Tire Pressures
Tire Pressures
Old 11-13-19, 11:30 PM
Bigbus
Bigbus's Avatar
Bikes: In Flux
Quoted: 125 Post(s)
Liked 41 Times in 30 Posts
Tire Pressures
I'm curious what other road riders with 1 1/4" tires are running for pressures on 27" rims. Tube type, Mine are rated at 90PSI and I've been experimenting all over the place. Thanks in advance for any replies.
Bigbus is offline
Old 11-13-19, 11:48 PM
HTupolev
Quoted: 1367 Post(s)
Liked 184 Times in 111 Posts
1 1/4" is ~32mm and 27" is almost exactly the same diameter as 700c. So I'd run them about the same as I'd run a 700x32.
For my ~190lb road bike+rider weight, if I was on decent roads, I'd probably do something in the vicinity of 70 PSI in the rear tire, maybe 5-10 PSI less in front.
What's your bike+rider weight, what are your roads like?
HTupolev is offline
Old 11-14-19, 05:35 AM
jpescatore
Bikes: Trek Domane SL6 Disc, Jamis Renegade
Quoted: 187 Post(s)
Liked 51 Times in 39 Posts
I weigh 230 lbs and run 80 on my 32mm 700cc tires. I've played around between 90 - 70, after many years at 90. I honestly couldn't tell much difference but flats did go down at 80 compared to 90. The science says lower is just as efficient if not more and pinch flats did not start to happen at 70. If I lose weight, I will lower it.
Earlier this year I did the Seattle to Portland ride on a rental Fuji road bike with 32mm tires. I forgot to check the air pressure on the first day, felt fine. On the second morning I checked - the tires were at 65 psi! I pumped them up to my usual 80 - psychologically, I felt faster. Looking at numbers - no difference.
jpescatore is offline
Likes For jpescatore:
Old 11-14-19, 09:13 AM
Kabuki12
Kabuki12's Avatar
Bikes: 1973 Windsor Profesional,1976 Kabuki diamond formula with full Campy, 1977 Raleigh Competition GS , 1971 Stella original Campy equip. 1978 Raleigh Super Grand Prix, 1972 Italvega Gran Rally ,1972 Super Mondia Special,Medici Pro Strada
Quoted: 150 Post(s)
Liked 107 Times in 77 Posts
I have 27" x 1 1/4" tires on my Mondia and I checked them with a pair of calipers and they measured 1.390" or 35mm. This is with 80lbs. They are Michelin Pro Tech that I got at REI and they were under $30 each. They are mounted on 1 1/4" wide rims. I am glad the bike has extra clearance to clear the wide tires , even though I have to mount the rear wheel with the tire deflated. The ride is great , but they are heavy. I am running them at 75 lbs and I weigh 155.
Kabuki12 is offline
Old 11-14-19, 09:35 AM
Sapperc
Bikes: Specialized Roubaix SL4 Comp, Trek 930, Nishiki International
Quoted: 59 Post(s)
Liked 18 Times in 10 Posts
I would be careful trying to compare newer 700c wheels to old 27” wheels. They aren’t built the same externally or internally. Same goes for the associated tires. But then I’m not an advocate for under or over inflating tires. The old style 27” tires like mine are labeled “inflate to 90 PSI.” That’s how I ride them. The ride on my vintage Nishiki International is responsive, supple, and sure. No need to fix something that was never broken.
Sapperc is offline
Old 11-14-19, 11:51 AM
Caliper
Bikes: Many
Quoted: 354 Post(s)
Liked 31 Times in 25 Posts
Inflating tires based on volume and load is something that basically applies to all pnuematic tires. Plus there are plenty of 700c wheels and tires built to the same quality as 27"ers.
Personally, I use the Berto tire pressure app, plug in my riding weight, bike weight and tire installed width. I treat 27" tires as 700c and run that. Technically the 8mm larger diameter of a 27" rim means more volume so they could be run slightly lower, but it's good enough.
Caliper is offline
Old 11-14-19, 01:49 PM
Carbonfiberboy
just another gosling
Carbonfiberboy's Avatar
Quoted: 2069 Post(s)
Liked 178 Times in 140 Posts
27" wheels means not hooked rims. Too much pressure will blow the tire right off. 90 is plenty, 80 maybe better.
Results matter
Carbonfiberboy is offline
Old 11-14-19, 02:25 PM
rumrunn6
rumrunn6's Avatar
Quoted: 3430 Post(s)
Liked 447 Times in 328 Posts
I pump my road bike's rear tire to max pressure & don't sweat the schrader burp at the end. I run the front a little lower, maybe 5psi? (700c)
rumrunn6 is offline
Old 11-14-19, 02:53 PM
HTupolev
Not necessarily. Hooked rims took off in the 70s, and 27" remained popular well into the 80s. Plenty of 27" wheels from that period have hooks. (And any bike that's had its rims replaced with new 27" rims since then will almost certainly have hooks.)
HTupolev is offline
Old 11-14-19, 08:01 PM
seedsbelize
smelling the roses
seedsbelize's Avatar
Quoted: 5187 Post(s)
Liked 118 Times in 92 Posts
I'm old school. I can't get used to running those low pressures. I still ride 23, and 25mm tires, in the 100 psi range, 700c. 27" slightly lower.
seedsbelize is offline
Likes For seedsbelize:
Old 11-17-19, 10:39 AM
Bigbus
Bigbus's Avatar
Bikes: In Flux
Quoted: 125 Post(s)
Thank you for all the great replies. I'm old school MTBer and have been for many many years, but this road bike thing is all new to me since the donated bike (Giant Quasar from the late 80's) and I'm really beginning to enjoy the roads more. The last time I pressured up I set them at 70psi which for a MTBer is really a lot of pressure. With the higher pressures I have noticed how much I miss a front suspension fork. But you gotta love the speed. Compared to a MTB this thing flies haha!
Bigbus is offline
