PVC Bike - Anyone tried it?
Old 01-09-05, 07:13 PM
HunterBee
formerly cycletourist
HunterBee's Avatar
A bicycle frame made from PVC would make a pretty interesting art work (the kind you hang on the wall) and Testor's model paint is designed specifically for use on plastic. It (a PVC frame) would be cheap and easy to make (no welding skills required). I don't think I would ride one, tho.
HunterBee is offline
Old 01-09-05, 07:41 PM
PanPanX
Ride On!!
PanPanX's Avatar
Bikes: 2004 OCR3, 1989 Nishiki Sport, 2003 Kona Blast, 2007 Fuji Track
when i say ride one, i mean down the street, or around the block or something like not.. stuff thats under a quarter mile..
PanPanX is offline
Old 01-09-05, 09:01 PM
mtbikerinpa
Shimano Certified
mtbikerinpa's Avatar
Bikes: 92 Giant Sedona ATX Custom
Quoted: 38 Post(s)
Liked 6 Times in 5 Posts
Aww, no freeriding?
mtbikerinpa is offline
Old 01-09-05, 09:22 PM
2manybikes
Bikes: 2 many
Quoted: 1266 Post(s)
Liked 323 Times in 169 Posts
Plastic bikes were made and sold. They were discontinued because they were too flexible and handled poorly.
Until CF, now lots of bikes are made of plastic. Pcv is not the same though. Not at all.
2manybikes is offline
Old 01-10-05, 12:37 AM
Hhowdy
I survived lotoja
Hhowdy's Avatar
Bikes: Kona Dawg-Deelux, Raliegh Competition
Howdy,
Commercial PVC pipe is probably not your best choice, I'd go more to the Lexan end of things. Lexan is available in tubing and is eaily worked and bonded. The draw back is probably the cost, I'd guess the material will cost 4-5 times as much...
M.R.
Hhowdy is offline
Old 01-10-05, 08:48 AM
Applehead57
slower than you
Applehead57's Avatar
Bikes: Gunnar Road Sport, peugeot UO-10
Originally Posted by ofofhy
I saw one designed to be used on the water made of PVC, but it was in a trike configuration. It had big, plastic, paddle-like, floating wheels on it. Mt guess is you would have to modify the geometry of the frame to support your weight.
Now this makes sense. Aim your inspiration to be a water bike.
Otherwise, you're going to have this cool, strange bike that drew a mild interest from passer-bys and then got stuck in the back of your barn, forgotten.
Applehead57 is offline
Old 01-10-05, 09:32 AM
Dirtbike
Giggity giggity!
Dirtbike's Avatar
Bikes: Yeti DJ Custom build. X.9, Marzocchi, RaceFace, Gamut, DT, Truvativ, Michelin, Hope.
once its complete, we need to find out how high we can do a drop with it
Dirtbike is offline
Old 01-10-05, 12:27 PM
PanPanX
Ride On!!
PanPanX's Avatar
maybe i can make one that can handle 6 ft drops.
and a waterbike would be too easy. made lots and lots of those in highschool physics.
PanPanX is offline
Old 01-10-05, 04:23 PM
myxbyx
least coast
myxbyx's Avatar
having recently used a lot of pvc pipe in my basement (drains) i would not like to be sitting on a bike made of it after a 6 foot drop, depending on your body weight, you might continue on through the cross bar without stopping.
however there was a bike i believe was called the Itera.....
myxbyx is offline
Old 03-19-07, 06:32 PM
bluewolf
Yes some has done a PVC bike
It's been done for 4 wheel bikes.
https://www.americanspeedster.com/
bluewolf is offline
Old 03-19-07, 07:46 PM
n4zou
Scott
n4zou's Avatar
Bikes: Too Many
If I were going to build a bike frame from an alternative material I would use wood. I found this link quite by accident and book marked it. It makes interesting reading and I think someone could look at his photos and figure out how to build one without sending this fellow $25. Then again $25 is less than you would spend at a fast food joint to feed the family so if I were going to do something like this I guess I would pay the $25 and save design time.
https://mysite.verizon.net/res88kr1/
n4zou is offline
Old 03-19-07, 08:44 PM
urbanknight
Over the hill
urbanknight's Avatar
Quoted: 998 Post(s)
Liked 1,206 Times in 692 Posts
Originally Posted by notfred
PVC is slightly stronger than cardboard. your bike will break.
