Sunglasses HELP!
Sunglasses HELP!
Hi all, I'm about to invest in my first pair of cycling sunglasses after taking up riding in the UK during lockdown. The majority of my rides are on towpaths, alongside canals and a mix of being in shaded areas and in bright sunshine. But with the typical British weather I need something that will also work in overcast conditions. I don't want to have to change lenses so do I go for a photochromic lens or look at something like the Oakley Prizm Trail Torch - would the latter be any good in overcast conditions? Any suggestions of makes and advice would be much appreciated. Also looking at Bolle Lightshifter photochromic Phantom glasses if anyone has any experience with these? Many thanks in advance.
Quoted: 6963 Post(s)
Liked 10,961 Times
Quoted: 336 Post(s)
Liked 309 Times
I have the Oakley photochromic lenses, prizm road, and the prizm trail.
I live in Portland, Oregon, and commute year round. For my commutes, I use the photochromic almost exclusively. The only exceptions are in the summer when it is reliably sunny, sunrise is before 6AM and sets at 9PM - Prizm Road for those days.
Both the Prizm Trail and Photochromic are great for cloudy conditions. I primarily use the Prizm Trail if I am going to spend a lot of time off road, or a lot of time in canopy, where I frequently go from sun to shade. I also use them if I am going to be in canopy on a cloudy day.
The Photochromic is what I take if I am leaving before dark, returning after dark, or I am going to be in partly sunny conditions. The photochromic lens goes from nearly clear to a light grey. You can use them in the dark, or in full sun. While a dark polarized lens (or Prizm Road) is more comfortable in full sun, the Photochromic is just dark enough to be acceptable for me. There are a couple of downsides of the Photochromic. The first is that they are relatively slow to change from light to dark and vice-versa. They are not going to adjust quickly when riding in and out of canopy in bright sun. They adjust to what I would call the average condition. I actually like this.
The second downside to the photochromic is that they are completely useless for driving. They adjust to darkness with UV light, and automotive glass removes most UV light. Even in bright sun, they will not darken if you are in the car.
If I could only have one lens for riding in my climate (300 cloudy days per year), it would be the photochromic. While I love my Prism trail for gravel rides and mountain biking, and the Prism Roam for road rides on one of the 60 sunny days per year, the photochromic is the only one that I can ride comfortably in the dark, but still be comfortable in full sun.
Likes For aggiegrads:
Bikes: Moseman with Campy NR circa 1979, Merlin Titanium from1993 with newly installed Campy Chorus 12, Raleigh Tamland II gravel grinder, Tommassini XFire with Campy Record
Quoted: 30 Post(s)
Liked 104 Times
I have some expensive photochromic glasses for fly fishing. Polarized lenses are a must for seeing fish. I also go for glass lenses as thy are more scratch resistant, though can break. So, I am willing to spend because it makes a difference.
I’ve gone the other direction with cycling glasses. I’ve had Bolle and Oakleys in previous iterations, but now find I’m not missing anything with much less expensive Tifosi glasses with photochromic lenses that are not polarized. They don’t get perfectly clear in overcast conditions so I do have clear lenses (19 bucks) that I use rarely. I suspect you’ll have that issue with any photochromic lenses. I don’t feel I’m missing anything even on those all day rides. I’m eager to see what others say.
On Your Left
Quoted: 3004 Post(s)
Liked 2,433 Times
I have Rudy Project. They go from clear to really dark quickly.
Likes For GlennR:
Photochromic lenses don’t change very fast, so they aren’t helpful for going in and out of shadows, but they can be useful for leaving when it’s dark and adjusting as the sun comes up (or leaving in daylight and returning at dark). A lot of times they also don’t get as dark as non-photosensitive lenses.
I’ve had the best luck with 80% amber lenses. They let enough light through to see just before dawn and still provide relief after the sun comes up. A blue mirror coating will make them a little darker, providing more bright light protection at the expense of pre-dawn visibility.
Liked 10,961 Times
Now that I've had my morning coffee, allow me to give a bit more info.
