Pain at back of leg, top of calf/right below knee
Old 01-28-08, 12:37 PM
ImprezaDrvr
Back in the Sooner State
Got the new bike, overdid a bit, but have pain in a place I've never had it before. After climbing with some stronger guys and not keeping up, I've ended up with pain that was initially at the bottom of my hamstring near my knee but has settled in near the top of my calf. It's just to the outside of the middle of my leg. I've had some speculate that it is a strain at the spot where the hamstring attaches at its low point, but wonder if anyone can shed any light on it? There's no bruising or severe pain, so I'm pretty sure that a week off and ice and such will take care of it, but it's strange nonetheless and I'd like to hear from anyone that may be able to shed some light on it.
Thanks in advance!
ImprezaDrvr is offline
Old 01-28-08, 12:40 PM
JayC
Guadzilla
JayC's Avatar
Bikes: Pinarello F4:13 W/Campy Reecord & Blue RC6 W/SRAM Force
Liked 3 Times in 2 Posts
HTFU?
Seriously, sounds like you just overdid it. Ive had pains in that general vicinity as well.. I usually just take 800mg of ibuprofen and keep on riding.
For pains like that that Im pretty sure are just strains, I try to work them out gently.. get on the bike and just spin around at recovery pace. If it gets worse, go to the doctor.
Rest works too.. Im just stubborn like that.
JayC is offline
Old 01-28-08, 12:43 PM
daytonian
elitist jerk
daytonian's Avatar
Bikes: CAAD9
Thanks in advance!
Had same issue in June. I was told it's strained IT band. I made sure cleats were aligned properly, raised seat, and stretched hams, calves, and quads thoroughly before every ride. Higher cadence on climbs keeps me from noticing as much.
daytonian is offline
Old 01-28-08, 12:52 PM
StanSeven
Administrator
Bikes: Cervelo C5, Guru Photon, Waterford, Specialized CX
Quoted: 1104 Post(s)
Liked 2,167 Times in 1,459 Posts
The "new bike" part of your post is key. Unless your new bike is exactly set up like your other bike in terms of physical dimensions, you are subjecting to body (mostly legs) to alot of new/different stress. Take the time length of your ride multipled by your cadence and you'll quickly conclude your legs are subjected to thousands of movement actions. Then consider a new bike with maybe 1/2 degree difference in the seat tube angle, a saddle that is 1/2" in a difference location, crank arms that might have different lengths, a saddle that is slighly higher or lower from the bb than your currenet setup, etc. You atre subjecteing your body to things it isn't quite used to.
Take some time off until the pain subsides. Use the time to compare your two bikes and make any adjustments needed to the new setup. When you go back out, do some slow, easy rides and build up gradually and don't try to hang in with the stronger guys jsut yet.
StanSeven is offline
Old 01-28-08, 01:29 PM
Doggus
half man - half sheep
Doggus's Avatar
Location: Big Mineral arm - Lake Texoma (Pottsboro, Tx)
Quoted: 9 Post(s)
I play a doctor on TV and the IT band is above the knee on the front-outside of the leg. The OP said the pain is in the back of the leg below the hamstring and above the calf. I have this exact same injury and it has lasted for over a year and a half. It started one day when I went to hard to soon and has plagued me ever since. Be careful to let it heal before you have the same problem I have.
Doggus is offline
Old 01-28-08, 02:28 PM
waterrockets
Making a kilometer blurry
waterrockets's Avatar
Bikes: rkwaki's porn collection
Quoted: 37 Post(s)
Liked 91 Times in 38 Posts
I'm still getting over a similar pain, although mine is more toward the center of the back of the knee. I've isolated mine to be calf-related, not hamstring, but it's triggered by either sometimes.
Anyway, I took an easy day to learn what made it hurt, and quickly discovered what motions and flexions to avoid, and it started getting better right away. Interestingly, higher cadence was much less comfortable than lower cadence.
It still comes back a little bit (it's been a month), but most of the time I don't have any pain for any motion. It hasn't hampered me at all though -- power numbers keep climbing.
waterrockets is offline
Old 01-28-08, 03:08 PM
Brian Ratliff
Brian Ratliff's Avatar
Bikes: Three road bikes. Two track bikes.
Quoted: 47 Post(s)
Liked 4 Times in 4 Posts
I've had this too, at one time to the point where there was some bruising at the inside back of my knee. It has something to do with the muscles back there - it didn't act like a ligiment or tendon problem. It would come and go during a ride, and it would start out bad, and gradually get better as the ride progressed, provided I didn't aggravate it again - like a strained muscle. For me, it was probably hamstring related rather than calf related.
