kryptonite lock help needed
Old 08-05-06, 11:18 AM
crayonsemble
the tall guy.
crayonsemble's Avatar
has anyone ever had problems with the kryptonite disk locks for the chains become
stiff to lock over time? mine is getting hard to lock and unlock and iam afraid
that one day it will become jammed lock to a sign. is there anyway to make
it smooth again? i was thinking about using some wd-40 or something,
any ideas?
crayonsemble is offline
Old 08-05-06, 01:27 PM
fixedpip
asleep at the wheel
fixedpip's Avatar
Bikes: Custom Richie Ditta Track Bike, Eddie Merckx Corsa, Marioni Custom Pista, Dolan Cyclocross
Lube it, use just a little at a time until it becomes buttery smooth again. Worked for me when my Fug chain lock starting getting troublesome to unlock.
fixedpip is offline
Old 08-05-06, 07:54 PM
Rikardi151
redonkulous
Rikardi151's Avatar
Bikes: 2001 GT GTB
the same thing is happening to my fughettaboutit u-lock
Rikardi151 is offline
Old 08-05-06, 08:08 PM
ink1373
nothing: lasts forever
ink1373's Avatar
Liked 2 Times in 1 Post
i put a little triflow in there now and then if it starts getting sticky, then open and close it a dozen times or so to work it in. that always does the trick for me.
ink1373 is offline
Old 08-05-06, 08:41 PM
BuddyMike
Sometimes I hear people use disk lock and the horseshoe mini u-lock interchangable. I have a new york chain and it came with the mini house shoe u-lock, so I am going to assume you have the same[unless it came with the krypto disk[round]lock. So just in case https://www.nybma.com/faq/question3.htm This link is a good link and may raise another problem with your lock that you might not suspect.
BuddyMike is offline
Old 08-05-06, 08:43 PM
born on a bus
LTD
born on a bus's Avatar
Bikes: raliegh fix conversion
I had a similar problem, it was due to corrosion though, I used PB Blaster and that stuff cleared it up in an instant. It works way better than Wd-40, though it is probably way worse for the environment.
born on a bus is offline
Old 08-05-06, 09:36 PM
Yoshi
Just use some bike lube.
Yoshi is offline
Old 08-05-06, 09:40 PM
Yoshi
A mini-ulock is a mini-ulock. A disk lock refers to the type of core the lock has (what you stick the key into). On the newer kryptonite locks (and the older fuggedaboudits) they used a disk lock core which consists of a series (7-8) of disks stacked on top of each other.
Yoshi is offline
Old 08-06-06, 12:34 AM
AfterThisNap
Taking "s" outta "Fast"
AfterThisNap's Avatar
2nd on the bike lube. We use triflow and prolink at the shop for sticky kryptos.
AfterThisNap is offline
Old 08-06-06, 03:45 PM
Retem
Paste Taster
Retem's Avatar
Bikes: , Jury Bike, Moto Outcast 29, Spicer standard track frame and spicer custom steel sprint frame.
never use wd-40 on a lock it can damage the springs and tublars instead go to the hardware store and get some of that graphite lock grease it usually is in a little tube for a couple a buck and it has a really thin little applicator so you can put it in the lock all the way to make sure it is lubed all the way
works great and its water proof if you damage the springs and tumblers or pins one could jam and then you will never gt it open again
Retem is offline
Old 08-06-06, 04:07 PM
Ceya
Guest
Just send it back, I am sending back my Gorgon locks because the key wouldn't turn, another key twisted in the lock.
Another new lock wouldn't open took back to LBS for exchange next day, exchanged lock the key broken in the lock 7 days later while working.
I can give you contact info if needed.
S/F,
CEYA!
Ceya is offline
