What will a new bike do for me?
Bikes: 1991 Diamondback Apex, 2015 Trek Verve 3, 2020 Specialized Diverge
Quoted: 143 Post(s)
Liked 116 Times
I am shopping for a new bike. Currently leaning toward an endurance bike like Specialized Roubaix, Trek Domane and Cannondale Synapse.
I am riding a hybrid. It is comfortable on 40 mile rides. I am gradually increasing my distances.
Went on my first ride with a slow D group. No problem keeping up with those guys. Ride leader said he thought I would have no problem with the C group. But I would struggle in the B group.
I do not think a new bike would make the difference between being a C group rider and a B group rider. But I suspect it would help a bit.
Maybe a nicer, better fitting bike would be more comfortable.
And I think I would enjoy riding a higher quality bike, crisper shifting, smoother ride and I admit cooler. Maybe only cooler in my head, but that is really the only place it matters.
And I want a new toy.
Help me out here. I am working on rationalizing a splurge.....
Likes For Sorg67:
Quoted: 7652 Post(s)
Liked 3,473 Times
A new bike will always make you ride faster .... because your wallet will be lighter. ( < rimshot >)
Likes For Maelochs:
Liked 3,473 Times
Oaky ... first there is no need to rationalize wanting more toys. And when it comes to bicycles, you need to rationalize NOT buying at least a couple more. So that whole part of your post .... done.
What can a new bike do, realistically?
When you start riding in a new style---say, more miles, more pace, or group rides---you can buy a bike well suited to your new style, and it will perform marginally better in the roles for which it was designed, no doubt.
A bike with a riding position more suited to extended efforts at higher output will be more comfortable over that distance at that effort. If the bike is lighter than your old one, it should seem snappier under acceleration and braking. If the steering is a little quicker the bike should feel more nimble.
Of course, the rider is ninety percent of the ride. The fastest guy in that group would likely be able to keep up with the group on your current bike, and honestly, even taking ten pounds off a bike, say, 32 to 22 pounds, is not a lot compared to the overall package of bike and rider. But even if the difference is slight, or even if it is mostly placebo, there is some difference and well ... that's part of what you are buying.
Will the new bike shift more crisply? Well, if you did a crappy set-up on the old bike and do the new bike better .... but there is no reason why an older hybrid shouldn't shift well.
As for a smoother ride .... if the tires are narrower and the frame more rigid on the new bike (not uncommon on a performance-oriented bike as opposed to a comfort bike) then the ride might be a little Less smooth, but you won't mind---it will be smooth enough.
As for as "cooler" ... that is entirely subjective. So ... if I had an old hybrid, I would find it cool as what it was, and my new endurance-geometry bike as cool for what it was. What other people think of my rides ... i don't ask because I don't care. So ... All my bikes are cool.
But, that said .... New is also good. And if you only have one bike .... well, don't bother thanking me for deigning to lower my standards and engage in conversation with a person who only owns one bike. Instead, go out there and remedy the situation!!
Ride on.
Ride on.
Likes For Maelochs:
I went from a 2014 Specialized Roubaix Expert (Ultegra groupset, passive suspension with CGR seatpost) to 2020 Trek Domane SLR9 (SRAM Red for nearly everything, aero XXX wheelset). I'm certainly not worthy of such a bike (middle aged guy with a 240W FTP) but I absolutely loved both bikes but the Domane takes it to a new level. I typically ride at least 25 miles per ride, often 50 and yesterday did 130 miles on the Domane. I felt fresher than I could have ever imagined after that ride.
If you like longer rides, I think you will find a lot of enjoyment in a new road bike. I don't know what your budget is but I would recommend that most people try to find a bike setup the way you'd like on the used market to save some big bucks. On the other hand, there isn't a lot of new or used bikes available right now.
The most important thing to do, in my opinion, is to get a pre-buy bike fit to ensure you get the right size frame. I was surprised to find a significant fitting difference between the Roubaix (58cm) and needing a 60 or even a 62cm Domane to fit properly. I got the 60cm Domane and used the preliminary fitting measurements to get things setup and will fine tune with the fitter soon.
I learned a lot from the fitting including how to improve my pedaling technique which I suspect will result in substantial improvement in my power. Additionally (note the 130 mile ride), the bike fits perfectly.
One thing to note about the Domane is its ability to take on a 40 tire which is awesome for gravel. I bought Aeoulos XXX 4 TL for road riding with 28 TL Conti 5000s and have a set of the Pro 3V TL on order for gravel that I will equip with 40 tires. While the bike is speced for 38c, I tried a neighbors 40 and it fit with plenty of clearance in my opinion. Thankfully, only gravel farm roads as I don't want to ding this beauty up.
Likes For zorax2:
WALSTIB
Mainly food will taste better and the air will smell sweeter
Likes For hillyman:
Quoted: 18409 Post(s)
Liked 15,530 Times
Ask not what a new bike can do for you—ask what you can do for a new bike.
