Frayed cable caused entire shifter failure?
Quoted: 1324 Post(s)
Liked 927 Times
I said we are doddering fools, not you. We are discussing strategies to live with technology that was made obsolete a decade ago.
Unfortunately, traditional QRs were not designed for the forces applied by disc brakes, and can loosen under hard use without periodic adjustment. Rim brake equipped bikes do not have this problem.
FYI, I also keep my bikes until they can no longer be kept. But disc brakes, good ones being superior to all forms of rim brakes for multiple reasons, are a legitimate upgrade to a mountain bike. I have two (almost) working MTBs right now - one was originally built with V brakes but I converted to discs years ago, and the other has cantis, but it isn't really sufficient for real off-road use... I built it as a city/grocery/winter bike because I killed asset of Hayes hydraulic brakes by riding in salty slush and not doing anything to clean the calipers before I put it away until spring.
Also, my experience on IGH bikes is that a mini-wrench is not going to get the nuts tight enough to keep the wheel from slipping, so a decent ~6 or 8" long 15mm wrench is required. My youth spent on a Sekine with a nutted rear axle also agrees with this. Anything less than a regular size 15mm wrench is not going to allow enough torque to get the wheel tight enough, unless you also ride with a 'cheater bar' to use on the end of the mini-wrench.
Cheers
Señor Member
Quoted: 649 Post(s)
Liked 292 Times
Miele Man Obsolete != undesirable. What I meant was that new ones are not being made and parts are getting harder to find. Like I said, I have some 'vintage' bikes too - I know. Hence why people would have to resort to accosting people on the trail to try to get one. If it were not obsolete then it could be purchased new in a store.
Quoted: 550 Post(s)
Liked 325 Times
There really isn't an excuse for a cable fraying so badly in such a short time span that it ruins a practically new shifter. Nor should it be expected that, barring more extreme weather/conditions riding, that a cable should need to be check more frequently then annually.
Shimano suggests a 2500 mile replacement interval for Dura Ace 9001 levers which is every three months when you ride 200 miles a week.
https://www.bikeforums.net/bicycle-m...s-fraying.html
Campagnolo cables fray every 2000 miles
https://www.bikeforums.net/road-cycl...e-shimano.html
Shimano cables need changing every 2000 miles
Another 6700 setup that breaks cables in 2500-3000 miles
5800 shredded in 3000 miles
https://www.bikeforums.net/bicycle-m...l#post21134710
broken in 3.5 - 4k miles
https://www.bikeforums.net/bicycle-m...able-life.html
two broken cables in 4000 miles
https://weightweenies.starbike.com/f...28295&start=30
broke in 4000 miles
fail in 2400 - 3000 miles every 3-4 months
broke in 3600 miles
broke in 1500 miles, Shimano said the recommended replacement interval is 2500 miles
failed in just under 4000 miles
https://www.bikeforums.net/bicycle-m...n-problem.html
broke in 3800 and 4400 miles
SE Wis
Quoted: 2740 Post(s)
Liked 3,388 Times
Quoted: 4195 Post(s)
Liked 3,837 Times
Every shop I've been in (since brifters came out) has had at least one customer who breaks their shift cables far more frequently then the rest. Whether it's from shifting so often or so many miles or how they use the shifter it almost doesn't really matter.
I do agree that so many riders are fairly clueless about how to take care of your bike. (I teach bike repair clinics for our local club). Who's fault is that? I don't know. I do know that the new bike pick up speech we do would grow a lot if we tried to explain every possible future. We do offer free bike clinics on Saturdays that cover, amongst other topics, shifting and maintenance. Andy (Who has replaced many cables under "warranty" because it's an easy and quick way to make a customer happy for so little, whether the problem was even cable related)
AndrewRStewart
AndrewRStewart
Quoted: 1079 Post(s)
Liked 1,019 Times
I've replaced up to three in a 9 month window. Getting back in shape I broke two in 2019, the first in March and second in November.
It's not abnormal if you shift a lot and use modern levers with under bar tape routing with the required 90 degree guide causing fatigue failure in half the shifts.
