TRP Spyre Spring too weak
One of my TRP Spyre mechanical brakes doesn't have the same spring back it once had (the other one is fine). I have cleaned and lubed it with marginal difference. any advice on what else I can do to increase the spring force to its original?
meaning the typical spreader spring you get with the new pads, ? that goes in between them? (Only own their HyRd, which has none)
TRP brakes > https://www.trpcycling.com/contact/ .> For CDN :
- mail: AftermarketDivision@livetoplaysports.com
- Website: www.livetoplaysports.com
Occam's Rotor
Quoted: 2366 Post(s)
Liked 2,331 Times
Bend it out.
Likes For Cyclist0108:
Quoted: 4201 Post(s)
Liked 3,857 Times
A long used tandem drag brake cable trick is to add a coil spring over the cable between the casing stop and the anchor bolt/arm. Not done this yet on a Spyre so don't know how realistic it is on this brake. But I have done it on other disk calipers with some improvement in pad retraction/cable movement. Also having levers that have a return spring helps a tiny amount.
Rant time- I "thank" Shimano for introducing us to weakly sprung calipers and derailleurs. Andy.
AndrewRStewart
AndrewRStewart
I mean that there is normally spring tension to keep the pads in the normal open position. when you release the brake it does not return to the normal position as it should. This is not a cable issue as it's the same when disconnected from the cable.
Must be the weather , locally..eh? you consulted a local Bike Shop yet? or the manufacturer's rep office, I listed?
My BB7 discs had a spreader spring between the pads, I replaced The pads once then replaced them entirely with the Hy Rd ..
not yet, but I will. thanks for the info.
Bikes: 1970s Peugeot Phantom, 1989 Bottecchia Equipe (?), 2010 Colnago World Cup CX
The Spyre calipers have two pivot points, one ether side, and they are prone to collecting a bit of muck which can make them drag a bit. That makes the brakes slightly harder to pull, and restricts the caliper's urge to spring back open when cable tension is released.
As standard, Spyres' internal springs are arguably on the too-strong side so I'd recommend cleaning and lubricating the pivots well and then re-trying - you should be able to get a very snappy return. Do this with the calipers removed from the bike and disconnected from the cables to eliminate cable drag which can cause similar issues.
I have focused on the caliper's internal spring because I am familiar with that problem, but as has already been noted, you need the replaceable pad separating spring to be doing its job properly too.
Likes For A Northern Soul:
Likes For csport:
Quoted: 5781 Post(s)
Liked 2,576 Times
I agree. I can understand to a limited degree that lighter derailleur springs MAY make sense. But there's no reason for brake springs to be so weak. A positive return is highly desirable, and the tiny added resistance when applied, is meaningless in the scheme of things.
FB
Chain-L site
FB
Chain-L site
kmc143
3
11-08-13 07:58 AM
southpawboston
Classic & Vintage
20
03-07-11 08:05 PM
