Wahoo Element Mini
#51
Quoted: 21 Post(s)
My Mini is 1.10.3. (227)
Speed sensor 1.2.39
So I reached back out to Brad who is the tech in charge of the issue I was having and asked him about the version numbers and to verify that I am on the latest.
He said that the developers did release a patch to fix the issue however like other software vendors, it may or may not have bumped up the version number as it was just a patch. He did verify that the versions I have above are the latest.
All I can say is I put it through its paces and I do not have the problem anymore. Is that the same version you have? And are still having the issue of deleting pages?
#52
Quoted: 377 Post(s)
Liked 221 Times
What attracted me to the Mini is the battery, the fact the battery can be changed by the user, it's size (I like smaller computers) and the fact that it's basic in nature. The more bells and whistles, the higher the chance of firmware bugs. After years of fiddling with Garmins, I want simple, easy and works as intended.
Is that the Mini? Don't know yet as today will be my 1st ride with it.
The Bolt is a fantastic computer and should meet your needs now and in the future if you think you'll want or need the extras it provides.
#53
Quoted: 377 Post(s)
Liked 221 Times
Well here is the odd thing. After you asked this, I started looking through the data of my past rides when I had the issue and the rides since it was fixed... and the firmware version is the same.
Speed sensor 1.2.39
Speed sensor 1.2.39
#54
Quoted: 11 Post(s)
Liked 5 Times
Actually the Background app refresh lets the app stay running with wifi or cellular which is why it needs to stay on while riding if you want the app to track your route. I have mine set the same as yours... only use location while using the app. I also turn off background refresh when I'm not riding to preserve battery during the day. Thats not an Elemnt thing.... that an Iphone thing. Until I started using the Wahoo app, I never turned on the refresh.
I have been used to selectively disabling background refresh for individual apps. I just found the global control for background refresh in settings-> general. I can try that.
#55
Quoted: 377 Post(s)
Liked 221 Times
Today's ride was 2 hours and 29 minutes. The battery on my Sony Z5 Compact was at 100% when I left and after the ride was over it was at 86%. So using the phones GPS to track the ride used up a total of 14% over 2 1/2 hours. Not bad at all I'd say.
The recorded GPS track was fine for the most part. I expected, and got, issues when downtown amongst the tall buildings. Nothing wonky or major just some minor GPS track drift.
Speed and total distance were about what I expected but auto pause does take a few seconds to kick in once stopped. Not a huge deal but it's not instant either. Also when slowing or accelerating, the speed lag slightly behind. Again not a big deal but something to consider.
One bummer, and I sent a feature request to Wahoo earlier, is when a text message comes in it only displays for a few seconds then goes away. I got 3 messages during my ride but only saw one in time before it cleared off the screen. On the Bolt, you can access missed messaged in the settings screen but since no such screen exists on the Mini, if you are not staring at the screen when an SMS comes in you'd never know you had missed one. Hopefully, they can resolve this by leaving SMS on the screen until the user clears it via a button press.
Lastly, the ride did not auto upload to Strava. I had to force the upload via the Wahoo app. I am going to disconnect my Strava account then reconnect before tomorrows ride and see if that helps any.
#56
Quoted: 21 Post(s)
Sounds about right with the GPS moving around and to be expected using a phone. They aren't true GPS units and get the location by triangulating from cell towers. The more cell towers around, the more they will jump from one to another so your location may seem to move. I ride a lot out of the city and the routes tend to be very accurate.
I see the same slight lag in starting after the pause. Not bad though. I think the feature request you sent would be nice.
#57
Quoted: 377 Post(s)
Liked 221 Times
Send them a feature request. The more who ask for it the better the chances of getting it implemented.
https://support.wahoofitness.com/hc/en-us/requests/new
#58
Quoted: 4259 Post(s)
Liked 1,361 Times
Smartphones have GPS receivers and work fine without any access to cell towers.
GPS is a bit slow to get an accurate initial fix. The triangulation helps with that.
Smartphones can also use wifi to assist in getting a fix (there are databases of wifi networks associated with location).
Once an accurate fix is obtained, GPS on smartphones is fast and very accurate (equivalent to a handheld dedicated GPS).
GPS has known limitations in canyons (natural or urban) and heavy tree cover.
#59
Quoted: 119 Post(s)
Liked 23 Times
This is wrong.
#60
Liked 1,361 Times
GPS doesn't work very well inside buildings. WiFi might work inside when GPS doesn't. WiFi location is very approximate. Also, there is no inherent location associated with a wifi router. "Somehow", the wifi SSID has to be associated with a GPS or triangulated tower location and stored in a database. Apple might want wifi on to collect that information.
So, you are generally better-off, sometimes, with wifi on (Apple is trying to make things simple).
Keep in mind that wifi range is very limited. If you are outside, you are typically out of wifi range (having wifi on or off is irrelevant).
Smartphones GPS receivers work as well as handheld dedicated GPS units (basically).
Because smartphones have other stuff, they have some tricks that dedicated GPS units can't use.
GPS units are typically used for relatively long periods.
Smartphones often use location data for quick hits (very short periods of time). GPS doesn't work well for that. That's another reason smartphones also use towers and wifi.
#61
Quoted: 21 Post(s)
This is wrong.
Sorry if I misspoke before. But you are correct.
#62
Quoted: 21 Post(s)
#63
Liked 1,361 Times
People need to be aware whether or not a particular app needs cell service. (I wouldn't really use an app that required cell service.)
