Triplize a Shimano 600 double?
Bikes: '84 Miyata 610 91 Cannondale ST600,'83 Trek 720 84 Trek 520, 620, 91 Miyata 1000LT, '79 Trek 514, '78 Trek 706, '73 Raleigh Int. frame.
Quoted: 685 Post(s)
Liked 370 Times
https://www.bikeforums.net/classic-v...nk-6207-a.html
I've installed the double ring version of this crank on my wife's bike, and she needs the granny gear.
Is this something I can add on? I believe I'd need to source the granny, the longer axle, and possibly longer sleeved allen bolts to go through the third gear?
Extraordinary Magnitude
Quoted: 2608 Post(s)
Liked 1,699 Times
The 6206 and 6207 are very different cranksets.
The 6206 is effectively the 600/XT level triple crank with the 110/74 BCD pattern.
The 6207 is a 130 BCD double crank.
Commence to jigglin huh?!?!
Quoted: 685 Post(s)
Liked 370 Times
So different crank entirely.
The original set up that came on her bike, an '88 ST400, was a suntour that had the threaded holes to accept a granny gear, but I swapped it for the shimmy 600 to use a set of 165mm cranks.
So find 165mm cranks and a granny for the suntour...
I wonder if I can find a full triple with 165's on fleabay...
I'll put up WTB post in the for sale section 👍
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
If a 34T granny is small enough, you could get one of those dual-pattern 110/130 chainrings to use as the triplizier.
blahblahblah chrome moly
Quoted: 1172 Post(s)
Liked 2,567 Times
Not sure if I understand, is this it: OP has some 165 mm cranks with a 130 mm BCD, and he wants to put a small granny ring on?
Then a 130 BCD triplizer ring should work, no? A triplizer ring replaces the inner ring of the double and becomes the middle ring of the triple. It has holes at 130 BCD to attach to the crank, and also holes at 74 BCD to attach the granny. So you need
Here's a later model TA:
Here's a Thorn (from SJS Cycles in the UK):
The TA has ramps and pins to aid with front indexed shifting, if you're into that. I think the Thorn is old-school, intended for friction shifting on the front derailer. I've never actually held a Thorn version in my hands though. I know the older-version TA triplizer was without ramps and pins.
Mark B in Seattle
- triplizer ring
- 74 mm BCD granny ring
- chainring bolts for the granny
- longer spindle
Mark B in Seattle
Likes For bulgie:
Liked 2,567 Times
Here's my wife's Dura-Ace 7400 in 165 mm, with a Stronglight triplizer.
I like the Stronglight, but it's more work than the TA, Willow or Thorn, because it doesn't have clearance for the 5 shelves off the inside of the spider arms, so you need to saw the shelves off. Not too difficult if you're handy, and you have a vise with soft jaws, a hacksaw, and a flat file to dress down the saw marks. Takes me about 15 minutes, but most people would be reluctant to take a hacksaw to a nice crank. Especially when there are other triplizer rings that don't require any sawing/filing.
My advice is get a TA. They're very well made, out of good hard alloy, and look great. $54 plus shipping from Bike24 in Germany https://www.bike24.com/p2141592.html
or $88 plus cheaper shipping from Peter White in the USA https://www.peterwhitecycles.com/ta-...ings.php#alize (scroll down to "tripleizer" -- that's the way he spells it)
I leave it to you to decide which is a better deal once shipping is added in, but shipping from Germany will probably be slower too, a factor if you're in a hurry.
Good luck, let me know if I can answer any other questions.
If I completely misunderstood your situation, then -- never mind!
Mark B in Seattle
Mark B in Seattle
Likes For bulgie:
ambulatory senior
Quoted: 1955 Post(s)
Liked 3,661 Times
Just here to say, those triplizers work great.
Death fork? Naaaah!!
+1.
Willow triplizer on Dura Ace 7400 crank:
Top
Top
Quoted: 3241 Post(s)
Liked 2,512 Times
Spindle length for the FC-6206 is 121.5. Maybe the will help with your situation.
Bikes: A bunch of old bikes.
Quoted: 278 Post(s)
Liked 870 Times
I swapped the short cage on a shimano 600 for a longer one from another shimano sis RD. That helped a bunch with the small gear combinations.
Quoted: 685 Post(s)
Liked 370 Times
We aren't going up mountain passes just the odd steep hill, and that would likely do the trick.
This is what I'm working with, it came with a long cage OEM, and the original crank had the spot for a granny, I just swapped it out to use the 165 crank arms for her.
Likes For Chr0m0ly:
