Lemond Revmaster Pro built in speed sensor
I have a lemond revmaster pro spinning bike with “supposedly” cadence and speed sensors (as I have the pilot computer which displays my cadence and speed). I bought the ANT+ USB to be able to pair with zwift on my computer. Via the app, I am able to detect the cadence sensor but not the speed sensor (even after pedaling the bike to “wake up” the sensors). Is there no speed or power sensor in this bike? My garmin bike computer isn’t picking up the speed sensor either.
Thank you in advance for your help.
Hi Negtheegg,
I'm working on the same issue, digitizing my Revmaster Pro almost a month, the only solution I've found is installing a new bluetooth sensor for speed with a very small neodmiyum magnet.
Currently there's only cadance sensor is installed in the Pilot II configuration, there's no such speed sensor, so Zwift is not working out of the box.
Regards,
ET.
Regards,
ET.
Seems Pilot II device is making a simple calculation over the Cadance sensor, to measure the speed. Unlike a regular bike, there's no "gears" in the device, easy to calculate the speed.
Has anyone solved this issue?
If you haven't solved this problem (can't use Pilot II cadence monitor and transmitter with Zwift), can you recommend some online training programs that don't require such a connection?
small speed sensor?
I'm curious which small speed sensor you were able to fit on the fly wheel.
The space is very small and it doesn't looks as a Wahoo, Moofit or anything on Amazon would fit.
