Sore legs, any miracle potions?
Old 05-17-19, 08:27 AM
big chainring
Quoted: 752 Post(s)
Liked 730 Times in 353 Posts
Its almost Spring in the midwest. Getting out on the bike more frequently, but still have layoffs of a week sometimes two weeks between rides. And I do physical labor for a job, painting contractor. Its killer going out for a ride on Sunday, followed up with heavy work days monday thru friday, then back to the bike on weekends. Any supplements recommended?
The bad....sore legs
The good....feel great on the bike.
big chainring is offline
Old 05-17-19, 08:34 AM
FiftySix
I'm the anecdote.
Bikes: '12 Schwinn, '13 Norco
Quoted: 1110 Post(s)
Liked 1,176 Times in 795 Posts
In for the advice. Last night the leg cramps were waking me up. I'm thinking taking too many days off from riding did it this time.
Usually, I try and ride 4 times a week and feel pretty good, even if my knees start out with some pain.
This past week, I was in another city for a machine repair job Sunday night and didn't make it back home until 11pm Wednesday night. Yesterday was another day of field repairs locally, but I had to mow the yard before sunset instead of riding the bike.
So no riding since early Sunday morning and last night the leg cramps arrived, which I haven't had in a while.
FiftySix is offline
Old 05-17-19, 08:43 AM
FrenchFit
The Left Coast, USA
FrenchFit's Avatar
Bikes: Bulls, Bianchi, Koga, Trek, Miyata
Quoted: 361 Post(s)
Liked 25 Times in 18 Posts
Works for me: https://www.amazon.com/Zahler-Enrich...-2-spons&psc=1
There is more to life than simply increasing its speed. - Gandhi
FrenchFit is offline
Old 05-17-19, 10:25 AM
Flip Flop Rider
Flip Flop Rider's Avatar
Bikes: 2010 Fuji Absolute 3.0 1994 Trek 850
Quoted: 762 Post(s)
Liked 555 Times in 322 Posts
ride more, seriously. the pain will go away
Flip Flop Rider is offline
Likes For Flip Flop Rider:
Old 05-17-19, 10:36 AM
berner
Quoted: 663 Post(s)
Liked 496 Times in 299 Posts
For some, compression socks or compression tights help quiet a bit. Runners frequently use them as well as myself. Since diabetics often use compression socks, I surmise the discomfort is related to poor circulation.
berner is offline
Old 05-17-19, 10:43 AM
jadocs
jadocs's Avatar
Quoted: 942 Post(s)
Liked 527 Times in 349 Posts
Incorporate recovery rides when you legs are sore. This is zone 1 power, you are basically spinning at a higher cadence (not mashing) with not much effort at all on the pedals. It will clear the lactic acid out of your legs faster than just waiting for it to go away on it's own.
jadocs is offline
Old 05-17-19, 10:45 AM
shelbyfv
Expired Member
shelbyfv's Avatar
Quoted: 3674 Post(s)
Liked 5,431 Times in 2,759 Posts
About 1/4 cup pickle juice, 1 teaspoon Cayenne pepper, water to fill a regular size glass and ice. Makes a refreshing after ride drink and is said to prevent cramps.
shelbyfv is offline
Old 05-17-19, 10:50 AM
FBOATSB
FBOATSB's Avatar
Quoted: 913 Post(s)
Liked 515 Times in 344 Posts
Painting contractor? It's spending an entire shift on stepladders that does me in. Guaranteed leg cramps that night. I have to force myself to go for a ride that evening, even if short distance or on the indoor machine. It helps me a great deal to relax the tight leg muscles. Magnesium supplements or gel before bed, and pickle juice for actual attacks.
FBOATSB is offline
Old 05-17-19, 11:18 AM
5teve
Quoted: 69 Post(s)
Liked 65 Times in 29 Posts
Well, I don't know if my experience will apply to your situation. The problem I have is that my legs burn and feel fatigued before I think they should. It feels like what used to be referred to as a build up of lactic acid in the muscle tissue, though I think current thinking on what is actually happening has changed a bit. Because of it, I had to back off on a climb or ease up from a harder pace because that burning sensation forced me to give up before I felt I'd given it all I could, before I felt my legs should really be tired. What has helped me is Sportlegs capsules. They aren't a miracle drug-they don't make me feel strong if I'm not in shape, but they help hold off the lactic acid burn sensation that I've felt was holding me back these past couple years.
5teve is offline
Old 05-17-19, 11:54 AM
bogydave
bogydave's Avatar
Bikes: /Skye/ Torker mt, Sirrus flat bar
Quoted: 188 Post(s)
Liked 24 Times in 10 Posts
+1
bogydave is offline
Old 05-17-19, 02:37 PM
rumrunn6
rumrunn6's Avatar
Quoted: 5224 Post(s)
Liked 3,581 Times in 2,342 Posts
tiny does of magnesium & hot soaks in epsom baths w/ massage, using foaming bath soap of choice. 20 minute minimum. 1/2 glass of red wine helps too. I've soaked long enough for the water to cool. there's no danger of using too much epsom salt or soaking too long. I prefer the cheap epsom salt from Walmart & Dr Teal's Eucalyptus and Spearmint Foaming Bath
rumrunn6 is offline
Likes For rumrunn6:
Old 05-17-19, 02:51 PM
Lemond1985
Sophomore Member
Lemond1985's Avatar
Quoted: 1628 Post(s)
Liked 1,057 Times in 631 Posts
I mentioned "lactic acid" as causing muscle soreness, in another thread, and someone jumped all over me for it. I think they were saying the soreness was not caused by lactic acid at all, lactic acid is in muscles only during exercise.
I had not heard about this previously, not sure if it's actual science or not, I think it's a somewhat recent discovery.
Don?t blame lactic acid for sore muscles | ScienceNordic
Ask your average amateur athlete what causes stiff muscles after a hard workout and more likely than not you’ll hear “lactic acid” as the answer.
When you train hard or at high intensity, your body has to turn to a kind of spare engine to produce enough energy. This “engine” is called anaerobic metabolism. When your body produces energy this way, your muscles can continue to work hard, but not for very long. Eventually your legs begin to tire and stiffen, and you can’t run as fast as before.
The conventional wisdom has been to blame this on lactic acid, a by-product of anaerobic metabolism. And because the amount of lactic acid tends to increase while your legs are in the process of stiffening up, people concluded that lactic acid is what makes your legs stiff and sore.
But it turns out that this is almost certainly not true.
Lemond1985 is offline
Old 05-17-19, 03:12 PM
CAT7RDR
Quoted: 822 Post(s)
Liked 1,960 Times in 943 Posts
I have had good results with Better than Blue sold by Swanson's for muscle soreness and arthritis.
https://www.swansonvitamins.com/swan...l-cream-SW1450
Of course it helps that my g/f is a massage therapist.
CAT7RDR is offline
Likes For CAT7RDR:
Old 05-17-19, 04:15 PM
MinnMan
MinnMan's Avatar
Bikes: 2022 Salsa Beargrease Carbon Deore 11, 2020 Salsa Warbird GRX 600, 2020 Canyon Ultimate CF SLX disc 9.0 Di2, 2020 Catrike Eola, 2016 Masi cxgr, 2011, Felt F3 Ltd, 2010 Trek 2.1, 2009 KHS Flite 220
Quoted: 4390 Post(s)
Liked 3,016 Times in 1,865 Posts
Miracle potions may be a minor aid, but it's already been said, the real solution is to ride more and to make sure you mix in hard and easy (recovery) rides. If you ride only on the weekends, it ain't going to happen. 4-5 rides a week, with about half being easy ones, is how you train your legs.
MinnMan is offline
Old 05-17-19, 04:27 PM
fietsbob
Bikes: 8
Quoted: 7607 Post(s)
try laying on your back, butt against the wall, legs straight up..
The oil that makes a massage go so well, is ineffective without the physical effort
of the masseur doing the work..
fietsbob is offline
Old 05-17-19, 04:30 PM
Hondo Gravel
Life Feeds On Life
Hondo Gravel's Avatar
Bikes: Too many Motobecanes
Quoted: 4423 Post(s)
Liked 4,527 Times in 3,029 Posts
Ice cold beer and you’re favorite music if that doesn’t work then take Naproxen
Hondo Gravel is offline
Old 05-17-19, 05:10 PM
Carbonfiberboy
just another gosling
Carbonfiberboy's Avatar
Quoted: 3889 Post(s)
Liked 1,938 Times in 1,383 Posts
Lactic acid isn't even what causes the burn. Technically it's lactate. In any case yes, lactate dissipates completely from the muscles in about an hour, maybe less for the well-trained. The lactate burn happens because your muscles aren't yet good at either using it for fuel or removing it from the muscle. The traditional method of lactate conditioning is to get in a long hill and go over your lactate threshold, get a good burn going - you'll be panting - then back it off to your upper aerobic zone - you'll be breathing deeply - then take it back up again and repeat until you can't anymore. Not the most fun anyone had, but it works. It's just a matter of conditioning.
Even more technically, it's now believed that it's not actually lactate that's making the muscles burn, but whatever it is, it's created at the same time as lactate, so might as well blame it on lactate because it's in the language now.
Muscle pain the next day or more usually, on the second day, is called DOMS, delayed onset muscle soreness. It's from microtears within the muscle. They take time to repair. In general one can hit it hard maybe 2 days in a row, then one needs a day or two of recovery or easier rides to allow the microtears to heal. If you keep hitting them before they heal, you get weaker, not stronger.
OTOH, sore legs aren't necessarily from DOMS, at least in my experience. Sometimes they're just sore. If I get on the bike and pedal and they still hurt after 1/2 hour, I give it up and pedal easy back home or just get off the rollers. In general, if sore legs on the bike are a consistent problem, you're not getting enough protein to heal them up. More usually they loosen up and feel OK after 1/2 hour of fighting the urge to give up and go home.
I ran a crew doing very hard but intermittent skilled manual labor. I found that going to the gym and working out really hard a couple times a week made a huge difference. Focus on the muscles which get sore. Beat the crap out of them.