I have the Prizm Trail, which is almost identical to the Prizm Trail Torch that you are considering. The tint is light enough to be useful in light-to-heavy overcast conditions which are common in winter time around here, or off-road under tree cover. The lens has a pink-ish tint which punches up the contrast, and that also helps in flat lighting -- makes the road surface easier to read for potholes and such.
If there is one knock on the lens, it's that it is not quite dark enough for bright full sunlight - though it's usable, it is not optimal. But if you need a darker lens for such conditions, you can buy a Black Iridium lens and swap it in...It's generally about the cheapest replacement lens that Oakley sells.
And by the way, I've owned various brands, but only buy Oakley for riding glasses now. Top quality and durable.
Bikes: nothing to brag about
Quoted: 130 Post(s)
Liked 206 Times
I recently discovered a whole new category of biking sunglasses. Safety glasses. They are wraparound with minimal frames that are adjustable in several ways, come in various tints, and are dirt cheap--most less than $7! There are varieties that look just like sunglasses. Also, they come in anti-fog versions and it really does work. I have clear for night, yellow for dusk, and for sun I prefer the more lightly-tinted ones for the reason you are asking: they're good in both sun and shade. And that's my recommendation: whatever you get, don't get anything darker that you absolutely need and you will find it good in most lighting situations.
In the US, a good brand and my favorite style is the Pyramex Rendevous ($2.79!) Lose them, break them, get tired of them . . . at that price it really doesn't matter.
https://www.amazon.com/stores/page/B...ridPageIndex=2
On Your Left
Liked 2,433 Times
Clear - I have prescription additional lenses, they are optional.
Dark
Bikes: 2017 Colnago C-RS, 2012 Colnago Ace, 2010 Giant Cypress hybrid
Quoted: 408 Post(s)
Liked 122 Times
Tifosi makes some very nice photochromatic sunglasses and they are nowhere near as expensive as some of the one's mentioned. You may want to look into them, as well.
HCFR Cycling Team
Ride Safe ... Ride Hard ... Ride Daily
2017 Colnago C-RS
2012 Colnago Ace
2010 Giant Cypress
HCFR Cycling Team
2017 Colnago C-RS
2012 Colnago Ace
2010 Giant Cypress
Likes For John_V:
Quoted: 30 Post(s)
Liked 104 Times
Smoke
Quoted: 590 Post(s)
Liked 445 Times
I like the Tifosi Seek line. Having no frame at the top of the lens allows you to see more of the road ahead while you're head is down, in an aero position.
https://www.tifosioptics.com/product...c-matte-black/
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
Polaroid? They take self-developing photos too?
Am I the only one that thinks it's funny when someone posts a thread with a title like this? All or mostly caps and a bunch of !!! ? Like their life depends on getting an answer asap.
https://www.probikekit.co.uk/sports-clothing/oakley-radar-ev-path-sunglasses-matte-black-prizm-road/11373333.html?affil=thggpsad&switchcurrency=GBP&shippingcountry=GB&shoppingpid=spend_and_save_v2&&th g_ppc_campaign=71700000073341592&gclid=CjwKCAiA-_L9BRBQEiwA-bm5fhuczfV1FlQf7fe8gFbLnPrTwJ7v3U2dnUvi6sUDVQT2r498J7IOVxoCFEsQAvD_BwE&gclsrc=aw.ds
have worn them every ride, in all conditions, most comfortable glasses I've ever had. Lenses have performed well in all conditions, best 100 quid I've spent in a long time!
Quoted: 27 Post(s)
Liked 18 Times
vote for photochromatics
Tend to agree with aggiegrad . Have a set of Oakleys photochromatic lenses that tend to be so versatile I wear them often in all but the high and bright sunny days of summer. Just recently was telling the wife it was one of my best investments in cycling. Being older my eyes dry out easily so I tend to never ride without glasses and these are just so versatile. Good luck in your decision.
I recently found safety reading glasses, so for night rides I now use those and get the magnification I would ordinarily get from my regular readers.
Advocatus Diaboli
Quoted: 4733 Post(s)
Liked 1,532 Times
I really like, though maybe this is nose and face-fit dependent, the Smith brand glasses. If I was picking up a new pair, I'd be probably getting something like the below for your conditions, in the Opal Blue maybe
https://www.smithoptics.com/en_US/su...UNGLASSES.html