Two issues contribed when I had this (I found this from experimenting). One was a saddle which was too high/having a hamstring that wasn't flexible enough for the amount of leg extension I was using. The other was straining during hard efforts going up hills because my hamstrings would start pulling too early in the pedal stroke. Basically, pedalling square.
If this sounds similar to what you have, you might try lowering your saddle a smidge. I was adjusting things in 1/8 inch increments. If you lower the saddle too much, you'll get pain in front of your knee and underneath the kneecap which is ligament inflamation and is much more serious and potentially long term. The pain behind you knee will heal - it is likely muscular. Pain in front of your knee might be permanent if you ride with it for long - ligaments don't get much blood flow and so heal very slowly, and if damaged enough, not at all. Do toe touching exercises to increase the flexability of your hamstrings and work on pedaling in circles.
Disclaimer: I am an engineer and not a doctor - I don't even play one on TV. This is just my experience and if you really want to know what is going on under your skin, see your doctor. They might not be able to tell you how to adjust your bike to minimize the problem, but they'll be able to tell you what's wrong at the body level.
Cat 2 Track, Cat 3 Road.
"If you’re new enough [to racing] that you would ask such question, then i would hazard a guess that if you just made up a workout that sounded hard to do, and did it, you’d probably get faster." --the tiniest sprinter
Brian Ratliff is offline
Old 01-28-08, 03:44 PM
dmac
Had same problem.
Check your saddle position.
https://www.cptips.com/knee.htm
specifically:
https://www.cptips.com/pknee.htm
Had the same problem. Few weeks on the trainer and a lot of cleat adjustments and saddle adjustments until I found the problem. I had swapped saddles and seatpost from original and my position was way off.
dmac is offline
Old 01-28-08, 04:06 PM
Brian Ratliff
Quoted: 47 Post(s)
That explains it to a "T".
Treatment would include
  • a period of decreased training
  • addressing biomechanical factors (leg assymmetry)
  • adjusting your saddle down a few millimeters
Old 01-28-08, 05:16 PM
Machka
In Real Life
Machka's Avatar
Bikes: Lots
Quoted: 3203 Post(s)
Liked 596 Times in 329 Posts
Originally Posted by dmac
Had same problem.
specifically:
+1 on the https://www.cptips.com/knee.htm link.
Machka is offline
Old 01-28-08, 08:51 PM
wolfpack
Rawwrrrrrrrrr!
wolfpack's Avatar
Bikes: 2009 Specialized Ruby Sworks SL w/SRAM Red; 2006 Fuji Team RC; 2008 Felt F1x; 1980's Lotus Excelle; Mangusta FG/SS; Rossin (yet to be built up)
Liked 2 Times in 1 Post
Originally Posted by JayC
HTFU?
No - sometimes HTFU is not the appropriate response, especially to those of us who actually try to do that and end up getting hurt.
prolly better rest it a bit and then, if you don't do this, learn to spin more when you ride.....i did that last yr and ended up with bursitis/tendonitis in my right knee, that kept me off the bike for 2mo over teh summer and is a continually nagging problem....
wolfpackcycles
skiffrun: Enjoy the ride. Ride for the enjoyment.
wolfpack is offline
Old 01-28-08, 09:49 PM
revolator
ROAD enthusiast
revolator's Avatar
Had same problem.
specifically:
+1
I had the same problem. I had to replace my seat, got the pains as you described. Made some adjustments before I saw the orthopedic, but he put his finger on it and confirmed it.
- most of my adjustments was moving the seat forward
- did lower it a tad
- readjusted my cleat a tad also.
I also have the other problem, runner's knee (running,skiing,basketball)
Which is what led me back to cycing.
revolator is offline
Old 01-29-08, 09:36 AM
ImprezaDrvr
I was the first to admit that I did too much and am resting it. It's much better now than it was on SUnday, which is a good sign, but I'm not riding a bit until at least Thursday and probably not until Saturday. I'm still taking a couple of ibuprofin and icing as well.
Thanks to all for the assistance. I'm going to ask my PT wife to check for leg length discrepancies, too. I've got shims in case I need them. I may also lower my saddle a bit until the legs are used to the new position. I don't want to jeopardize the season after putting in some decent winter hours up to now.
Old 01-29-08, 10:35 AM
maddmaxx
Boomer
maddmaxx's Avatar
Bikes: Diamondback Clarity II frame homebuilt.
Quoted: 16098 Post(s)
Liked 1,457 Times in 1,064 Posts
This pain is common to runners and unfortunately does not heal a rapidly as one thinks. It is common to reinjure this point by returning too soon. Sorry the following link is not an active one, so you will have to copy and past it into your browser.
https://www.sportsinjuryclinic.net/cy...calfstrain.htm
Edit: there is some good information here although parts about heel pads are not really usefull for cycling.
maddmaxx is offline
Old 01-29-08, 02:36 PM
ImprezaDrvr
Standing on tip-toes hasn't ever bothered it, so I'm leaning away from it being a strained calf at this point. The pain has always been the worst as my leg has gotten out in front of me as I walk and my hamstring slows my lower leg down.