Klaatu..Verata..Necktie?
Quoted: 10424 Post(s)
Liked 11,886 Times
A new bike will inspire you to ride more, and longer, and try harder things, and maybe enjoy riding that much more. If it's more stable at speed than your hybrid, you might find yourself seeking out descents, and the only way to get to the descents is to ascend, so maybe you'll climb more.
Likes For genejockey:
Tragically Ignorant
Quoted: 8186 Post(s)
Liked 9,098 Times
Got to ask this on pretty much all should I buy threads right now: is this theoretical, or have you actually located someone who has bikes in stock?
Quoted: 143 Post(s)
Liked 116 Times
The bikes I want are in stock locally. The limiting factor is the ability to take test rides. You have to buy the bike ride it and return it if you do not like it. I would be willing to do that, but I am new to this style of bike so I really do not have a basis for comparison to know how I like the bike relative to other similar bikes. I would like to ride several back to back. Relative to my hybrid, all these bikes will be a lot different and I will like them all.
I think.....
I think.....
Likes For Reflector Guy:
Expired Member
Quoted: 3664 Post(s)
Liked 5,412 Times
Here's a similar thread pondering the point of a new bike.https://www.bikeforums.net/general-c....html:twitchy:
Likes For shelbyfv:
Liked 3,473 Times
If you spend enough on the new bike ... the tension between yourself and your significant other will be enough to drive you out of the home and out onto the roads on your new bike.
Quoted: 143 Post(s)
Liked 116 Times
Here's a similar thread pondering the point of a new bike.https://www.bikeforums.net/general-cycling-discussion/1210251-do-i-want-fast-bike.html
I think I will probably get one of the three endurance bikes mentioned in the OP. But I will wait until I can test ride them all and in both 54 and 56 cm frames.
In the meantime, I will put clipless pedals on my hybrid and get used to riding with those. I am considering some narrower tires. I might replace the suspension forks with fixed forks. Also considering replace the handlebars with carbon. It will be interesting to see how much I can improve my existing bike.
Not sure the handlebars and fork will be worth the money on a bike I probably will not ride a lot. But it might be a fun project while I wait for test rides to loosen up.
Liked 15,530 Times
Likes For indyfabz:
Quoted: 6960 Post(s)
Liked 10,960 Times
Last time I was shopping for a new bike, I was going custom. Had the shop price it with Di2 and also with the mechanical groupsat. Difference was $1200, which included porting the frame for the wires. Showed my wife the prices, and she immediately said “You told them to go ahead with the more expensive one, right?“
A couple months later, when the frame was almost finished, we got an unexpected $5000 check in the mail. I showed it to my wife, and she immediately said “anything left on that new bike that you need to upgrade?“
PS, she’s a lot younger and prettier than me, and she loves to cook. I must’ve been a really great person in some previous life.
Likes For Koyote:
Quoted: 4227 Post(s)
Liked 2,488 Times
A new bike will give you a " temporary feel good sensation " for about the first 3 months. After that you will get bored with your new bike and come back here and start a " bored with my new bike " thread.
Quoted: 143 Post(s)
Liked 116 Times
[edit] Although I still ride my early 1990s Diamondback Apex.
Bikes: 2010 Fuji Absolute 3.0 1994 Trek 850
Quoted: 762 Post(s)
Liked 555 Times
it will increase your enjoyment and motivation to ride, so, really you have no choice
Likes For Flip Flop Rider:
Liked 10,960 Times
Quoted: 1572 Post(s)
Liked 643 Times
You are making a left brain/ right brain decision.
Pure left brain people see a bicycle as only a functional tool.
Pure right brain people see a bicycle as a toy.
Everybody draws the line between those two extremes differently. Have fun determining where your personal line is drawn.
Quoted: 1364 Post(s)
Liked 1,677 Times
It doesn't even need to be a brand new bike. A "New to You" pre-owned can create excitement, too. Even just a mod. Over the last 23 years I have modified my 1997 Nishiki Blazer mountain-bike and each modification has produced varying levels of excitement in me, much to the annoyance of those on bikeforums, since I tend to over-share.
The four most exciting changes for me were studded snow tires, big fat slicks, and adding drop-bars and replacing the original cantilever brakes with V-brakes.
I would say these changes were on a par excitement-wise with acquiring a 16-year old road bike in 2009, and buying a brand new bike in 2015.
In my opinion, "rewarding" yourself by splurging on a new bike for having ridden is better than overspending on a new bike in hopes it will spark you to begin or increase riding, although whatever successfully gets you riding or keeps you riding is good in my book.
Likes For BobbyG:
Quoted: 550 Post(s)
Liked 325 Times
Aerodynamics and a supple set of road tires with low rolling resistance (too narrow to fit most hybrid rims) will make you faster too.
Likes For Drew Eckhardt:
