front derailer, inner limit screw
Quoted: 5224 Post(s)
Liked 3,581 Times
if I just want to adjust the front derailer inner limit screw so that the derailer moves a mm or two away from the frame, meaning outward, to the right
does anyone know, off the top of your head:
1- which way do I turn the screw?
2- do I need to have the chain in any special place, meaning like on the small front chainring? & or the big rear chainring?
Really Old Senior Member
I'd suggest holding the FDER over with one hand to relieve tension on the screw. It saves threads in the FDER body.
It's relatively soft aluminum & steel threads tend to wear it badly when screwed under tension.
It's a limit screw, not a jacking screw.
Likes For Bill Kapaun:
Quoted: 1438 Post(s)
Liked 1,092 Times
Put the chain in big rear, small front, closest inboard. Adjust the screw, following Bill Kapaun's suggestion, until there is 1mm max clearance from the chain at its nearest point in the crank's revolution. You will normally not need to move it again.
Likes For dsbrantjr:
Liked 3,581 Times
I brought it up due to derailer rubbing tire occasionally under load
narrated my answer into my phone w/ a screw driver on the correct screw: on this bike, it's he outside screw the one marked low clockwise moves it out away from the bike counter clockwise moves it left toward the frame
Nice, dry chain.
Only slight rust.
Grind, grind.
Only slight rust.
Grind, grind.
Liked 3,581 Times
Ignore the chain location in that photo cuz it’s on the small sprocket in the back. Or I tugged in the chain to see the other part So I adjusted the screw & deflated & massaged the tire so it wobbles less seems better . Took it out in the parking lot for testing before it got dark, including a climb, under load, in lowest gears front & rear no rubbing. Isn’t a lot of room tho & if the skewer loosens the wheel can rotate it into the derailer which has happened cpl times so I’m keeping an eye on that skewer tension too
Liked 3,581 Times
Thanks guys sensible tips
Liked 3,581 Times
Droid on a mission
Quoted: 317 Post(s)
Liked 280 Times
I'd wipe that chain down real good and re-lube, if you still have that amount of rust oozing from the rollers then repeat again.
Liked 3,581 Times
sorry about those large pics. was working with just my phone. that's a really difficult area to photo. took another look this am. chain on both inner rings front & rear & w/o touching chain rotated tire to closest pass. doesn't wobble as much so I'm glad about that & this clearance I think is usable. also used a rotary grindstone on my drill to trim back a mm off the black part that was like folded over & protruding toward the tire (even tho this isn't where the actual rubbing was happening, it was rubbing on the silver part)
Liked 3,581 Times
Quoted: 1572 Post(s)
Liked 643 Times
Think before you screw.
1. Was it ever right? Derailleur limit screws, once set correctly, seldom need readjustment.
2. If it only happens when under load, the grinding you hear is probably due to bottom bracket movement.
like horses, dont put chains away wet and unlubed.
before anyone asks, my fav horse lube is "TriggerLube", regularly get 5000kms out of a set of shoes.
Liked 3,581 Times
hmmm, trying to remember. bought the bike used. my riding has gotten progressively more aggressive on steeper terrain. like I mentioned the left rear dropout wiggled out causing the wheel to pivot right & jam. dunno if that best the derailer a smidge. making it more susceptible to rubbing again. every time I mount those tires I have to massage them a lot to get them on w/o too much wobble. since I bought the bike I never adjusted the limit screws. is a little bottom bracket movement OK or should I be looking for other symptoms for replacing it?
catching up.... I'm seeing the typical issue..
A trade off of fat knobby tire, + short chainstay bikes, grind off offending knob rubber ...
or just put a tire on without that interference..
Likes For fietsbob:
Liked 3,581 Times
Bikes: Schwinn Varsity
Quoted: 1931 Post(s)
Liked 742 Times
"Think before you screw" ... that's funny.
BikerBob had a good idea.... cut the tire down..... I like that idea.
Also...in cases like this where you just need a bit more clearance... I use an adjustable Crescent wrench and pliers and tweak the front DR in the right place.
maybe one of those reciprocating 2 blade motorized carving knives?
... that only get used for the big holiday birds.. charity shop search should find some
Likes For fietsbob:
I'd probably use my 3" cut off wheel....outside.
Like this-
https://www.harborfreight.com/3-in-H...ool-63023.html
Like this-
Liked 3,581 Times
Likes For trailangel:
Liked 3,581 Times
finally got back out on this bike. no more rubbing
cajunpedaler
Bicycle Mechanics
11
12-01-14 06:09 PM
skydive69
Bicycle Mechanics
4
07-17-10 10:02 AM
