GPS Options?
Quoted: 81 Post(s)
Liked 7 Times
GPS Options?
Hi folks,
I'm seeking a satellite GPS for my bike that will provide the same features as google maps on my smart phone: maps of US locations that are regularly updated (preferably without a fee), the ability to program destinations in the form of street addresses and change them on the fly, turn-by-turn directions, touch screen, long battery life. Would the Garmin Edge 1030 meet my criteria? Is there an older version of the device I could find used that would do the same stuff at a lower price?
Bikes: Downtube IX NS&FS, Dahon Speed8Pro/Matrix/Curve, Brom S2L,Montague Para, ICE-XL w/Rollie/Schlumpf, Trident Spike, ebikes, BFSatRDay
Quoted: 172 Post(s)
Liked 95 Times
Hammerhead Karoo, if you're not in a hurry.
Android, free maps, reasonable touch screen routing, great screen can take a SIM card
Consider switching to an older inexpensive cell phone or a car GPS. something that you don't plan to last forever.
There is no magic answer , but inexpensive cell phone may be the best given your specifics, other than battery life.
though the monthly is a factor. an older Garmin 1000 series used, maybe.
Battery life is a product of screen size and age of the device.
Quoted: 81 Post(s)
Liked 7 Times
Quoted: 3238 Post(s)
Liked 2,086 Times
Hi folks,
As note as to the Garmins. One of the rock solid features is the ability to use an online route creation program such as Kamoots or RideWithGPS to create a route to download to the device. This feature works really well and is reason enough to put up (sometimes) with Garmins quirks
EDIT: Hammerhead does have a built in GPS. I think the only cycling unit that didn't was a discontinued Wahoo unit whose name escapes me. The Edge 130/530/830 and 1030 series all have GPS built in, they do not require a phone to function.
Quoted: 81 Post(s)
Liked 7 Times
Yes, the 1030 will do what you want. The current version is the 1030 Plus, it's near $600, but there are sales on the older 1030 for low $400's (Amazon at $440). That's a good price on a very good unit. The Garmin Edge 830 is somewhat smaller, somewhat newer, smaller screen, also not on sale currently so $400. If you want to view maps, the larger the screen the better, touch screen as well makes it easier to pan and zoom a map. Prices on cycling GPS's tend to start at around $240. If you don't need any performance metrics (Power, Workouts) the Edge Explore is almost the size of the 1030, is designed for the touring market and is $240. Then there are Wahoo units, as well as Hammerhead as Bikeetc....mentioned, but that's not yet available as the Karoo 2 and knowing Hammerhead, it'll likely be 6 mos.
Thanks, the Edge Explore sounds like a possibility. Will it give turn by turn directions? Can I program directions directly from the explore or will I need to synch it to a smartphone first?
Liked 2,086 Times
Typically and on the Garmins and Wahoos, the device connects to a smartphone via a BlueTooth connection, with an app on the phone. The phone app can then connect to the website based software and will allow a course you’ve created to be sent to the device. It’s a pretty painless process once you understand it. The way I use it is I’ll research a route in an area I’m unfamiliar with. I might use the street view on Google maps to look at what the road looks like in terms of having a shoulder, pavement, etc... I’ll then use RWGPS and draw a route for the distance I want to ride, I might do some options for different distances, labeling each as a different route. I’ll then have the routes sent to the device and I will start one. If I choose to cut a ride short, I’ll stop a route and start the shorter route. The device will ask me if I want to navigate to the start and I’ll say No. It’ll then figure out my position and start a TBT from that point to the finish. There’s also an option should you just be riding a wandering course and want to return the same way, you just start a navigation for “return to start, follow existing route”, and it will TBT a back track to the start.
The Explore is a good unit at a good price. You can get an app for the Explore called RouteCourse (it’s called an “iQ” app, available for free on the Garmin iQ store) which uses a BT to your phone and cell data to query your saved routes on RWGPS to download to the device. It’s pretty painless. RideWithGPS is free as BTW for a lot of their functions.
Tell me which GPS is right for a beginner? I mean that the interface is not very complex and only internal functions. In order not to be distracted by unnecessary)
Liked 2,086 Times
The Edge Explore ($250) is a good unit and decent price, especially if you will use for navigating and want on-screen maps. Otherwise an Edge 530, which is smaller, uses buttons in place of the touch screens on other models but not as good for navigation, $300. Or a Wahoo Bolt, $230.
Quoted: 680 Post(s)
Liked 948 Times
What do you mean by "only internal functions" ?.
Quoted: 172 Post(s)
Liked 95 Times
Accuracy in GPS is variable in all devices , based on satellites uses and sample rate. Much debateded, but if you are not planting fence posts, probably not critical.
Guys who found their century to be measured at 99.8 km/miles are the only ones very distressed.
Lezyne (Mega-XL, etc.), Bryton (450, 830), and IGPSport (igp618) all have GPS units with OSM maps in the $150-$200 range
Quoted: 81 Post(s)
Liked 7 Times
How easy are they to use relative to the Garmin Edge Explore? How robust are they mechanically in terms of surviving the beating they'll get from outdoor cycling?
Liked 2,086 Times
I would recommend doing a Google search for reviews and users experiences of the Lezyne and Brytons. I've read less than positive comments about the Brytons, mostly good about the Lezynes excepting that they rarely provide bug fixes or updates. As well neither provides the same lever of additional functionality interfacing with 3rd party activity tracking and route and navigation development, from my own research. Your call as to how that might be important or not.
The manuals are available online. They all look pretty similar, given the functions (that is, there's nothing about using a touchscreen unless the unit has a touchscreen).
BTW, the damned wind does give clues this time of year, at least in some areas ... the leaves show which way the wind is blowing.