But thanks for the suggestion, and thanks again to everyone for their advice and links. Like I said up front, I know that I overdid it with the new fit. But I also know that the new fit is more comfortable. Saddle is higher and further forward. I usually pulled myself forward before anyway. The height is probably a bit much, but again, it could be a leg length problem. I'll lower the saddle a bit and take it easier until I'm used to the position, then get up to where it is now. In short, I fully realize that it was too much, too soon with a new fit, but I was curious about others' experience with this pain as i've had lots of knee pains over the years but nothing like this until now.
Old 01-30-08, 01:08 AM
oilman_15106
Thought IT band pain was on the side of the knee? Anyway my take it is just overwork of muscle groups from a new riding position. Also although the standard advice is ice and rest there is a camp that says you will recover faster if you start riding at a really light pace on a flat course.
oilman_15106 is offline
Old 06-04-17, 08:47 AM
aralph
Sorry to receive an old thread but...
Wondering if OP ever resolved this issue and if so what was the fix or the culprit for the pain? Having this exact same issue (pain behind knee on back of leg). No real changes to bike setup. Been having pain for over a month and wondering if I need to take off from riding or make some changes to setup.
aralph is offline
Old 06-04-17, 11:35 AM
Carbonfiberboy
just another gosling
Carbonfiberboy's Avatar
Quoted: 3878 Post(s)
Liked 1,930 Times in 1,377 Posts
Happens to me fairly often - it's a reminder to push forward more at the top of the stoke to relieve the pull-back pressure at the bottom. That fixes it right up. No need to change anything else. I think it happens more to those of us with strong hams.
Results matter
Carbonfiberboy is offline
Old 06-04-17, 04:24 PM
Scarbo
Erik the Inveigler
Scarbo's Avatar
Quoted: 1310 Post(s)
I second this. It really sounds as though the saddle might be a bit too high.
Scarbo is offline
Old 02-17-20, 03:06 PM
flitz
My first post in this forum, hello bikeforum world!
Its quite some time since the last post and even more since the startinf of this thread. I have similar pains, back of the knee outside after a too long ride for me, stupidly I didnt stop as we were bickepacking I continued for three weeks with around 100km a day... After a year I still have this pain. Does someone know how people solve it or does anyone have any tips?
Thanks in advance!
flitz
flitz is offline
Old 10-28-20, 05:06 AM
aralph
Thanks in advance!
flitz
Any luck? My pain just returned after 3 yrs. No changes to bike fit. Just went out one day for a 60 mi solo ride and the pain returned. This is a typical pace and distance for me, routine bike route. Taking some time off as I believe that's how I got over it last time.
aralph is offline
Old 10-29-20, 02:32 AM
flitz
How long did you w8? Im doing strength and stretching a lot now, seems to help!
flitz is offline
Old 10-29-20, 05:42 AM
aralph
Don't recall. Maybe a month.
aralph is offline
Old 10-29-20, 07:09 AM
Fiery
Fiery's Avatar
Quoted: 242 Post(s)
Liked 18 Times in 13 Posts
... back of the knee outside...
While general pain in the back of the knee is a sign of the saddle being too high and/or too far back, I have had pain in the outside back of the knee caused by riding with a too narrow stance (moved my cleats all the way toward the outside of my shoes). It seems that this caused overuse of the outside part of the hamstrings on one leg that persisted even after increasing my stance on the pedals. It got resolved when I started focusing on driving through the big toe with that leg, this changed muscle activation patterns and rebalanced the load on the hamstrings.
An exercise that seems to diagnose this sort of hamstring pain well is single leg hamstring bridges (even better on a stability ball). Years after the injury I can still feel tenderness on the outside of that knee when doing this exercise if I don't activate the inner hamstrings correctly.
Fiery is offline
Old 10-29-20, 09:05 AM
flitz
An exercise that seems to diagnose this sort of hamstring pain well is shsb. (even better on a stability ball). Years after the injury I can still feel tenderness on the outside of that knee when doing this exercise if I don't activate the inner hamstrings correctly.
I will try this asap when home from my office. The pain is more in the calf though. But it might be due to my hamstrings. I will also try riding my bike through my big toe from today. I will report back in a couple of weeks. As I had this pain for a good 1.5 years now it will probably take some time. I dindt have it all the time but it just keeps coming back... /;
flitz is offline
