bearings won't seat with new handlebar riser
I tried to put a handledbar raiser on my bike, one of those raisers from a company called Outerdo that fits onto a threadless stem. When I install the device and turn the bolt in all the way and tighten it, the steering column(?) judders, remains loose. The bearings don't seat the way they should. When I remove the raiser and put the bike together the way it was, the bearings seat find and there is no looseness. I know how to install these risers and how to place the spacers so that the top of the raiser presses down on the spacers and not on the stem, so that is not the problem. What could it be?
Quoted: 6177 Post(s)
Liked 4,794 Times
Fitting Your BikeAre you confused about how you should fit a bike to your particular body dimensions? Have you been reading, found the terms Merxx or French Fit, and don’t know what you need? Every style of riding is different- in how you fit the bike to you, and the sizing of the bike itself. It’s more than just measuring your height, reach and inseam. With the help of Bike Fitting, you’ll be able to find the right fit for your frame size, style of riding, and your particular dimensions. Here ya’ go…..the location for everything fit related.
Maybe your post will be more appropriate in this sub-forum:
Quoted: 426 Post(s)
Liked 696 Times
Sounds like the bolt may be bottoming out in the star nut in the steerer. You may just need to drive the star nut further down into the steerer. I'm assuming the long bolt isn't fully threaded.
