Pedals With Toe Clips
Insane Bicycle Mechanic
Quoted: 802 Post(s)
Liked 703 Times
You can't go wrong with MKS Sylvan pedals:
https://www.universalcycles.com/shop...s.php?id=19660
They'll accept any of these toe clips and straps:
https://www.universalcycles.com/shop...?category=1670
Jeff Wills
Jeff Wills
Solution
Those look nice and the price is right. Those are the types of pedals that came with the bike. I ride in tennis shoes and the cleats dig in and put my foot asleep. Had to grind the cleats down and homemade a platform.Solution?...Thanks,mjac
Friendship is Magic
Bikes: old ones
Quoted: 26401 Post(s)
Liked 10,374 Times
...I have, and use with toe clips, every one of those pedal versions so far mentioned. All three work well, but yes the GR-9's are bargain priced for a workable platform pedal that gives you some flat base for you tennis shoes. The Sylvan has been in production for many years now, and is also a very good choice, because it's a wide pedal, and has the additional advantage of having a surface on the underside that you can easily pedal on when you first start moving, in case you miss picking up the clip on your first go at it.
Likes For 3alarmer:
Needed
Quoted: 1438 Post(s)
Liked 1,092 Times
I like Power Grips in lieu of clips and straps: https://mrpbike.com/collections/power-grips
Interesting
rebmeM roineS
Quoted: 653 Post(s)
Liked 347 Times
I used Power Grips for a couple of years as a transition from toe clips to clipless pedals in the late '90's. They worked pretty well. Weren't compatible with all pedals.
Had previously also earlier used a couple of different actual platform pedals with toe clips, one of which was MKS - possibly same or very similar to the Urban model discussed above. The other was the classic Lyotard Marcel Berthet platform. VeloBase.com - Component: Lyotard Marcel Berthet (later type)
My spouse uses the MKS Sylvan pedals on her single bike with half-clips. She has only in recent years used clipless pedals as the stoker on our tandem.
One thing I have always wanted to know. You are riding a tandem, in the front. How do you know if the person in the rear is putting out any effort or you are pulling the whole train?... Curiuos,mjac
rebmeM roineS
Quoted: 653 Post(s)
Liked 347 Times
I'm obligated to state that my spouse/stoker is always contributing to the work that we do to move forward. One of the rules of tandem-riding is that the stoker is never at fault.
Quoted: 1303 Post(s)
Liked 1,909 Times
JanMM,
Your'e right they weren't expensive back then,I had them on everything. And then the source dried up! I wound up landing with Suntour sealed bearing pedals that were not complete platform, but allowed for my wide feet. The other option was Campy track pedals, but kinda salty in price back then. Thanks for the memories, MH
If you mean the Marcel Berthet pedals, they weren't expensive when I used them in the 1980's.
What if she is dogging it?
Marcel Berthet
JanMM,
Your'e right they weren't expensive back then,I had them on everything. And then the source dried up! I wound up landing with Suntour sealed bearing pedals that were not complete platform, but allowed for my wide feet. The other option was Campy track pedals, but kinda salty in price back then. Thanks for the memories, ,MH
Friendship is Magic
Bikes: old ones
Liked 10,374 Times
Likes For 3alarmer:
These are some very inexpensive lightweight chrome steel items from somewhere in China. I got them on ebay.
...FWIW, since we're talking pedals that fit wide feet, MKS makes a knock off of the old Suntour quill pedals called the AR-2. I use them in situations that seem appropriate for quill pedals. They have a wide "platform", and a pretty shallow quill portion. They're usually pretty cheap, from the various online sellers like Ben's.
