Civia Belt Drive Bryant - Fender and Changing a (rear) flat
Bikes: 2012 Motobecane (BikesDirect) Immortal Force; 2011 (?) Civia Bryant Gates Carbon Belt Drive (upgraded to Alfine 11 and Gates CenterTrack)
I am considering putting fenders on my Civia Bryant. It has occurred to me that in order to change a flat rear tire I will need to slide the rear wheel back about an or so - the Bryant has horizontal dropouts.
Does anyone have experience with this? Do I need to mount the fender differently? Is there generally enough clearance if I deflate the tire 1st? Is this a non-issue?
Mike
Mike
Bikes: Vassago Moosknuckle Ti 29+ XTR, 90's Merckx Corsa-01 9sp Record, PROJECT: 1954 Frejus SuperCorsa
Quoted: 174 Post(s)
Liked 157 Times
IIRC the dropouts on the Bryant are pretty short, so you'd only need 1" or so of space. I'd mount the fenders with a touch more clearance at the back (the stays should have enough length, depending on their length and the eyelet location). To remove the wheel, you'll probably need to move the wheel forward slightly (release tension on the belt), slip the belt off of the chainring (to the inside), then pull the wheel back and let it drop. Before doing any of this, ensure you've removed the Alfine shift cable, which takes all of 2 seconds when using an old spoke cut to 6" or a 2mm hex.
DancesWithSUVs
Quoted: 7 Post(s)
Could also use SKS fenders and use the safety releases on the rear struts. Then you can just pop the rear struts off to give yourself some extra room.
C'dale BBU('05 and '09)/Super Six/Hooligan8and 3,Kona Dew Deluxe,Novara Buzz/Safari,Surly Big Dummy,Marin Pt Reyes,Giant Defy 1,Schwinn DBX SuperSport,Dahon Speed Pro TT,Brompton S6L/S2E-X
DancesWithSUVs
Quoted: 7 Post(s)
Never had a prob using longer bolts,spacers,and a little bending of the strut to mount fenders with discs. Also note your fork has lowrider mounts;you can always attach the stays to them and trim off the excess.
As far as the fender fitting issue, I just returned the SKS and bought some that fit without duct tape and bailing wire. I say that with respect, as the one time owner of 1956 (pre-unit) Triumph 650 that was in fact held together with duct tape, bailing wire, and hose clamps.