Señor Member
Quoted: 649 Post(s)
Liked 292 Times
https://si.shimano.com/pdfs/um/UM-07X0A-004-ENG.pdf
I looked at the user's manual for both the cable brake and hydraulic brake versions of 10f STI levers, and there is no mention of 6 month or any arbitrary mileage cable replacement intervals. There is a note that 'regular wear and aging are not covered under warranty,' but failure after a few months on a road bike with, presumably, the OEM Shimano cables and housing that are included with new Shimano shift levers, would not in any reasonable person's view constitute 'regular wear or aging'. Get the shifters sent back to Shimano and they should replace.
However, your description of the problem sounds like it may not have been the frayed cable itself that caused the failure, but the shop's attempts at removing it. If Shimano denies the warranty claim this should totally be up to the shop to fix. Especially if the shop sold you the bike... most new bike sales, in my experience, come with a shop labour warranty of at least one year, usually to cover break-in related items like cable 'stretch', but also to weed out faulty products that may have not been noticed on assembly.
I am potato.
Quoted: 1782 Post(s)
Liked 1,621 Times
Wow. In reading this thread, I'm surprised that any one of the 20 or so bikes that have filtered through my stable (hobby/gifts/donations, etc...) have faired well at all.
1 single bike with 1 single frayed cable that got a "rough" feel at 4000 miles.
From the sound of it, it's a miracle the whole stable hasn't assploded in a mass conflageration of horror.
From now on, I'll consider myself one lucky soul, indeed.
Car dependency is a tax.
Señor Member
Quoted: 649 Post(s)
Liked 292 Times
Here they say yearly
https://bike.shimano.com/en-US/infor...rake-pads.html
Quoted: 6934 Post(s)
Liked 10,940 Times
I'm curious to know if BenBoozer has been back to his shop - and if so, whether they have accommodated him. I hope he will come back to update this thread.
Hello and yes I am back to report with good news. About a week after I went to the shop and requested that they file a warranty claim on the shifter, the mechanic called me and stated he took another "real good" look at it and found the strand of wire that was fouling it. I picked up the bike a couple days ago and just ran it through a test ride. Shifting perfectly. Total cost: $25.00 for shifter maintenance or something like that. I know now to have those cables inspected on like an 8 month schedule.
Likes For BenBoozer:
Bikes: old clunker
Quoted: 684 Post(s)
Liked 105 Times
Likes For AnkleWork:
Liked 10,940 Times
SE Wis
Liked 3,388 Times
Methinks it's time to find a new shop
Likes For dedhed:
working on my sandal tan
Quoted: 3870 Post(s)
Liked 2,563 Times
Maybe, but after this practice they might be a little better at servicing it next time.
Meanwhile, I'm thinking I may go with bar-ends if I ever decide to get shifters on my handlebars...
This should 100% be a warranty issue. If the shop didn't tell you outright "the cables need to be replaced every two months' then this is on them.
Also, Shimano parts on new bikes have a 2 year warranty (except Dura Ace, which is 3 year), and this was a new bike. Any LBS can make a warranty claim. If the one that sold you the bike is giving you the runaround, go to a different shop. You should expect to pay for shop time to remove and reinstall he replacement at a second shop, and maybe a few bucks for shipping back to Shimano, but not for the new shifter.
Señor Member
Quoted: 649 Post(s)
Liked 292 Times
However, even if they were from another maker, it is definitely a problem with Shimano shifters from the last decade or so that have a consistent problem with cable fraying and breaking. Prior to routing all the cables under the bar tape, cables would outlive just about every other part of the bike.
Likes For Wilfred Laurier:
My experience from assembling bikes for a small manufacturer is that the OEM shifters come with cable already installed.
You may think shimano shifters have issues. I on the other hand think lots of issues (fraying cables, dropped chains, poor braking, rough lever feel, ect.) are caused by bike manufacturers cutting corners, speccing all sorts of parts to cut cost or to differentiate in the market.
Bikes: old clunker
Quoted: 684 Post(s)
Liked 105 Times
Lots of misconceptions about contracts and warranties. Apparently, the OP has a contractual relationship with the retailer. That contract includes express and implied warranties. The OP probably has a contractual relationship with Trek via their express warranty -- a term of sale, and probably does not have a contractual relationship with Shimano. Shimano may provide warranty coverage via their relationship with Trek.
Said repair should have been fully covered by any or all of the above. I would not have paid $0.25 let alone $25. Because consumers frequently lack knowledge of contract law they are easily deceived.
don't try this at home.
Quoted: 972 Post(s)
Liked 509 Times
My Campagnolo 10 speed Veloce had breakage. I broke shift cables twice in 20,000 miles, each with fairly low mileage, somewhere between 2500 and 4000 miles. Each time, I didn't notice any symptoms before the ride where the cable broke. I noticed some sloppy shifting (like the OP mentioned), thinking I'd want to adjust the derailleur when I got home. Then a missed shift, where I needed to shift once more and shift back to move the chain. (The cable was really frayed by this point!) Then within an hour, snap!
I do shift a lot. I'll often shift for just a couple of pedal strokes, then shift again. Rolling hills get the most shifts.
Campagnolo has a little window in the shifter where the cable makes it's 90 degree turn. So it's possible to fold back the hood and check it for fraying. I don't know about Shimano shifters.
Di2
Wow, low maintenance! And I shift even more often now. It's effortless, fast, and precise.
I just checked over my Ultegra Di2 this month. I got it on a new bike in Sept 2014. I have 20,000 miles or a little more on the bike.
I still have the original seatpost battery. I expected it wouldn't hold a charge too long after all the this time, but it's still serviceable. Maybe a new one this year. I'll make a note of when I charge to see if the time period is dropping from the original 800-1000 miles or so. (I try to charge soon when it drops below 50%, the solid green light.)
The rear derailleur pivots aren't worn -- the shifter has no sloppy play when I wiggle the body or the pulley arm. And the shifting is still great.
I removed the pulleys, expecting to need new ones. The bottom one is perfect, the top one didn't spin quite as freely. A drop of oil helped. But I'm putting new pulleys in anyway. Di2 has it's own pulley part number. Around $20.
Front derailleur is fine. Shifters are fine. Shift buttons work as new. Even the rubber hoods have minimal wear.
I've micro adjusted the rear derailleur shift centering maybe 4 or 5 times. It's simple, just hold the junction button for 5 seconds, then each shifter click adjusts the derailleur a tiny amount in that shift direction. Fast and easy.
Quoted: 550 Post(s)
Liked 325 Times
The problem is that a bend radius under 1" or pulley diameter under 2" is smaller than mechanical engineering guidelines allow for 0.047" (1.2mm) wire rope, and shifters don't have that much room inside.
Regardless of what brand you buy, you'll get 304 stainless steel plus strain hardening from the die drawing process failing after a similar number of stress cycles.
If you want different life you'll need to change the material. KCNC makes titanium shift cables. Power Cordz are made of polymer fiber.
Alternatively, you can upgrade to electronic shifting.
Bikes: 2 many
Quoted: 1266 Post(s)
Liked 323 Times
No.
Liked 1,019 Times
I think some of it just comes down to manufacturing tolerances and things being left too rough or imprecise with the occasional shifter that causes the problem. I've got a set of rx100 shifters that has used the same cable for years. Ultegra with cables that are on their third, maybe fourth year, Tiagra that have a couple year old cables. But the 105s on my wife's bike that we ditched after the first frayed cable the cable broke after only a couple months and she doesn't ride as much as I do. Most of the people I'd helped with the problem hadn't experienced the problem with their other or older bikes suggesting it isn't them. Like I did for my wife, if a shifter frays a cable I'd just get rid of that one since all the shimano sti levers I have running in this house suggests its not a larger issue.
Grease the cable track inside the shifter?
I have had two RD cable fray issues with Shimano 9000 and 6800. Both times I was able to fish the cable ends out of the shifter. One cable broke and another I had to cut. In both case I had to remove the shifter and spend a lot of time with some dental type pic tools to get the cable end out. I have started to put silicon grease in the track inside the shifter that the cable runs through in an attempt to reduce the friction on the cable. Time will tell if this really makes any difference.
