Bicycle fell on drive side while washing/degrease
Was washing my bike and took both wheels off and my bike fell off my chain stay stand. Am pretty sure the right pedal took most of the brunt. Do I need to check anywhere for damages? So far the ride feels okay.
Frame is aluminium.
Frame is aluminium.
Likes For SpeedRanger:
Quoted: 6972 Post(s)
Liked 10,968 Times
And if (like most cyclists) you don't have the derailleur alignment tool, just put the bike in your workstand and gently run it through all gears, being especially careful at the extreme ends of the cassette. If it's shifting as well as before, then it's fine.
No need to worry about the frame. If the pedal took most of the force, that's good.
Likes For Koyote:
Quoted: 839 Post(s)
Liked 1,061 Times
First thing I always check with something like that is my ego. If no one else is around then it's usually OK. But, as others have mentioned if it rides OK then it should be fine other than some possible scratches or damaged bar tape. Sounds like the bike wasn't too far off the ground so not likely to do any great harm.
Likes For billridesbikes:
Liked 10,968 Times
Quoted: 6196 Post(s)
Liked 4,810 Times
If you can ride it and it shifts as well as it did before and nothing else in the operation of the bike has changed, then ride it.
What more do you want? You'll probably spend less money and less time doing maintenance if you wait for a problem to actually identify itself instead of looking for what might happen.
Anytime a bike falls on the drive side, the rear DR and it's hangar are the thing you want to worry about most. But if it's shifting okay on the back then do you really want to spend time or money?
Likes For Iride01:
