saddle fore and aft adjustment
Bikes: Wife says I have too many :-)
Quoted: 327 Post(s)
Liked 250 Times
I have my road bike dialed in pretty well, comfortable riding, just got back from a 60 mile outing and no issues. I am concerned about the fore and aft saddle position however. It is supposed to be good to set up the saddle position so a plumb bob from the knee cap intersects the pedal center. On my bike the plumb line is 1 1/2" forward of the pedal center. Should I be concerned ?
How critical is this ?
Quoted: 327 Post(s)
Liked 250 Times
Depends on where you are most comfortable when pedaling which falls to individual preference / build / flexibility / biomechanics, etc. Mine is actually an inch behind the plumb line.
I needed more aft or more setback position in my case because I am most comfortable with the saddle tilted down (even if the saddle has relief channel or cutout). To keep myself from sliding forward with the saddle tilted down, I increase setback or more aft position.
Quoted: 6193 Post(s)
Liked 4,809 Times
As far as using a plumb bob -- I would not make that the end-all-be-all decision for where your saddle should go. Perhaps it might be thought of as a starting point to set your saddle the first time and then adjust from there as your body tells you what feels right after actual rides. IMO.
Likes For Iride01:
Quoted: 139 Post(s)
Liked 136 Times
With regard to your question about the "knee over ball of foot" test, which uses the plumb bob to which you refer, it's out-dated, old-school thinking and is no longer considered critical. And to be clear, it's not where your knee is in relation to the pedal, it's where your knee is in relation to the ball of your foot on the pedal with the crank at 3 o'clock.
just another gosling
Quoted: 3888 Post(s)
Liked 1,938 Times
This KOPS thing is not particularly outdated. It's still used as a starting place by many fitters. Having got that right, one then looks at balance, meaning fore and aft saddle position, realizing that changing saddle position will also affect saddle height.
What's critical is not KOPS, it's balance. For most folks, KOPS and proper balance are about the same, which is the reason that shortcut gets used so much. KOPS really has nothing to do with pedaling mechanics. Fore and aft position does affect which muscles get used more and less, but that's trainable and doesn't seem to make much difference.
Results matter
Results matter
Quoted: 139 Post(s)
Liked 136 Times
In the first place, "from the kneecap" is incorrect. One drops the plumb bob from the bony protrusion just below the kneecap. That makes a difference as you will see. It's known as knee over pedal spindle or KOPS.
