Tire width; 28 vs. 30 or 32.
Quoted: 462 Post(s)
Liked 635 Times
My Roubaix came with 28 tires but will fit up to 32 safely. I ride on notoriously bad roads so always looking to improve the ride quality. My old bike (09 Roubaix) had 25's and the new bike is noticeably more comfortable but not sure how much of that is the tires vs. the bike itself.
I'm going to need tires soon and considering going wider. Is there a noticeable difference in ride quality between 28 and 30 or 32? And will I pay a price in rolling resistance going wider? My main use of the bike is rides in the 70-100 mile range on the weekends. Speed is not important but I don't want to feel like I've ridden an extra 10 miles at the end of a ride. Currently riding GP5000 TT but open to other suggestions as long as it's something that isn't super easy to puncture.
Bikes: Trek Domane SLR 7, Trek ALR 6, Trek CrossRip, Trek X-Caliber 8
Quoted: 73 Post(s)
Liked 141 Times
My Domane came with 32's and I absolutely love them, buttery smooth. I went with the Bontrager R3 TLR's.
Likes For jaxgtr:
Quoted: 14759 Post(s)
Liked 3,727 Times
They're consumables - just try them. If all else is the same, none of the jumps is going to be so bad that you'll want to toss them in the bin and go back immediately.
Having run 30s for a couple years, I do prefer 28s, but that's because a) the 28s on my wide rims are comfy enough and b) I like my bike to handle a little more to the agile/twitchy side. In terms of rolling resistance, there's no way that I could tell a difference.
Likes For WhyFi:
New here
I have a Domane SL5 with 32s, and really like them. On the other hand, I didn’t like the 32s on my Sirrus 4.0, and went down to 28s which I find much more responsive and faster on that bike. My wife finds the 28s on her Roubaix much to her liking. I guess it depends on the actual tire and how they perform on the bike.
Likes For Mojo31:
Quoted: 3923 Post(s)
Liked 1,657 Times
Try latex tubes. My bikes max out at 700x25, so my only option for softening the ride on our increasingly rough chipsealed roads was to try latex tubes. Really helped. I'm not strong enough to notice any difference in speed due to reduced rolling resistance. But it's more comfortable, which matters on longer rides.
If you go this route, check out the tutorial videos by Silca. Very important for properly installing latex tubes to minimize problems. Since the Silca video was done they've begun pre-powdering tubes to ease installation with reduced risk of pinch-cuts against the rims. But I add a little of my own corn starch powder for subsequent uses. And be sure the rim tape adequately supports the tube -- some folks recommend tubeless rim tape rather than cloth or others.
So far my only puncture with latex tubes was user error -- I neglected to follow the advice to use tubeless tape and just used the Velox cloth tape that was already on the rims. There was a tiny bit of something sharp embedded in the cloth tape that punctured the tube on the rim-facing side. I was able to patch it using Lezyne self-sticking patches, which are very unusual -- they're paper thin, very soft and flexible, and the adhesive seems to get stronger and bond more securely with age. I used a Lezyne patch to repair the puncture and left it for a few days before riding. No problems since.
However I would advise carrying one or two spare butyl tubes for use on the road. Patching a powdered latex tube during a ride is a PITA. Quicker and easier to use a butyl tube, then patch the latex tube later. I usually carry super light Continental Race 28 Light tubes on my road bike seat bags, since I can carry two in the same space as one regular butyl tube. The Conti Race 28 Light tubes have been more durable than I'd expected, despite being so thin.
Tubeless is another option but I haven't tried it yet.
If you increase width without reducing your pressure, the tires won't ride any comfier. (Actually, wider tires are a bit stiffer than narrower ones, when both are at the same PSI.)
"Rolling resistance" in bicycle tires on pavement has two main contributing factors.
One is energy lost to tire deformation.
A bicycle tire inflates to a round-ish cross section, but at the contact patch where it's pressed against the road surface, the shape is flattened out somewhat. As a bicycle rolls along, when a section of a tire gets to the contact patch, energy is spent deforming it against the road surface. When that section of the tire leaves the contact patch, it "springs back" to a round shape. When it springs back, some of the energy is returned to forward motion, but not all: some of it is lost to internal frictions within the material of the tire, becoming heat.
Wide tires don't have to become any more deformed at the riding surface than narrow tires do, so they aren't really disadvantaged here.