I disagree. Shedule 40 PVC can be run over by a truck or stomped on by a 250 lb guy with steel toe boots and not crack. Class 125 is about like cardboard though. Either way, I'd agree that the bike could still break since a compression load isn't the same as the forces on a bicycle frame, so it's the land of the unknown to me.
My main concern is this...
Originally Posted by jemoryl
Actually, most PVC pipe I've seen has quite a bit of give. A PVC bike would be more like one made from al dente pasta.
The ride would probably like a car with springs but no shocks. I'd still up your health and life insurance, though.
urbanknight is offline
Old 03-19-07, 09:03 PM
wroomwroomoops
Sir Fallalot
wroomwroomoops's Avatar
Quoted: 9 Post(s)
Liked 13 Times in 11 Posts
Originally Posted by Rowan
Yeah, why not give it a go. so many things were met with "it won't work", "hope you're health insurance is up to date", and we use them now every day -- probably even that wonder product, carbon fibre!
Unintentional sarcasm - brilliant!
You gotta love the Internet.
wroomwroomoops is offline
Old 03-20-07, 11:04 AM
supcom
You need a new bike
supcom's Avatar
Liked 4 Times in 3 Posts
I'd leave the bike design to the experts. You can buy a real nice bike for the cost of a single trip to the emergency room.
supcom is offline
Old 03-20-07, 11:27 AM
geo8rge
electrical conduit? Probably bends before it fails. Tube benders and fittings already exist.
geo8rge is offline
Old 03-20-07, 11:41 AM
2manybikes
Bikes: 2 many
Building a bike out of an odd frame material still means you have to add all the normal bike parts. Compared to buying an entry level mountain bike a PVC frame bike will cost more if you buy the components at near retail. Then you have a heavy weak bike. Lots of things won't fit the pvc pipe so you will need some parts made special just for that bike. If you can't do it by yourself, and need to pay someone to make parts for you, (meaning you don't have access to a machine shop for free)
the price of the bike will easily be more than double the price of an entry level MTB. The diameters of the plastic pipe will be different than steel or aluminum, so most things won't fit.
You could build a lousy $300 bike for $600, maybe more.
Old 03-20-07, 11:56 AM
JustBrowsing
Señor Miembro
JustBrowsing's Avatar
Isn't it amazing how quickly a 2+ year-old thread can be resurrected. That said, I seem to recall seeing a story in the summer of '05 about a guy in California who was impaled on a piece of PVC after trying to make a bike out of the stuff... ; )
JustBrowsing is offline
Old 03-20-07, 01:19 PM
badfishgood
B(.)(.)BS
badfishgood's Avatar
Bikes: My bicycles?
There is a man here in Hermosa Beach who has a bike frame and wheels made of wood. It's pretty cool, shaped like a chopper... You should see him ride it up hill...
badfishgood is offline
Old 03-20-07, 02:21 PM
urbanknight
Over the hill
Quoted: 998 Post(s)
DOH!
Old 03-20-07, 06:32 PM
vpiuva
vpiuva's Avatar
Me want plastic bike to bomb down hills. + plastic wheelset. plastic calipers, plastic bars. please build. me pay lots for plastic death machine.
vpiuva is offline
Old 03-20-07, 07:04 PM
Lurch
Fossil
Lurch's Avatar
Bikes: Izip E3 Path Plus Step Thru , Raleigh Misceo
Quoted: 11 Post(s)
I saw a plywood bike once. It was a kid's size and made basically of two plywood triangles more or less side by side. The wheels were solid plywood circles with small circular cutouts for the schrader valves. It had rubber tires and plywood forks. It appeared well made and finished, not a homemade job. This was in a small town in Italy last October.
Lurch is offline
Old 03-21-07, 06:33 PM
carcassonne
PVC bike:
Well, at least you won't need any suspension like shocks and frame suspension :-) The whole thing should bounce away merrily.
carcassonne is offline
Old 03-22-07, 08:20 AM
n4zou
Scott
n4zou's Avatar
Bikes: Too Many
EMT conduit is a very popular material for custom bicycle frame builders and it will not bend after its welded into a frame. Follow this link as an example.
https://bikerodnkustom3.homestead.com/brad_overkill.html
n4zou is offline
Old 03-22-07, 06:19 PM
vpiuva
vpiuva's Avatar
Like to climb with that rear wheel? Talk about your rotational weight issues.
vpiuva is offline
Old 03-22-07, 09:21 PM
2manybikes
Bikes: 2 many
Leaning the bike over in a hard corner would also be interesting with a tire like that.
