Tail light for daytime riding
Quoted: 642 Post(s)
Liked 1,526 Times
I want a dang bright tail light as noticeable as possible in full sunlight. Pulsing, strobing, whatever is most noticeable. I need it to last 5 hours and preferably be rechargeable with internal battery.
I currently have a cygolight hot shot but would like something with considerably more oooomph.
I ride rural roads that often have no shoulder and want the ranch hands flying along in their pickups to see me well in advance.
What do you got?
What do you got?
Non omnino gravis
If you have the Cygolite then you're already in good company. I've been researching brighter lights (for daytime running) but none are as flexible nor as compact.
From what I understand there is an update that is even brighter. They also offer the Hot Rod, but its a seadpost mount, which is not tilt adjustable.
Hotshot Pro also...a very bright light.
- Soli Deo Gloria -
Quoted: 6844 Post(s)
Liked 736 Times
Axiom Pulse 60 is pretty bright. Other riders sometimes ask me to turn it down. I run it at the seat cluster.
I also use two Cygolite Hotrod 50's down low, one on each chainstay.
The Axiom Pulse goes on flash and the Hotrods go on low steady. All are good for five hours.
-Tim-
-Tim-
Bad example
Quoted: 824 Post(s)
Liked 208 Times
Two suggestions. One, add a helmet mounted light. Sometimes bike-mounted lights get hidden by other cars. Second, consider putting your rear light on a “stalk” of sorts that sticks out to the left side of the bike. That way people will see it sooner on right hand turns.
LET'S ROLL
I'm happy w/ the 150 version. Looks like they're coming out w/ a 300 version soon:
One day: www.youtube.com/watch?v=20X43026ukY&list=UUHyRS8bRu6zPoymgKaIoDLA&index=1
Two suggestions. One, [size+2]add a helmet mounted light. Sometimes bike-mounted lights get hidden by other cars. Second, consider putting your rear light on a “stalk” of sorts that sticks out to the left side of the bike. That way people will see it sooner on right hand turns.
I've been riding with this setup since the late nineties. The redundancy also serves as backup should one fail or you forget to charger it.
Quoted: 659 Post(s)
Liked 7 Times
Yes, this makes a big difference. AIRC the original Hotshot was rated at about 30 lumens and was followed by various models designated by their lumen output - the Hotshot 50, then 80, then 100, and currently the Hotshot Pro 150. I have both the 80 and 150 and have compared them side-by-side and was surprised by how big a difference there is. The 150 was both substantially brighter in the center of the beam but also covered a considerably broader area.
niteflux redzone 8 is good.
also dinotte makes some good ones.
lupine has a good one.
designshine is the most powerful one in existence.
don't try this at home.
Quoted: 973 Post(s)
Liked 511 Times
I compared the Cygolite HotShot with the newer Pro 150 in this post.
The Pro 150 has a variable speed "short bright flash" mode. At one flash per second, it runs about 30 hours. At 2 flashes a second, about 15 hours.
I normally use the one per second flash during the day -- my goal is for drivers to notice a bike ahead from far away. Or I switch to the two per second rate if the road is curvy or has patchy shade.
It includes some photos:
Quoted: 642 Post(s)
Liked 1,526 Times
...what model HotSHot have you? Because I'm using a HotShot Pro, and have had numerous people-- both on bikes and in cars-- tell me that it is essentially "the brightest thing they've ever seen."
To get brighter, you have to spend a good bit more money-- like, Dinotte money.
the hotshots have a single crappy led and lens concentrating the light in a narrow cone behind it. it doesnt matter if its 10000 million lumen its not gonna be bright from anywhere outside the cone.
get a real light instead. i recommend the older orfos red and the niteflux redzone. these spread light out in all directions around the bike. they both have many many leds and they tap directly into clear plastic to spread the light.
on max you can see these from several miles.
And I'm fairly certain you can only get around 60-80lm or so (or even lower like 50lm) for a single cree red led, the best ones they make. you do the math...
and when pushing them to the max the lumen/w and efficiency and battery life goes down.
this is why all good rear lighrts have multiple leds. dinotte has 4. orfos has 10-15, desighshine had 6, niteflux has 4. and so on
Quoted: 3459 Post(s)
Liked 1,465 Times
Not my bike, I saw it parked somewhere and had to take a photo.
reverse thinking
Makers Headlights of late have been competing with each other for who makes the brightest..
but not so much with tail lights..
you can put a red lens on a headlight and point it rearwards to get that kind of bright..
B&M 4D toplight, rack mount, is big, red , and has 4 LEDs
to light up the whole thing.
but does not blink or flash .. 2 AA batteries in them.
I like them..
I like them..
I like them..
I like them..
thats why they have red leds. the conversion is so inefficient its not done. and to put a spin on it a red led is much much less efficient than a white one is. where you can get 1000lm out a single xlm2 led you get at most 50-100 out of the best red ones. for the same juice.
Quoted: 642 Post(s)
Liked 1,526 Times
The Orfos looks like it might be worth a try but I'm a bit nervous that all their products seem to be pre-order only. In general, I don't put out money for products that may never be available.
dafuq do you mean here really?
when you order something on the mighty "interwebz" you pay in advance. make no mistake.
you will not have the product in your hand before you have paid for it. i can guarantee you that.
Quoted: 642 Post(s)
Liked 1,526 Times
There is a difference between ordering a product that actually exists and waiting for it to arrive and one that may never be manufactured. If a company needs customer money up front before they can manufacture, that is a danger sign to me.
