Go Back  Bike Forums > The Racer's Forum > Track Cycling: Velodrome Racing and Training Area
The Effect Of Crank Length On Performance
Track Cycling: Velodrome Racing and Training Area Looking to enter into the realm of track racing? Want to share your experiences and tactics for riding on a velodrome? The Track Cycling forums is for you! Come in and discuss training/racing, equipment, and current track cycling events.
Old 10-27-18, 11:40 AM
carleton
Elitist
carleton's Avatar
Quoted: 1369 Post(s)
Liked 75 Times in 61 Posts
Originally Posted by topflightpro View Post
I see now. I did not scroll down far enough: https://rotorbike.com/catalog/default...3d-cranks.html. It lists only 170-175 in the written description, but the chart farther down shows the other lengths.
This is what confuses me, too.
carleton is offline
Old 10-27-18, 02:53 PM
gl98115
Quoted: 140 Post(s)
I can confirm that the 150mm ALDHU3D crankarms exist and are available because I have two pair.
gl98115 is offline
Old 02-22-19, 01:22 AM
fastkad
Quoted: 5 Post(s)
Liked 3 Times in 1 Post
Ken is also like 5 feet tall.
Leg length is a factor. I'm currently running 170s, and my fitter said normally she would scream about someone running cranks that long, but they work okay for me because I have such long legs. Still thinking about going down to 165s though because the latest science says they are faster. (Per the video I posted earlier.)
You're generous. He's 4'11" last time I check the mirror.
fastkad is offline
Old 02-22-19, 01:26 AM
Baby Puke
Bikes: Marin Stelvio, Pogliaghi SL, Panasonic NJS, Dolan DF4, Intense Pro24 BMX
Quoted: 351 Post(s)
Liked 73 Times in 50 Posts
Baby Puke is offline
Old 02-22-19, 01:47 AM
fastkad
Quoted: 5 Post(s)
Few quick noticeable differences of these little cranks. I switched from 165 to 155 (Carelton's pic above) few seasons ago:
* Higher peak cadence (20-25rpm net gain).
* Higher saddle height; more aerodynamic position.
* Higher effective gear (old 92" becomes 95-96" roughly).
* The need to reglue chainring bolts every 2-3 months!
It boils down to personal preference after everything is said and done. However, metrics tend not to lie. Hope this helps!
fastkad is offline
Old 02-22-19, 04:58 AM
Morelock
Morelock's Avatar
Quoted: 256 Post(s)
Liked 30 Times in 22 Posts
I'm not saying you didn't see aerodynamic gains, but can you expand? In my experience this has not usually been the case.
Morelock is offline
Old 02-22-19, 05:27 AM
gycho77
Bikes: Serotta steel track bike, Specialized MTB
Quoted: 99 Post(s)
Liked 4 Times in 3 Posts
Yellow line is 170mm crank and blue line is 165mm crank.
as you can see shorter cranks are more aerodynamic
gycho77 is offline
Old 02-22-19, 05:44 AM
Morelock
Morelock's Avatar
Quoted: 256 Post(s)
Was it more aerodynamic when he wasn't posing with his head in a totally different position as well
Morelock is offline
Old 02-22-19, 05:56 AM
gycho77
Quoted: 99 Post(s)
It was the same position. It's just a bad screenshot.
So same head position and others. That's why the yellow line is lower than the current head position.
gycho77 is offline
Old 02-22-19, 06:28 AM
Morelock
Morelock's Avatar
Quoted: 256 Post(s)
You can tell by his ear position in relation to his shoulder that it isn't the same head position. (as well as that he's not even remotely looking up in the second one, while he's periscoping his head in the first)
His hip angle also decreases by ~ 5, the opposite of what would happen by moving to shorter cranks if the position had stayed the same. The shoulder angle (bend at the elbow) decreases by ~8 as well, tightening everything up. This doesn't happen from 5mm crank length as the only change.
