How to use a single training wheel?
maybe an explanation
Am not a learner, but older cyclist with balance problems. I have a Cannondale multi gear. Adding training wheels to this looks complex and expensive, could a simple single wheel (away from the gears) help me ? Anyone?
Quoted: 5703 Post(s)
Liked 2,427 Times
This is a problematic trade off for adults. Because of the height and weight involved, trainers usually hace to be set for full time ground contacr, holding the bike rigidly vertical. As such it rides more like a trike than a bike, except it's much more tippy.
A single trainer won't help, because it affords to anti-tip protection in the other direction. Plus if it's set to allow you the normal side tilting of a bike it won't bd reliable to keep you from falling.
It's hard to advise without knowing the details of your condition. Balacing a bike is s learned process involving the cerebellum which uses steering inputs to keep the bike under you. It's the same functional pathways you use for walking, and just about all your motion controls.
So, if you have no brain injury, odds are you'll improve over z short time frame.
OTOH, if you do have a brain injury affecting motion control, usually such that you walk like a drunk, then you'll have comparable issues riding, and may have to limit yourself to MUPs, and speeds where you aren't likely to get injured in a fall.
Or consider z trike, or recumbent trike.
FB
Chain-L site
FB
Chain-L site
Bikes: Eddy Merckx Corsa Extra, Basso Loto, Pinarello Stelvio, Redline Cyclocross
Quoted: 336 Post(s)
I would suggest a recumbent trike. I met a guy with a paralyzed arm that had ridden one across the USA and back so they must work well. I had a bit of trouble getting on and off but I imagine that would improve with experience. It did ride nicely from the very first.
Depending on the source of your balance issues, 3 wheels is likely the way to go. There are upright and recumbent trikes. Recumbent is going to get better use of your gluteus muscles and get you more distance with same effort. Recumbent trikes can be taller than you think, and are visible in traffic.
Quoted: 2473 Post(s)
Liked 722 Times
LBKA (formerly punkncat)
Quoted: 2208 Post(s)
Liked 960 Times
The problem you will run into is a question of physics. You can compensate and balance on the free side, but if you try to correct to the training wheel side you will "bounce" off and go down hard on the free side. This issue is easily evident watching any child with a (set) of training wheels as they bounce from wheel to wheel before they find balance. Don't do it.
Bikes: WWII Wehrmacht M30
Do you think more people would be interested in unicycles with training wheels?
They could potentially come in two or three wheel configurations, and they would make unicycles easier and safer to ride.
Bikes: 36" Unicycle, winter knock-around hybrid bike
Quoted: 930 Post(s)
Liked 393 Times
An ordinary bicycle, or a well designed tricycle make more sense - wheels not included in the original design just don't work well, since everything changes based on their number and location, and beyond three you need an adaptive suspension.
The only reason to ride a unicycle is if you actually want to be riding a unicycle... which is not what you are doing if your cycle has more than one wheel (that contacts the ground; vertical stacks exempted since the extra wheels are just power transmission)
but, off the shelf, from your neighborhood Shop, you may want to buy a Trike..
they have 2 rear wheels and a comfy seat..
a bike with a single wheel added to one side , that wheel is, best, if part of a sidecar..
Quoted: 551 Post(s)
Liked 276 Times
Is it important to you that you ride a diamond frame bike or are you open to other options?
Tryke
Adaptive Cycling: Handcycles, Amputee Adaptation, Visual Impairment, and Other Needs
9
12-26-15 08:38 AM
