Severely stuck fixed cup of BB
Quoted: 1088 Post(s)
Liked 1,022 Times
Although these are neat tools, where do you put the big @ss wrench for the leverage you need or is it the little handles?
I've had cups I didn't really consider stuck and I still had to step on the wrench to get enough leverage just to get them loose. A tool like the different pics seems good for almost all and useless on the rest. And if a pipe wrench can bite in enough I'd worry about the hardness of the steel in the tool.
Friendship is Magic
Bikes: old ones
Quoted: 26400 Post(s)
Liked 10,373 Times
But grabbing the tool in the pipe jaws on a bench vise and twisting the frame is how you get maximum leverage.
Likes For 3alarmer:
Total Scrounge
Bikes: 71 International 72 Super Course 83 Gap
Quoted: 327 Post(s)
Liked 924 Times
Has anyone ever tried to adapt an impact wrench in this situation? I’ve always found that the hammering action of a pneumatic or electric impact wrench is more effective than a big lever. Just a thought.
Really Old Senior Member
Most bike mechanics aren't going to be equipped with 1/2" or larger impact wrenches and an air compressor to keep up.
And you still have to hold the rest of the bike.
My "tool set" in post 7 hasn't failed me yet in 6 "frozen" cups.
Multiple applications of Liquid Wrench dribbled in the shell from the opposite side to run down into the threads. 1st application, keep dribbling as long as it keeps running into the threads.
7 whacks & 6 cups. I was too gentle on the very 1st whack. 2nd whack I KNEW the tool would stay in place.
Likes For Bill Kapaun:
Quoted: 1324 Post(s)
Liked 927 Times
I've take a bicycle frame with a really stubborn to remove fixed cup to a park and then strapped the frame to a picnic table. I then used my copy of Sheldon's fixed cup removal tool and a long handle (24+ inches) socket handle on the socket that I fitted over the bolt head. That always go the fixed cup loose.
However, upthread the OP said that his attempts were not working and it looked to him like the fixed cup was being destroyed. Thus I'd use a good quality penetrating solution copiously applied from inside the bottom bracket shell and then I'd put something over the fixed cup, support the non-drive side of the frame on something solid and then whack the protected fixed cup firmly with a good size hammer or mallet in the hopes that the shocks would help brea loose whatever was jamming the threads. I've seen master car mechanics do that on seaized bolts or nusts where they didn't have access to an impact wrench and it usually worked a treat.
Cheers
Cheers
Total Scrounge
Quoted: 327 Post(s)
Liked 924 Times
How about you?
I’m not suggesting it’s a great idea, or that I’ve tried it, I just know that in other disciplines impact is the way to go. Might be an interesting experiment with a frame that isn’t too precious.
Nope, never really needed to. As a contractor, though, impact drivers have become ubiquitous, as they have tons of power without relying on the same sort of torque that a drill uses. Same with auto mechanics, an impact wrench has a magical effect on stuck nuts and bolts. In this case, you could just have the bike in a stand and an impact wrench could hammer away without the need to hold the frame, really.
At that point, a 4 lb. hammer takes less set up time. You don't have to connect it to its "power supply". You don't have to coil up & stow said "power supply".
It's akin to having your brain surgeon use a hammer & chisel to crack your skull.
Friendship is Magic
Bikes: old ones
Liked 10,373 Times
....mostly you see impact wrenches (either electric or pneumatic) suggested and used to remove freewheels.
But that's a case where the removal tool is already often manufactured to fit a square shanked socket ratchet.
Total Scrounge
Quoted: 327 Post(s)
Liked 924 Times
Doesn’t the sheldon browne homemade tool rely on a socket wrench? Seems like a natural place to use an impact socket.
Likes For davidad:
Old fart
Quoted: 3587 Post(s)
Liked 3,398 Times
You slide a cheater pipe over the handle. The Campagnolo tool comes with one (part 793/4 in the illustration); for the others you supply your own. And, as noted, the Campagnolo tool can be clamped in a vise so you can use the frame itself as a lever.
Old fart
Liked 3,398 Times
Sometimes you are desperate to SAVE the cup.
My method works as a 1st resort too, AND saves the cup.
Your inexperience really shows.
Total Scrounge
Quoted: 327 Post(s)
Liked 924 Times
Like I said, it was just an idea. Just musing on possible solutions for tough situations. Tools do tend to evolve over time, so no harm in keeping an open mind.
Quoted: 1303 Post(s)
Liked 1,908 Times
I own the VAR tool, which I use for my own projects. When it comes to my local co-op it is more like junk yard mechanics. Two weeks ago I had a youngster in trying to remove the adjustable cup of his BB. Went to the tool board and found the thin walled tool to move the cup,but it was frozen in place. (cups were so worn they pushed the threads into the BB shell) So I showed him how to use a socket and some washers, and the spindle nut to clamp the whole lot together. Had to use the frame straightening bar with 3' of leverage to get the cup to come loose. Easy? not so much. But did learning occur? yes. He now has an appreciation of how to make it work as BK's solution and my junk yard approach. Yes I am using the Var side of the BB shell pictured but it works the same way on both sides.
Now about the impact thing, I have a 1/2" drive black socket that I have cut the ends out of with much tribulation to fit on fixed cups. So far no need to get it out, but it is in the works. I have also looked at a 36mm open end/box end wrench at Menards for $20 that looks like a real beefy tool to use with a c-clamp and two blocks of wood. Because of the size, I am not sure about a cheater bar to fit on it. But the wrench is about 14" long, (plenty of room for BK's hammer!) Smiles, MH
Friendship is Magic
Bikes: old ones
Liked 10,373 Times
Anyway, I was doing enough of this to warrant buying a Hozan, and it works on everything I've tried it on. And some of that stuff was pretty stuck. It's worth seeking out someone who owns one, like the ever decreasing number of local shops.
We bought one for the co-op here, and it got/gets used a lot.
Liked 1,908 Times
Trip Alarmer, and BK,
The cup is already trashed as it can't hold the retaining seal. The best solution is the cup retainer socket made by the major manufacturers. But sometimes there are work arounds that help us in the world of junk restorations and it is always good to know what others are doing. Smiles, MH
SE Wis
Quoted: 2743 Post(s)
Liked 3,390 Times
While this was a cartridge, sometimes you just need lots of leverage.
Friendship is Magic
Bikes: old ones
Liked 10,373 Times
Liked 1,908 Times
Ahhh yes! My favorite tool is the blue wrench! Nothing like the sound of rushing Acetylene and Oxygen to make the heart beat faster. Smiles, MH
Likes For Mad Honk:
Likes For JacobLee:
Total Scrounge
Quoted: 327 Post(s)
Liked 924 Times
And let’s use our manners, Bill. I’m pretty sure your comment is against the spirit of the forums.
Friendship is Magic
Bikes: old ones
Liked 10,373 Times
...not certain you've used an impact wrench in a circumstance like this. It's not like going at a lug nut on a car wheel, and the bicycle itself tends to move around easily. So the business end of the tool either slips out or can damage the little teeth in the BB fitting (they are either aluminum or plastic.) So it might work, but you're way better off bolting the tool to the sealed unit spindle with a properly sized bolt and some fender washers, putting either an adjustable or (better) properly sized box end wrench on the tool, and hitting the wrench with a mallet or hammer. Plus you get to use a hammer.
SE Wis
Liked 3,390 Times
Likes For dedhed:
IF it was a good idea, it would have been suggested earlier in the thread by someone knowledgeable.
I should have told you the blunt truth earlier.
Ignore list-