By dropping his head and rotating his hips he has dropped into a more aerodynamic position. Short cranks can indeed help with that SOMETIMES but too often someone jumps on the internet, reads 30 minutes on Slowtwitch and jumps to drastically shorter cranks... the same way time triallists 10 years ago thought you needed 180+mm cranks to produce more leverage.
Fwiw I think he has a good fit, and it looks aero. I just think the forest is getting lost in the trees a bit.
Morelock is offline
Old 02-22-19, 11:59 AM
bartek.
Quoted: 63 Post(s)
OK, not sure if I get it correctly...
Extra 20-25rpm per 10mm shorter crankarm? This is A LOT. That would mean that between 165 and 170mm crankarms length would be about 10-12rpm difference?
This is where I am confused. You increased in cadence AND gear ratio simultaneously? Or that your absolute speed stays the same with lower ratio, shorter crankarms and higher cadence? I believe the second, just want to be sure.
What is a reason for this? Higher cadence makes more vibrations than smashing?
bartek. is offline
Old 02-22-19, 01:03 PM
rensho3
Bikes: Fuji Elite, 3Rensho track, Trek Madone 6.9, Specialized MTB, GT MTB, Cannondale Cad3 fixie
Quoted: 72 Post(s)
I did buy the 150 cranks from Rotor, and I have had several comments concerning how much better I look on the bike when I am in an aero position (handlebars are Scattos). I must be more aero, because my speeds are up and my times are down, and nothing else has changed, except for me getting even older, which I am pretty sure is not enhancing my performance any.
rensho3 is offline
Old 02-22-19, 01:29 PM
fastkad
Quoted: 5 Post(s)
  • Doubt the cadence gain will be linear like that. Perhaps a better conclusion might be: the closer the optimal crank length, the higher peak cadence.
  • Shorter cranks, less leverage. That makes the gearing effectively taller.
  • Ever serrated chainring bolts won't stay put in the Power2Max spider (a known issue) and they keep spinning. J-B Weld holds the best but needs to be reapplied every few weeks (3-5 ring swaps per week on average).
fastkad is offline
Old 02-22-19, 02:39 PM
queerpunk
aka mattio
queerpunk's Avatar
Bikes: yes
Quoted: 339 Post(s)
Liked 50 Times in 30 Posts
Short people tend to be on cranks that are too long, unless we seek out aggressively shorter-than-ordinary cranks - stuff below 165. Being on "too long" cranks means that we tend to have positions that are more upright than, say, the 'platonic ideal' of bike positioning - so that we can have a hip angle that can produce power. Or, hell, just so that we can get our legs over the top of the stoke.
But when we shorten the cranks, we can raise the saddle, pitch our torsos forward, and start to approach that nice-looking position.
queerpunk is offline
Old 02-22-19, 03:49 PM
Morelock
Morelock's Avatar
Quoted: 256 Post(s)
^I'm not at all saying short cranks are wrong, or won't make you more aerodynamic. They can. For the 5'5 woman 170's that came stock on her bike likely are too long. For the right bike/position/person, 155's or shorter may be right. All I'm saying it that people don't understand what is often making them more aerodynamic.
This athlete changed nothing in equipment between these two runs. There is a 15 watt difference between them. That's in the most controlled setting you can have testing differences in aerodynamics.
That's why it's hard to account for "I must be more aerodynamic" because I changed xxx without checking a lot of boxes and making sure you really only changed one thing. In the real world, that means lots of a/b/a/b/a/b testing realistically. (and keeping up with crr drift, temperature, small position changes, etc)
*athlete is me... (~10yr ago)
Morelock is offline
Old 02-22-19, 04:03 PM
gl98115
Quoted: 140 Post(s)
What he is referring to is what Shelton Brown calls 'gain' ratio.
https://www.sheldonbrown.com/gain.html
gl98115 is offline
McBTC
Road Cycling
29
09-08-17 10:48 AM
dwmckee
9
12-02-13 02:38 PM
Dolamite02
13
04-03-13 11:42 AM
hobkirk
Road Cycling
17
07-31-12 11:33 AM
tjspahr
Road Cycling
3
02-27-10 01:37 PM
