Clean Your Freewheel
Prompted by a thread from a few days ago, I was looking carefully at the freewheel on my bike. I cleaned the cog exteriors, added some oil and gave it a spin to spread the oil.
The thing is, when spun, it didn't sound quite right. I added more oil, then more (a lot really). It was still not right.
I unscrewed the freewheel from the hub (a chore in itself as I forgot to grease the threads) and spun it again. It was definitely not right.
Using a syringe applicator, I injected some gasoline through the gaps to flush out any grit. Mind you, the oil is supposed to do this but it did not. I spun and re-flushed until it spun properly (quietly).
A bunch of junk came out into the parts cleaning pan. This included a bunch of very fine flecks of the gold-colored coating from the freewheel body and cogs. It contained a lot of very fine, silty material. I assume this is from the beach sand. It isn't grains of sand, as the bike never goes onto the beach. It was just a fine silty material I assume was wind-born. None of that is good for a freewheel's bearings and racheting mechanism.
Anyway, it's clean now, re-lubed and re-installed (with grease on the threads this time).
If you want your bike to last, you have to take care of it.
Mine is 45 years old.
Quoted: 5888 Post(s)
Liked 3,471 Times
and don't forget to grease those threads,
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3888 Post(s)
Liked 6,487 Times
I use only new sunrace and IRD freewheels on my old bikes.
Shifting is fun!
Bikes: Yes, please.
Quoted: 2198 Post(s)
Liked 4,601 Times
For some reason I find cleaning and lubricating freewheels very satisfying.
I'm sure sound has a lot to do with that.
Quoted: 765 Post(s)
Liked 660 Times
Gasoline! Man, that's living dangerously. I know there are others here who do the same, but I think it's nuts.
www.redclovercomponents.com
--Ogden Nash
--Ogden Nash
So it goes.
Bikes: A few. Quite a few.
Quoted: 432 Post(s)
Liked 639 Times
When I get a new (old) freewheel or a bike with one, it gets a bath for a couple of days in mineral spirits with spin/agitations at intervals, which does great at getting the gunk loose and flushed out. After that I lube with a mix of Phil's Tenacious and regular oil. So far that's been a winning procedure for me.
Ever since they outlawed the sale and use of mineral spirits, I've been struggling to find a suitable replacement. Acetone is all they sell and it's so volatile, even compared to gasoline, I'm not yet sure what to use.
What do you use?
Well, I've been experimenting with White Lightning waxy (dry) chain lube. It's good, too, but I'm not yet confident in the lubricity of the stuff nor of the chain life when using it. It won't work on freewheels.
I occasionally use gasoline - gasp - usually from the lawn mower or snowblower gas cans. Everything else .... everything, pales in comparison when it comes to getting the tough stuff clean. If I had a spare 90 minutes to clean a cassette with todays "degreasers" and a toothbrush, I would. But 30 seconds and a paintbrush dipped in gas does the job 1,000 times better. Sometimes I'll chain smoke Camels while watching Rambo in my fireworks / ammunition closet and clean a cassette. But seriously, there is a time and place, and with 2 brain cells, why not ??? Then again, I've cut the tags off pillows and may have used an aerosal can in a manner frowned upon by the US Government ..... ssshhhhhh.
Likes For sdn40:
It isn't my preferred solvent but it's what was at hand (lawn mower fuel). It's unleaded and alcohol-free. I used about 2-3 ounces.
What do you use?
What do you use?
We used to use regular kerosene for flushing freewheels etc BITD, so it's hardly a worry. Naphtha will work for this too, as would turpentine. Usually at home these days I just flush stuff like this out with WD 40. Orange solvent and/or detergent solution will work, but slower. Simple green would probably work but the smell makes me sick.
Back to the main topic - If it's an old vintage crusty freewheel, I'd probably rebuild it. We never or only very rarely did that when freewheels were the only option - waste of time, but 30 or 40 years of sitting around turns grease into varnish.
Semper Fi
Quoted: 1172 Post(s)
Liked 358 Times
I always send any not new freewheel to Pastor Bob for a cleaning and tune up, well worth it to get his quality work, looks like new, and quality work every time.
Bill
Bill
Semper Fi, USMC, 1975-1977
Likes For qcpmsame:
Semper Fi
Liked 358 Times
And, you have a "Runs With Scissors" t-shirt, and its true too!
