A wide range 2x isn't so terrible but yes not quite as smooth as a 3x but it can be a bit simpler and still be workable. Maybe with STI levers it might not be as fun but thumb or trigger shifters aren't so bad.
Liked 4,280 Times
I don’t agree about SRAM front derailers, however. At least not for mountain bikes. From top to bottom of the line, SRAM X series works wonderfully. Same can’t be said for Shimano. Their XTR carbon fiber E-type derailer has to be the most useless expensive derailer around. If you had one, I can see why you wouldn’t want front derailers. Their expensive road and mountain derailers are about the same. When I have Shimano systems, I don’t go above Tiagra for road or above Deore for mountain. And, in mountain, I avoid using bottom swing as much as possible. Oddly enough, SRAM bottom swings work fairly well and are on the same par as SRAM’s top swing.
Stuart Black
Stuart Black
Are triples really going away? I haven't been out of the middle ring on my bike for about twenty years, but I always felt like a rebel for that. I guess now I'm just ordinary.