An effective way to reduce this effect is to use performance-oriented tires that have less internal frictions. A beefy tire like a Marathon Plus has durable sidewalls, a long tread life, and extremely effective protection against punctures, but in order to accomplish this, they are very stiff and lose a lot of energy when they deform against the riding surface.
Another way to reduce this effect is to pump the tires stiffer. A stiffer tire deforms less at the contact patch, so less energy is lost to deformation.
BUT
The caveat to pumping a tire stiff is that the tire won't be as compliant on road surface irregularities. This isn't just a source of discomfort: it's also the other major contributing factor to rolling resistance. When a road tire is deflecting off of surface irregularities instead of deforming smoothly around them, it's vibrating the bike+rider. Vibrating the bike+rider costs energy, which is stolen from your forward motion. This is a decent article on the subject.
The costs from the latter effect can be significant. If your current tire width is preventing you from running adequately-low pressures, going wider might actually let you reduce your rolling resistance.
Here's my gravel bike, with 2.1" Rat Trap Pass EL tires, which are built like performance-oriented road tires except super wide:
Here's my Emonda, on some 25mm Bontrager R3s, a road racing tire:
On most paved road riding, I maybe go around a kph slower on the gravel bike. This is a VERY significant difference from the point of view of anybody shopping for fancy road racing bikes, but we're talking about feeling like having done a few extra miles on a century. And this is with a comically large difference in tire width, blasting straight past the wildest illogical conclusions of the question that you're asking. If you're worried about "feeling like you've ridden 10 extra miles", 32mm versus 28mm isn't in the same universe as anything that you should be worrying about.
If you think that going 28mm -> 32mm might offer some benefit for your rough roads, I'd say go for it.
-BUT-
At the same time, the really important thing for compliance is appropriate inflation. Are you sure that you're not overinflating your current 28mm tires? What's your bike+rider weight, and what PSI do you usually run?
If you're currently running butyl inner tubes, I'll also echo canklecat 's suggestion of latex tubes. You have to be more careful when installing them than butyl, but on the road, if anything they seem less prone to punctures and whatnot. And their benefits are real.
Likes For HTupolev:
Pointy Helmet Tribe
Bikes: Venge, R5, Shiv, Lynskey and a few more
Quoted: 476 Post(s)
Liked 572 Times
FWIW, I really like the Panaracer Gravel King slicks - they are light, they have been holding up very well so far (knock wood) and they roll surprisingly well for nominal 35c. I am getting more of those (and I say this as someone who rides race tires all the time).
Sophomore Member
Quoted: 1623 Post(s)
Liked 1,043 Times
While more comfy, wide tires are slow as a dog on climbs. I need all the help I can get in that area, so I always run the narrowest tire I can get by with. Not a big devotee of the "wider is always better" cult. YMMV.
Did you consider the Schwalbe Pro Ones with the Addix compound? Also, what kind of usage are you doing?
See the below rolling resistance test of GP5000 tires at various widths. Rolling resistance decreased from 10 watts to 9 watts when comparing a 25mm to a 32mm. In other words, the wider tire rolls easier. Unless there is some aspect of wider tires and climbing that I’m missing.
GP5000 tire width rolling resistance test
Bikes: 2020 S-Works Creo SL, 2020 Specialized Roubaix Expert
Quoted: 566 Post(s)
Liked 1,967 Times
I’m running 32mm GP5000TLs on my Roubaix and my Creo. I really like them. I’ve also run them in 28mm on both bikes and much prefer the 32s.
I think you have this backwards. Rolling resistance goes DOWN as you go wider on tires, although I certainly agree that there is such a thing as too wide. What goes up with wider tires is aerodynamic drag.
I think he meant wider tires = heavier tires. At low speed (climb), I'm not sure how significant is the reduced rolling resistance gain.
Not a newbie to cycling
Bikes: Omnium Cargo Ti with Rohloff, Bullitt Milk Plus, Dahon Smooth Hound
Quoted: 356 Post(s)
Liked 318 Times
That test shows that the rolling resistance goes down only if the two tyres are at the same pressure. But that it goes up the wider you get if use the recommended pressure which results in a 15% drop of the tyre when loaded:
Look at the part that says:
Rolling Resistance at Recommended Air Pressures (15% tire drop)
Likes For CargoDane:
Quoted: 355 Post(s)
Liked 201 Times
32mm GP5000 TL's are awesome.