Bill
Quoted: 1627 Post(s)
Liked 630 Times
Just because it's so flammable? The fumes bad to breathe? Don't want to get it on your skin?
I've used gasoline as a degreaser (outdoors) but mostly stick to WD40.
feros ferio
Quoted: 1393 Post(s)
Liked 1,326 Times
I just drip motor oil or ATF into the freewheel bearings with the bike lying on its left side. Lots of gunk comes out. Once you do this, you do have to commit to a regular maintenance schedule, because oil, even straight 30W, does not have the same longevity as grease.
Bikes: '74 Raleigh Professional, '73 Raleigh Grand Prix, '84 Nishiki Medalist, '85 Gazelle Champion Mondial AB, '81 Peugeot Course, '79 Univega Gran Rally, '85 Torpado Super Strada
Quoted: 67 Post(s)
Liked 10 Times
I use WD-40 to flush freewheels, works well the clean exterior too. Let them sit for a day and drain after spinning like crazy to get all the gunk out, then lube with Phil’s tenacious oil.
I soak them in diesel fuel. let them drip dry. Then soak them in automatic transmission fluid and let that drain off.
Quoted: 604 Post(s)
Liked 1,064 Times
I get I get the cleaning for a freewheel on a classic bike that you want to keep stock, but when the best shifting freewheel you can possibly get only costs 15 bucks, why bother. Not worth the time or effort of playing with the solvents and lubricants. Upgraded all my CV bikes, that I actually ride to the Shimano freewheel, which at that price, would be hard pressed to actually want to clean it.
Tim
Tim
Bikes: '84 Peugeot PH10LE
Quoted: 397 Post(s)
Liked 55 Times
I use MARVEL'S MYSTERY OIL in my cassette. It's super-quiet, AND 35 years old ('84 Helicomatic system).
Jon
Jon
Tim
Tim
Regarding cleaning, do you use them for a few miles and then throw them away?
How long do they last you without cleaning?
Please explain because the frugal cyclist in me is unable to grasp doing what I think you do?
Likes For Bad Lag:
If you use grease, which grease do you use inside your freewheels? How do you get it in and how do you clean and replenish it?
Do you disassemble the freewheel?
Did you install a zerk fitting?
I have always used oil. I add a few drops when I oil the chain (every hundred miles or so). The chain usually needs lube and cleaning before the freewheel, so adding a few drops to the freewheel is not an issue.
ATF and Marvel Mystery Oil all sound like my next lube purchases for trial. I still like Phil's.
Bikes: Forty of them
Quoted: 99 Post(s)
Liked 33 Times
I rebuild mine because oil leaks out and doesn't do as good a job as grease. Most aren't that hard to deal with, though Reginas can be a bit of a pain. I won't even touch Sunrace or the other generic brands - not worth the effort considering that the poor quality never goes away.
Likes For cinco:
Quoted: 4560 Post(s)
Liked 2,802 Times
Ditto, SunRace freewheels... at least the chromed versions like the 7-speed 13-25 MFR30, and 13-28 MFM30 ("R" for road, "M" for mountain bike, but I use both on road bikes). Those are good quality and outstanding values. They shift better than Suntour or Shimano freewheels on my bikes with Suntour and Shimano components.
I've just switched my Ironman from the SunRace 13-25 to a Suntour 13-26, which lets me spin a bit more effortlessly on our short, steep rollers. My knees like that. But the SunRace shifts more smoothly and runs more quietly. The Suntour Alpha freewheels and Accushift system are picky about chains.
OTOH, I just switched the Trekenstein 5900 from Shimano 14-28 MF-TZ21 to SunRace 13-28 MFM30 and it runs better, and doesn't spin out on a couple of favorite downhills. Neither freewheel was picky about shifting since Shimano was less finicky than Suntour Accushift.
But the MFM2A 7-speed 14-28 with a mix of blue-black carbon cogs was a disappointment. The freewheel body was a bit loose and rattly out of the box. I used it on my Globe Carmel errand bike, so no biggie. It's still better than those awful Shimano MegaRange freewheels that jump from the 24 to 32 or larger tooth cogs.
And please be extremely careful with gasoline. I'm a former OSHA safety inspector but I'll spare you the gruesome details of the horrific injuries and fatalities I've seen from getting careless with gasoline and other flammable liquids. Gasoline vapors spread very quickly and you can be surrounded by flammable vapor before you realize what's happened. 'nuff said, I hope.
