Any way to warm up a bike faster when you bring it inside?
Quoted: 120 Post(s)
My bike's out in the cold, long enough to adjust/match that outside temperature.
If I bring my bike inside, is there any way to warm the bike up faster than just letting it sit? I'm trying to think of ideas. Maybe a space heater, but that might start causing more wear compared to just letting it warm up on its own. And I don't have a space heater....
It's an aluminum bike too. I've been experimenting with bringing (ie sneaking) it inside for about an hour before I need it. That seems to work fairly well. Outside cold, inside for an hour or so, and it's much nicer than the outside temps for sure.
Just fishing for ideas....
Quoted: 4227 Post(s)
Liked 2,488 Times
Why warm up a bike ??….What's the point ??
Likes For wolfchild:
Quoted: 2952 Post(s)
Liked 3,106 Times
This is a joke, right?
Quoted: 120 Post(s)
It's not a joke. The bike is outside so it's literally ice cold. You sit on a cold bike seat and then grip cold handlebars. There's definitely a difference riding a bike that's sitting outside vs. one that's kept inside -- Cold butt and fingers go numb faster gripping the cold handlebars. Add in having to squeeze the handlebars more if I wear thicker gloves when it's colder out or when it's icier out and I grip the handlebars more. So if I bring the bike inside before I ride it when I'm stuck having to leave it outside, that helps. I'm wondering if I can get it to room temperature faster though.
A fan blowing air over it. Maybe an electric blanket. Laying something on it that's warmed. Putting it by something like an old boiler or oven.
But if it goes from an outside temp and then heats up faster than just sitting there at room temperature, I wonder what might do, in terms of the faster temperature change and also if that's repeated for wearing things. I would think even without speeding up the temperature change process that it's going to wear things out a little faster than if I kept the bike inside all the time and only had it outside while riding it.
Non omnino gravis
Likes For DrIsotope:
Aluminum bike right? Do you have an electric dryer? Disconnect your electric dryer power cord and cut one of the wires. Attach one end of the cut wire to the chainstay and the other end to the right handlebar as close to the end as possible. Turn the dryer on but stay away from the bike. The dryer won't run because it's not plugged in but it has to be on. In about an hour the bike will be just about the same temperature as the air in the house. The earlier in the week you do this the better. Towards the end of the week it does not work as good. When you are done reconnect the wires and plug the dryer back in. You can limit wear on the bike by hooking the wires up the other way the next time to even things out.
Likes For u235:
Quoted: 941 Post(s)
Liked 319 Times
Bikes: 2 many
Quoted: 1266 Post(s)
Liked 323 Times
If it's cold outside and the bike is cold you bring into say 68 degrees, something like a bike will get condensation on it. The bigger the temperature difference the more condensation there is. The faster you warm it up the worse it is. If you need to go outside when there is still condensation on something it will turn to ice if it's cold enough.
If you get condensation in the frame you can't see it. if you get some in the cables it can freeze the cable solid if there was not enough time to dry the bike out.
If you bring the bike inside let it warm up slowly, and let it dry all night long. I've seen frozen cables from this a couple of times. I was deer hunting when it was about 20f, brought the shotgun inside, leaned it against the wall and the water was pouring off the weapon.
Or leave the bike in the cold. maybe a garage, or a shed, and wear the right clothing. I do it all the time.
Likes For 2manybikes:
Oh my......
Quoted: 980 Post(s)
Liked 580 Times
I commute by bike. My commuter sits in the garage where, lately, it's been in the teens. I can't imagine wasting the time to bring the bike in every night.
Likes For sweeks:
WGB
Bikes: Panasonic PT-4500
Quoted: 1794 Post(s)
Liked 2,328 Times
Have a quick release for the seat. Bring it inside and keep warm. Reattach in the morning.
Likes For WGB:
Bicycles are people too. Like corporations....
If you have high ceilings, attach the bike up there since warm air rises.
Or give it a hot tub in the hot tub.
Stand it over the furnace vents. If you don't have a furnace, connect the hydronic heating supply to the head tube, and BOTH chainstays to the hydronic return line. If you only connect one chainstay, you get uneven heating of the frame and it will bend. That is how 126mm rearspacing happens.
Start a pottery hobby and put the kiln where the bike sleeps. have a batch of pottery ready to be burned before the bike comes home.
Quoted: 2594 Post(s)
Liked 1,922 Times
Getting the literally ice-cold bike inside is going to make your hands painfully cold. You might consider wearing the gloves you put on to bring the bike inside while you're actually riding the bike.
Similar process holds for the saddle, butt I'll leave that to your imagination.
Liked 2,488 Times
Somebody need to invent heated handlebars and heated saddles.
Quoted: 1362 Post(s)
Liked 1,674 Times
bikerbobbbb I commute year round down to 5F. My three bikes sit outside in an unheated shed. Below 15F the bikes sometimes feel kinda stiff for a couple of minutes, and using the pump to top off the AirZound air-horn can be a little tough. Also, the cable locks can be stiff. But I've never felt like the seat or bars are cold. On the other hand, I've been wrapping my bars in 3/4" pipe insulation for a dozen years due to hand issues. And each bike has a padded gel-seat cover...well, my snow bike has an actual padded gel seat (with springs). That may have something to do with it.
Quoted: 7341 Post(s)
Liked 2,441 Times
This reminds me of the story my friend told me. On his winter break, he would stay with his grandparents in rural New Hampshire. They had an outhouse rather than an indoor toilet. The seats were kept above the fireplace inside. He would take one of the seats (I don't know why there were two) off the wall and carry it out to the outhouse. He said it was actually a fond memory.
I bought a Eddie Bauer hand warmer power bank device. I turn it on and put it in a pocket.I grab it in my pocket and it quickly warms the palm of my gloved hands.
I have a very short cord to re-charge my Garmin which only lasts 8 hours and I have a headlight that plugs into the power bank.
For the seat I suggest a reusable warmer/ice pack Just warm it in microwave and hold it onto the seat for a minute. In the summer freeze it and leave with it in the pocket of your Camelback
I thought the World Naked Bike Ride took place in the summer.
If your bike seat and handlebars are ice cold, put on a pair of long johns and wear gloves.
Mad bike riding scientist
Quoted: 6200 Post(s)
Liked 4,200 Times
Not that condensation would be much of an issue for the aluminum. It’s fairly inert to water corrosion.
Stuart Black
Stuart Black
Quoted: 1104 Post(s)
Liked 1,824 Times
Just wear clothing appropriate for the weather conditions you're going to ride in. I used to ride in all weather conditions, including sub-zero ambient temps and my bike stayed outside in between calls. I can't say that I ever noticed a difference between stored inside and sitting out in the weather. Now a wet seat, that's a big difference but it's easily solved with a grocery bag or hotel shower cap.