I switched from tubed 28 GP5000s to these, and have been very happy. I wouldn't say the difference between them is dramatic, but the 32s definitely don't feel any slower and I can run them at lower pressure which makes for a more comfortable ride on rough stuff.
I'm around 165 and run my tubeless 32s at about 55-60psi on a 19mm internal rim.
Likes For msu2001la:
That struck me as odd, so I clicked through and looked at the pressures they were running.
Quoted: 356 Post(s)
Liked 318 Times
When adjusted for drop the Rolling Resistance is virtually the same (within .1 of a watt) however the RR calculations are flawed because they do not take real-world road conditions into account. The irregularities and imperfections in our roads skew the advantage substantially in a wider tires advantage. Also not taken into account the energy which our bodies must absorb from a narrow high-pressure tire, there are numerous studies including a famous one from the US Army on the fatigue effects of vibration on Tank Crews.
All I did was correcting a misunderstanding with the referred test. It did not, in fact, show that rolling resistance dropped the wider tyre you have unless the tyres were pumped to the same bar/psi.
Personally, I much prefer wider tyres (within reason) myself. But that's mostly a preference and certainly not based on rolling resistance (well, within reason).
Add:
There's a .6 watt difference between the 28 and 32mm. That really doesn't matter, but it's not lower in that particular test.
Quoted: 54 Post(s)
Liked 43 Times
The idea that larger tires roll better because they perform better in RR tests at the same pressure (which is comfort and suspension wise equivalent to inflating the narrower tire to a higher pressure still) and because they have lower suspension losses because they can be inflated to lower pressure is like having your cake and eating it too. Either you have one or the other.
Personally, if i'm going on one of the bumpier roads, I just inflate my tires a bit less. Latex tubes made a felt difference, even at higher pressures it is very comfortable.
Unfortunately, I haven't seen any real efforts to quantify the significance of this. The oft-cited BicycleRollingResistance article just assumes that equal absolute drop implies equal compliance with respect to surface irregularities.
lead on, macduff!
Quoted: 869 Post(s)
Liked 904 Times
the '23's force me to pay better attention vs zoning out. kinda like a manual transmission/stick vs automatic transmission.
that said, if i'm in ogsargville/central ca land where the pavement can be a serious issue (as per dozens of pics and personal experience), i'm likely rocking '25's on the rollers and flats.
i'll just suck it up and go slower on steep hills/mtn climbs on '23's. if there is any dirt involved, it's '28's. if i'm doing multiple rides involving different terrain, i'll bring another compatible wheelset and
the applicable tires.
Research may have shown that wider equals less RR, but it's not the only thing to consider if your goal is to shave a few seconds off your century trip.
This. There are so many ''real world'' factors and other relevant factors to consider. For instance, air resistance: Wider tire = increased resistance. Mass: Narrow tire = lighter = faster acceleration when needed.
Pointy Helmet Tribe
Quoted: 476 Post(s)
Liked 572 Times
And re the aero part - what little you lose in aero, you probably gain in reduced vibration losses. Silca has a really good article explaining that - worth checking out. And if you have a modern wheel, what little aero disadvantage you have at 0 yaw gets offset by better handling at yaw. Eg, Roval Rapides.
Pointy Helmet Tribe
Quoted: 476 Post(s)
Liked 572 Times
I eat carbide.
Bikes: Lots. Van Dessel and Squid Dealer
Quoted: 895 Post(s)
Liked 409 Times
OP - 25.
We used to consider 25's wide. Not it's not wide until you're over 32 apparently. That's ridiculous. I know a lot of really fast guys that rode 28's even back in the day who now feel like they've been validated but let's be real: It's a bit like saying some day recumbent riders will be validated for having the faster bikes.
At some point we have to stop putting monster truck tires on supercars.
You guys have fun on your Barcaloungers though. I'll be waiting for the kids to bring back narrower tires, triples, smaller cogs, bigger chainrings, rim brakes, etc. It's not like we haven't covered all of this multiple times in the ~140 years of bicycle development, manufacturing and use.
OP - seriously just pick a tire size. In that range you're not missing anything even remotely ground breaking or life changing in either direction.
PSIMET Wheels, PSIMET Racing, PSIMET Neutral Race Support, and 11 Jackson Coffee
Podcast - YouTube Channel
Video about PSIMET Wheels
Sophomore Member
Liked 1,043 Times
We've already got this thread:
https://www.bikeforums.net/general-c...l#post21767943
Maybe it's time for a "Heavy Tires Are Better!" thread as well.