As I say, supplements are a feather. Training is the hammer. If you're weak, train. That said, try electrolytes before bed and pickle juice for cramps. Not too much magnesium! My wife likes potassium. But that's for cramps, not sore legs.
Results matter
Carbonfiberboy is offline
Old 05-17-19, 05:17 PM
Lemond1985
Sophomore Member
Lemond1985's Avatar
Extremely informative, thanks!
Old 05-17-19, 05:31 PM
Chinghis
Bikes: Historical: Schwinn Speedster; Schwinn Collegiate; 1981 Ross Gran Tour; 1981 Dawes Atlantis; 1991 Specialized Rockhopper. Current: 1987 Ritchey Ultra; 1987 Centurion Ironman Dave Scott Master; 1992 Specialized Stumpjumper FS
Quoted: 209 Post(s)
Liked 178 Times in 111 Posts
I think that accomplishes the same thing I was going to suggest - massaging the legs, pushing up toward the heart, starting at the bottom. If I do this after a big long ride, I notice a difference the next day.
Of course, now that I type that out, it really just sounds like an old wive's tale (or folk wisdom, I guess, if it works).
Chinghis is offline
Old 05-17-19, 06:47 PM
canklecat
canklecat's Avatar
Quoted: 4560 Post(s)
Liked 2,802 Times in 1,800 Posts
All of the above, plus massage. Really seems to help my sore, stiff legs.
I use a massively heavy marble rolling pin to massage my legs. The weight makes it easy, other than doing my calves and hamstrings, which feel like bicep curls.
And foam rollers for the back, neck, etc.
I used to think the various topical analgesics I used were helping, but it was mostly the massage that goes with applying topical ointments. I get more relief from spending more time using the rolling pin on the legs and less worrying about the latest magical topical analgesic. Stopain roll-on works well enough, doesn't cost much and relieves some pain for about 20-30 minutes, mostly by fooling the nerves just under the skin for awhile with mint, wintergreen oil and MSM.
Anti-inflammatories might help but theories differ, especially about whether NSAIDs interfere with natural prostaglandins and whether we're trading some immediate relief for long term healing. I dunno. I take a prescription anti-inflammatory (oral diclofenac), bromelain (pineapple enzyme, supposedly a good non-NSAID anti-inflammatory and digestive enzyme), and CBD. I was skeptical about CBD claims for a year, until I found some that really works. No idea whether it's really an anti-inflammatory or just an analgesic. Either way, it works without the side effects of my prescription paid meds so I rarely take those anymore.
canklecat is offline
Old 05-17-19, 08:31 PM
TimothyH
- Soli Deo Gloria -
Quoted: 6844 Post(s)
Liked 736 Times in 469 Posts
A recovery ride has nothing to do with "spinning at high cadence."
What most people call recovery are really aerobic workouts - done at too high of an intensity and too long to be recovery.
Recovery rides are very short, low intensity rides. 45 minutes just breaking a sweat is enough. All you want to do is stimulate blood flow, bring fresh, oxygenated blood to the muscles to help aid recovery.
Sleep is the number one way to recover. Take a nap.
Take two Advil for sore legs.
Delayed Onset Muscle Soreness WebMD
-Tim-
TimothyH is offline
Old 05-18-19, 05:50 AM
Trsnrtr
Super Modest
Trsnrtr's Avatar
Quoted: 10963 Post(s)
Liked 4,620 Times in 2,123 Posts
Quoted for truth.
Keep the chain tight!
Trsnrtr is offline
Old 05-18-19, 05:51 AM
Trsnrtr
Super Modest
Trsnrtr's Avatar
-Tim-
Also, good info.
Trsnrtr is offline
Old 05-18-19, 07:28 AM
Clyde1820
Bikes: 1996 Trek 970 ZX Single Track 2x11
Quoted: 614 Post(s)
Liked 565 Times in 429 Posts
Best "potions" I've found for sore muscles have been, generally speaking: long soaks in hot water; massage, kneading the muscles, along with "out with the bad blood / in with the good"; stretching the affected areas; and, of course, lightly exercising the strained areas to help them loosen up, get blood and nutrients to the area to aid repair.
Of course, as we age, the amount of good that comes from continuing to exercise an area can be less and less as the years go on. But, still, stretching + heat + massage + exercise + nutrition ... or, as the docs say it: diet and exercise ... I haven't found anything better in nearly 50yrs of athletic activity. The "magic elixir" of life, I suppose one might call it.
Clyde1820 is offline
Old 05-18-19, 07:59 AM
eja_ bottecchia
eja_ bottecchia's Avatar
Quoted: 1020 Post(s)
Liked 463 Times in 293 Posts
Getting old(er) is not for the faint of heart, or legs.
“Those who wait upon the Lord shall have their strength renewed, they will mount up with wings like eagles, they will run and not grow weary, they will walk and not faint...” Isaiah 40:31
From one of my favorite scenes in Chariots of Fire...and from the Bible, of course
eja_ bottecchia is offline
