Go Back  Bike Forums > Bike Forums > Winter Cycling
3 speed IGH winter bike
Winter Cycling Don't let snow and ice discourage you this winter. The key element to year-round cycling is proper attire! Check out this winter cycling forum to chat with other ice bike fanatics.
Old 12-19-18, 03:30 PM
baldilocks
Bikes: Giant ATX Lite & Schwinn Mesa
Quoted: 156 Post(s)
Liked 7 Times in 7 Posts
Can anyone recomend a 3 speed internal gear hub bike for a winter bike. I've considered a inexpensive cruiser, a hybrid or building a single speed 29er MTB into a 3 speed. I've never had a 3 speed IGH but I think for winter riding that would be enough. The cruiser is the most affordable. Geometry wise I would probably like the hybrid or the MTB more. The cruiser and the MTB would allow me wider tires, which I would prefer. I forgot to mention I would have to buy studded tires. I've been leaving my bike in 3rd and just shifting the front chain ring but I don't know if that compairs to the gearing of a three speed. Your input is greatly appreciated.
baldilocks is offline
Old 12-19-18, 07:45 PM
baldilocks
Quoted: 156 Post(s)
I don't mean recommend a specific bike. I was wondering if anyone else has used a 3 speed internal gear hub bike as a winter bike.
Old 12-20-18, 05:04 AM
kingston
Jedi Master
kingston's Avatar
Bikes: https://stinkston.blogspot.com/p/my-bikes.html
Quoted: 1759 Post(s)
Liked 488 Times in 313 Posts
My winter bike is a 3-speed. I have only ridden it one winter, and last winter was pretty mild, but I was very pleased with the X-RD3 and X-FDD hubs for winter riding. When I was looking, there were no complete bikes available with those hubs, so I had to build one.
kingston is offline
Old 12-23-18, 12:11 PM
fietsbob
Bikes: 8
Quoted: 7607 Post(s)
SA 3 speed gearing is dependent on the hub cog, 13 to 22t you pick one, and your chainring size, rhat's your 2nd gear
1st is 3/4 of that 0.75; ... 3rd is 4/3 of 2nd, 1.33 X multiplied by your wheel size..
I'm Using a Sturmey Archer Drum brake hub on my winter bike , they also make a drum brake 3 speed IGH hub and have since the dawn of time..
Now they also make 4, 5 and 8 speed .. and the Cassette Freehub... and screw on freewheel models.. I have been using the latter for 30 years..
On a old Stumpjumper frame I got with a Broken dropout.. repaired, found a fork and so forth piece by piece..
If I had a use, like upper midwesterners do , Id rebuild the wheel with an SA drum IGH,,, but here snow is an occurrence, not a season..
My winter rain bike, now, is a R'off Disc brake bike Friday Pocket Llama*, with trekking bars ..
* High BB is a mixed blessing .. feet stay dry (rain cape) but I have to shift off saddle to put a foot down ..
you nay have to build your perfect bike , rather than like a computer expect it to be plug and play.....
Shop for something that has a lot of things going for it... right size frame, fork etc, then change the bits you want to be better..
fietsbob is offline
Old 12-25-18, 07:57 PM
Dahon.Steve
Quoted: 261 Post(s)
Liked 11 Times in 10 Posts
There are a number of 3 speed bikes for sale on Bikes Direct.
I will say this about the 3 speed hub (Shimano) in the winter. It tends to loose efficiency because the cold freezes the internals. The hub doesn't come to a screeching halt, but you will find yourself using more energy than a regular derailleur bike.
Dahon.Steve is offline
Old 01-01-19, 04:08 PM
fietsbob
Bikes: 8
S-A uses light oils, in the gears.. Shimano (coaster or Roller brakes), uses grease ... but they' re cheaper and BD is all over cost cutting..
fietsbob is offline
Old 01-03-19, 03:55 PM
CharlieFree
CharlieFree's Avatar
Quoted: 9 Post(s)
Liked 5 Times in 3 Posts
does this mean Sturmey Archers are better in cold temps? I have the Alfine 8 and find it seems a little draggy in cold temperatures. also thinking of going to 3 speed to bring hub weight down.
CharlieFree is offline
Old 01-04-19, 12:10 PM
fietsbob
Bikes: 8
People Open up Alfine 8 speed hubs de grease and ATF dunk them .. while apart consider fitting an oil port in the hubshell ..
thread and plug a screw hole..
fietsbob is offline
Old 01-04-19, 03:40 PM
kingston
Jedi Master
kingston's Avatar
I've never had a Shimano IGH, but my SA 3-speed feels the same in the summer and winter.
kingston is offline
baldilocks
Beach Cruisers
9
01-31-18 05:20 AM
baldilocks
Winter Cycling
20
01-13-18 03:10 AM
HSean
Winter Cycling
3
10-26-14 08:09 PM
chico1st
Commuting
28
01-23-10 02:03 PM