But it's easy to find apps that don't need cell service at all.
A dedicated unit does what it does "easily" but what it does is much more limited than a smartphone (a smartphone is a really a fairly general-purpose computer, with the attendant complexity of options).
Dedicated GPS's have "jitter" too. It's noticeable in displayed speed (the units might smooth the location).
The jitter in both will be larger at start up. Smartphones start up frequently. Often, the GPS isn't kept on in smartphones, which means you might see the jitter more frequently.
Using towers (or wifi) is fast but has low accuracy (it's not usable for navigation but it might be good enough to recommend a nearby restaurant).
Using GPS is slow at startup but much more accurate and fast over more time.
#64
Quoted: 3240 Post(s)
Liked 2,086 Times
Never seen that.
What I've seen is that smart phone app's are typically free or very low cost, so there's the advantage of pricing, as well they then replicate what a lot of Garmin units provide.
#65
Liked 1,361 Times
The Garmins are very slow compared to smartphones as well.
KH0456 was talking about smartphones (and said some things that weren't correct) and my reply was to that (you are taking what I said out of context).
Cycling specific computers have the advantage of being smaller, better battery life, and better screens for sunlight. Cycling specific computers also tend to have better sensor support but that wouldn't be hard to add to smartphones (ANT+ appears to work better than BLE but it costs extra and there isn't enough of a market to justify it).
Apps for smartphones haven't quite duplicated the navigation that the Garmins provide. It would be easy to add it but there isn't (it appears) a market for it (partly, because people don't want to spend any money for apps).
For software (which is all that navigation needs), smartphones are a much better platform than the slow/limited CPU's in the Garmins.
#66
Quoted: 377 Post(s)
Liked 221 Times
I did the same route today and my ride time was 2 hours and 31 minutes. My battery started at 100% and at the end of the ride, it was at 90%. So 10% used for a 2 1/2 hour ride.
For today's ride, I changed the location settings on my phone to test out the differences and that may account for the better battery life.
On Android, you have 3 options:
1. High Accuracy (uses GPS, Cellular, and Wifi)
2. Battery Saving (uses Cellular and Wifi)
3. Device Only (uses the phones GPS)
My 1st ride that was previously mentioned, I had the phone location setting to High Accuracy but for today's ride, I set it to Device Only. In device only mode I got better battery life. The tracks are similar and I again saw issues when downtown. Minor GPS drift but nothing wacky or major.
I did disconnect my Strava account and reconnect it but the ride did not auto upload afterward. I again had to force the upload in the Wahoo app.
Android Location Setting Screenshot:
#67
Liked 2,086 Times
"I'm sorry you're having issues with the app. At this time, there is a different login between our web browser and our app logins. You will need to set up a new account to use with the apps. With that being said, however, you can use the same login information as the web browser, but it won't be connected.
From there, you should be able to sync RWGPS to automatically sync your ride results!"
In reality the iOS app version uses the very same RWGPS login info - e-mail and password as the web log-in, you just need to set it up on the app as if it were new. After that all works as intended and all my rides port to RWGPS correctly.
#68
Quoted: 377 Post(s)
Liked 221 Times
I had a similar issue with my Bolt, inability to automatically send a finished ride up to RWGPS. An e-mail to Wahoo yielded this response:
#69
Liked 2,086 Times
Which raises the question as to whether the phone app recognizes the Mini as a separate device to upload. I've no experience with this and in your shoes might be contacting Wahoo,
#70
Quoted: 377 Post(s)
Liked 221 Times
https://groups.google.com/forum/#!to...rs/jynu4LsruQU
Thanks
#72
Liked 2,086 Times
#73
U*icyclist
I saw mention of that but I've not seen any updates come through and the bug is still present on my device. Also, pushing a software update without incrementing the version number sounds... wrong.
I discovered another fun little bug on my Mini. I wanted to confirm that it can store multiple rides on the unit itself, so I switched off Bluetooth on my phone and recorded three dummy rides on the Mini. I made them five, ten and fifteen seconds long to aid identification. When I switched Bluetooth back on they all synced, but the five second ride was duplicated many times. Every few seconds another copy of it would appear on my phone. Factory resetting the Mini fixed it.
I'll do a bit more testing to confirm it's easily reproducible and then report a bug to Wahoo.
#74
Quoted: 377 Post(s)
Liked 221 Times
To update a little more on the Android location settings. Today I rode in both modes, Device Only, and High Accuracy. I started in Device Only mode and noticed the speed lags behind quite a bit. From a stop I'd read zero for several seconds then it would jump to something like 8, then something like 12, then 16 ect. There didn't appear to any shown incremental speed increases.
At my turnaround point I stopped and changed over to High Accuracy. This was much better as far as showing the incremental speed increases and eliminating the lag. There is still some lag but not as bad as in device only mode.
Bottom line:
Device Only gives better phone battery life but the speed displayed on the unit head lags. High Accuracy mode uses slightly more phone battery but reduces the speed lag displayed on the head unit.
Bottom line:
#75
Quoted: 377 Post(s)
Liked 221 Times
Here is a tip to access some internal settings on the Mini:
1. Power on the Mini
2. Press both buttons together and quickly release them
3. The Mini internal setting page will be displayed
Helpful if you accidentally delete the Mini from the companion app and need to repair with the barcode (use the forget phone option) or to factory reset it.
